Divorced transfer case U-joints? #2710154
10/26/19 01:26 PM
10/26/19 01:26 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Hi all, does anyone know what the u-joints are on the driveshaft between the tranny and transfer case are for a divorced setup? Specifically I'm wondering for a 73 W200 with a 4-speed and a NP205.
Rock Auto says its a 7260 but that seems kind of small to me.
Thanks,
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Divorced transfer case U-joints? [Re: blown340] #2710217
10/26/19 06:18 PM
10/26/19 06:18 PM
Alberta
440_Offroader Offline
Alberta
I don't know which u-joints you need, but I'd measure them and cross reference them to know for sure. I think the 7260 measure at 2 1/8".
Re: Divorced transfer case U-joints? [Re: 440_Offroader] #2710243
10/26/19 07:52 PM
10/26/19 07:52 PM
Guitar Jones Offline
Just looking at the ones in my W200 they look like the small 7260 joints but i haven't pulled them out or measured them yet.
Re: Divorced transfer case U-joints? [Re: 440_Offroader] #2710288
10/27/19 12:49 AM
10/27/19 12:49 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Been a few years since I replaced mine. 7260 sounds familiar... Here are dimensions for 7260’s and a Spec page from 1974 Dodge Trucks Service Manual.
Re: Divorced transfer case U-joints? [Re: D_C] #2710291
10/27/19 01:09 AM
10/27/19 01:09 AM
D_C Offline
D_C  Offline
Below is a link to U-Joint Dimensions
U-Joint Identification Dimensions
Re: Divorced transfer case U-joints? [Re: D_C] #2710347
10/27/19 11:16 AM
10/27/19 11:16 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thanks everyone, I measured them as suggested and they are 7260's.
-Jon
Re: Divorced transfer case U-joints? [Re: blown340] #2710365
10/27/19 12:39 PM
10/27/19 12:39 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
My 73 W200 360, 435, 205 has the 7260 joints. I always thought they are kinda small for a 3/4T truck.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Divorced transfer case U-joints? [Re: moparmarks] #2710488
10/27/19 10:09 PM
10/27/19 10:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My experience with the 4x4 trucks is that the u joints, if properly cared for, cause about the least amount of problems in the entire 4x4 system. Those small joints might look a bit strange, especially with some of the driveshafts, but they must be some pretty good stuff. The Mopar designer's got that part right. Gene
Re: Divorced transfer case U-joints? [Re: poorboy] #2711943
11/01/19 05:56 PM
11/01/19 05:56 PM
south louisiana
lowell66dart Offline
south louisiana
Buy the good ones with that you lube from the cap end. I think they have a x after the number.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Divorced transfer case U-joints? [Re: lowell66dart] #2711994
11/01/19 10:30 PM
11/01/19 10:30 PM
U joints with hollow grease passages are not as strong as those without those passages work twocents
Take it from a old drag racer that had to learn that the hard way by breaking more than one greaseable U joint whiney wrench shruggy
Solid H.D. units( I prefer the Neapco solid H.D joints) are WAY better up
