correct factory brand tires for 1969 RR F70-14 #2709666
10/23/19 09:40 PM
10/23/19 09:40 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
What would have been the original tires installed at the factory for a 69 Roadrunner spo date of Jan of 69. The car currently has white wall radials on it and I'd like to put the redline bias plys on there I can afford it. I'm just not sure if it was Firestones or Goodyears in 69.
inherited a 69 roadrunner from my grand pop.
Re: correct factory brand tires for 1969 RR F70-14 [Re: fuelishnsilly] #2709744
10/24/19 09:53 AM
10/24/19 09:53 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Majority were Goodyears
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: correct factory brand tires for 1969 RR F70-14 [Re: MOPARMIKE69] #2709863
10/24/19 07:38 PM
10/24/19 07:38 PM
BlueRacer69 Offline
BlueRacer69  Offline
Was your Roadrunner a 383 car? If yes, then I think the factory tire was a Firestone Wide Oval, size F70-14's. Could be a redline or a whiteline.
Re: correct factory brand tires for 1969 RR F70-14 [Re: BlueRacer69] #2709872
10/24/19 08:16 PM
10/24/19 08:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I always saw Goodyear Speedway Wide Tread F70s on them in '68 & '69, as far as redlines go.
Never saw anything different.
All the original spare tires in my cars & buddies' cars were the Goodyears.
Not to say another brand couldn't happen, but I'm referring to literally dozens of new Road Runners & GTXs I saw in SoCal.
Re: correct factory brand tires for 1969 RR F70-14 [Re: topside] #2709877
10/24/19 08:48 PM
10/24/19 08:48 PM
BlueRacer69 Offline
BlueRacer69  Offline
Could it be a plant thing or brand thing? My new 69 Dart GTS 383 car came from the factory with Firestone Redlines. And it had about the same build date as his RR. Maybe Plymouth and Dodge used different brands of tires. shruggy
Re: correct factory brand tires for 1969 RR F70-14 [Re: BlueRacer69] #2709903
10/24/19 10:42 PM
10/24/19 10:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
May have been a size thing; Dart GTS & Swinger340 got D70 or E70, if I recall correctly.
Pretty sure at least one if not both of my '68 Chargers had F70-14 Goodyear spares, presumed original, I was 2nd owner of both.
Can't recall what another buddy's '68 SuperBee had.
Could even be Firestone was a back-up supplier.
Just reporting what I've seen, though I don't know where the new cars @ dealerships I saw were built.
All of my 68 & 69 RRs were St Louis cars except for 1 L.A.car, and my current Lynch Road car.
Re: correct factory brand tires for 1969 RR F70-14 [Re: topside] #2709905
10/24/19 10:48 PM
10/24/19 10:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think its a plant as well as build date thing.
A 1969 Charger a couple years ago I did was a July 69 St Louis build and it had its original spare. F70-14 Good year Speedway redline
A friends 1969 Dart 383 car has its original spare, E70-14 Firestone redline ( sorry, I dont know build date or plant )
Re: correct factory brand tires for 1969 RR F70-14 [Re: gtx6970] #2709930
10/25/19 08:06 AM
10/25/19 08:06 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
GY Speedway redlines were usually earlier in 1969 on GTX's and then they went on to GY PolyGlas redlines from what I remember when I was looking into this years back.
Ron
Re: correct factory brand tires for 1969 RR F70-14 [Re: RJS] #2710037
10/25/19 07:19 PM
10/25/19 07:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A-bodies & B-bodies had many differences - it only confuses the question
1969 Road Runner w/383
STANDARD tire was T83 F70-14 Goodyear SPEEDWAY red streak ***
OPTIONAL "no-charge" tire was T82 F70-14 Goodyear SPEEDWAY white streak ***
OPTIONAL $$ tire was T85 F70-14 Goodyear POLYGLAS red streak
included with the OPTIONAL $$ "spring special" A14/A15 package - T87 F70-14 Goodyear POLYGLAS w/RWL (OPTIONAL "no-charge" tire was T85 F70-14 Goodyear POLYGLAS red streak)
*** Firestone WIDE OVAL Deluxe Champion (non-fiberglass belted) tires were used at some plants/during some dates - these tires are NOT available in reproduction
the most correct without a broadcast sheet no-brainer is - OPTIONAL $$ tire was T85 F70-14 Goodyear POLYGLAS red streak - ALL year, ALL plants, ALL OPTIONS available w/383
Re: correct factory brand tires for 1969 RR F70-14 [Re: 6bblgt] #2710045
10/25/19 08:07 PM
10/25/19 08:07 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
My Dec 68 build 69 roadrunner that I’m doing had Goodyear Speedways originally. I would speculate yours would as well, as many I’ve documented have had, even past January.
Re: correct factory brand tires for 1969 RR F70-14 [Re: Paul Jacobs] #2710065
10/25/19 09:37 PM
10/25/19 09:37 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, the STANDARD "red streak" tire was the most common
1969 Road Runner:
T82 ~ 24% white
T83 ~ 54% red
T85 ~ 9% fiberglass red
T87 ~ 8% fiberglass RWL
Re: correct factory brand tires for 1969 RR F70-14 [Re: Paul Jacobs] #2710068
10/25/19 10:18 PM
10/25/19 10:18 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
[quote=Paul Jacobs]My Dec 68 build 69 roadrunner that I’m doing had Goodyear Speedways originally. I would speculate yours would as well, as many I’ve documented have had, even past January.
My BO8 69 RR St Louis car came new with Goodyear Speedways, I still have the car along with the original spare.
Re: correct factory brand tires for 1969 RR F70-14 [Re: 6bblgt] #2710228
10/26/19 07:16 PM
10/26/19 07:16 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
my june RR had F-70X14 white letter polyglass on road wheels with beauty rings.
Re: correct factory brand tires for 1969 RR F70-14 [Re: sixbbl 69] #2710237
10/26/19 07:41 PM
10/26/19 07:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
a friend's former "frost green metallic" (F3), green bench seat (H2G), w/red pinstripes (V7R) - RR hardtop (RM23)
