E-body Holley Sniper EFI tank #2709092
10/22/19 08:38 AM
10/22/19 08:38 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Hi,
Just wondering if anyone has used the Holley Sniper EFI tank in their E-body yet. Specifically, this P/N: https://www.holley.com/products/fuel_systems/fuel_tanks/efi_conversion_fuel_tanks/parts/19-136
The part number above is for a 70-74 Cuda. The tank is the same as for the Challenger except for the filler neck opening. So my question applies to both Cudas and Challengers.
What I want to see is how you handled the fuel line routing because the fuel pump assembly is on the top center of the tank instead of the left hand side. By putting the fuel pump assembly on the top center, isn't that going to be close to the shock crossmember? I know on a stock tank, the front of the tank is about 1 1/2 inches behind the crossmember, so how did you route your fuel lines?
I'm thinking about getting this tank but want to have a layout in my mind before buying it.
Re: E-body Holley Sniper EFI tank [Re: mrob] #2709481
10/23/19 12:01 PM
10/23/19 12:01 PM
Las Vegas, NV
Tom_440 Online work
Tom_440  Online Work
Las Vegas, NV
No personal experience here, but a "bump!"
I used the Spectra for my 73 Cuda and it fit like factory.
https://www.summitracing.com/parts/SGT-CR8CFI
Re: E-body Holley Sniper EFI tank [Re: Tom_440] #2709494
10/23/19 12:18 PM
10/23/19 12:18 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I used the tank from tanksinc.com. Exact fit and puts the intank pump where you can get to it easily. Jeff
Re: E-body Holley Sniper EFI tank [Re: 1969RR] #2709748
10/24/19 09:59 AM
10/24/19 09:59 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Me too! up
Re: E-body Holley Sniper EFI tank [Re: mrob] #2710146
10/26/19 12:45 PM
10/26/19 12:45 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Working on a B-Body where the entire Sniper setup, tank, EFI, Ignition, coil. Anyhow, the tank that Holley sent was a Tanks Inc fuel tank.
Re: E-body Holley Sniper EFI tank [Re: 451Mopar] #2710300
10/27/19 04:44 AM
10/27/19 04:44 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Doesn’t look any different to the Tanks Inc unit, I used a Tanks Inc unit but used the Fuelpuck for the pump, allows for better fittings if you want AN fittings rather than push lock fittings
Re: E-body Holley Sniper EFI tank [Re: Tom_440] #2710402
10/27/19 03:39 PM
10/27/19 03:39 PM
BDW Online content
BDW  Online Content
Used Spectra EFI tank on my Challenger.
Very happy with the results, don't understand the need to pay 2x.
Re: E-body Holley Sniper EFI tank [Re: BDW] #2710827
10/29/19 03:45 AM
10/29/19 03:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have the Holley Sniper on my sons Dart. He bought a direct fit tank for his Dart with the in tank fuel pump and it was not the Holley tank. I don't remember what brand it was but I can ask him if you like ? Ron
Re: E-body Holley Sniper EFI tank [Re: 383man] #2710891
10/29/19 10:38 AM
10/29/19 10:38 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Tanks Inc is what I used on my 68 Charger, works great.
Re: E-body Holley Sniper EFI tank [Re: BDW] #2710892
10/29/19 10:40 AM
10/29/19 10:40 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
BDW,
Thanks for the link for the Spectra tank. Had heard about those once and am glad to hear about someone that uses one. But have a question: the inlet/outlet use hose barbs. Not to sound like a stupid question, but did you use rubber hose and worm gear clamps for your connections? How is that holding up at 40+ psi?
Re: E-body Holley Sniper EFI tank [Re: mrob] #2710971
10/29/19 04:50 PM
10/29/19 04:50 PM
BDW Online content
BDW  Online Content
Yes, using EFI tubing and EFI clamps just like many OEMs use and it works fine now for 2+ years.
Ran 3 steel lines up to front of car, but the short connection from tank to line is rubber.
Re: E-body Holley Sniper EFI tank [Re: mrob] #2710987
10/29/19 06:31 PM
10/29/19 06:31 PM
AndyF Offline
AndyF  Offline
Originally Posted by mrob
BDW,
Use OEM type EFI hose and clamps and you should be good to go. Don't use old school rubber hose with worm gear clamps.
Re: E-body Holley Sniper EFI tank [Re: AndyF] #2711127
10/30/19 09:01 AM
10/30/19 09:01 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Thanks AndyF and BDW,
It's good to know that there's an alternative to the Holley Sniper (Tanks Inc) tank. Now I also know that hose barbs and EFI hose will withstand the pressure.
