E-body Holley Sniper EFI tank
#2709092
10/22/19 08:38 AM
10/22/19 08:38 AM
Posts: 198 Maryland
mrob
Maryland
Hi, Just wondering if anyone has used the Holley Sniper EFI tank in their E-body yet. Specifically, this P/N: https://www.holley.com/products/fuel_systems/fuel_tanks/efi_conversion_fuel_tanks/parts/19-136The part number above is for a 70-74 Cuda. The tank is the same as for the Challenger except for the filler neck opening. So my question applies to both Cudas and Challengers. What I want to see is how you handled the fuel line routing because the fuel pump assembly is on the top center of the tank instead of the left hand side. By putting the fuel pump assembly on the top center, isn't that going to be close to the shock crossmember? I know on a stock tank, the front of the tank is about 1 1/2 inches behind the crossmember, so how did you route your fuel lines? I'm thinking about getting this tank but want to have a layout in my mind before buying it. Thanks
Re: E-body Holley Sniper EFI tank
[Re: Tom_440]
#2710402
10/27/19 03:39 PM
10/27/19 03:39 PM
Posts: 4,681 Florida
BDW
Used Spectra EFI tank on my Challenger. Very happy with the results, don't understand the need to pay 2x.
[Re: 383man]
#2710891
10/29/19 10:38 AM
10/29/19 10:38 AM
Posts: 2,843 Pattison Texas
CSK
Pattison Texas
Tanks Inc is what I used on my 68 Charger, works great.
[Re: mrob]
#2710971
10/29/19 04:50 PM
10/29/19 04:50 PM
BDW
Yes, using EFI tubing and EFI clamps just like many OEMs use and it works fine now for 2+ years. Ran 3 steel lines up to front of car, but the short connection from tank to line is rubber.
[Re: mrob]
#2710987
10/29/19 06:31 PM
10/29/19 06:31 PM
Posts: 30,947 Oregon
AndyF
BDW,
Thanks for the link for the Spectra tank. Had heard about those once and am glad to hear about someone that uses one. But have a question: the inlet/outlet use hose barbs. Not to sound like a stupid question, but did you use rubber hose and worm gear clamps for your connections? How is that holding up at 40+ psi? Use OEM type EFI hose and clamps and you should be good to go. Don't use old school rubber hose with worm gear clamps.
