Running 2 Alternators simultanously? #2709708
10/24/19 07:04 AM
10/24/19 07:04 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Is it possible?
Are there problems when doing so?
Would they both charge at full capacity if demand required?
I'm thinking a smallish engine driven alternator, 40-50 amps, and a driveshaft driven larger alternator 60-80 amps that connects to trunk mounted battery.
This configuration;on would be appealing to me if they would "get along".
Re: Running 2 Alternators simultanously? [Re: jcc] #2709709
10/24/19 07:17 AM
10/24/19 07:17 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Assuming completely separate systems, then yes, if the same system then I'm not sure your wiring would like it and I cant imagine how it would be beneficial. What is the purpose?
Careful, your character's showing!
Re: Running 2 Alternators simultanously? [Re: jcc] #2709710
10/24/19 07:19 AM
10/24/19 07:19 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are planning to run them in parallel or have them support different loads?
Re: Running 2 Alternators simultanously? [Re: Sniper] #2709711
10/24/19 07:25 AM
10/24/19 07:25 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
They would work just fine if they are both fed the same sense voltage at the regulator.
...but why?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Running 2 Alternators simultanously? [Re: GoodysGotaCuda] #2709715
10/24/19 07:42 AM
10/24/19 07:42 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I'm going IRS, so a driveshaft rear mounted Alternator is relatively easy.
Not sure about occasional road splash water
I like my weight low, and rearward.
An engine mounted alternator only needs min output when at rest/idle, when moving and the driveshaft alt is in play, demand is higher and some recharge is likely needed depending on idle time.
Car would see minimum street use vs track car.
Charging systems would be parallel.
Re: Running 2 Alternators simultanously? [Re: jcc] #2709720
10/24/19 08:08 AM
10/24/19 08:08 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
System would probably be similar to a boat with twin engines. There is a battery isolator/distributor that both alternators feed into. The battery or batteries are fed from that. Its basically a set of electrical check valves to keep current from going places you don't want it to.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Running 2 Alternators simultanously? [Re: RoadRunner] #2709722
10/24/19 08:26 AM
10/24/19 08:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Some new 6.4 Ram trucks run 2 alternators.
Doug
Re: Running 2 Alternators simultanously? [Re: dvw] #2709751
10/24/19 10:17 AM
10/24/19 10:17 AM
moparx Offline
moparx  Offline
Doug
i was just going to say the same thing.
my one buddy has one of those trucks, but i never really looked at how those are wired up, or inquired as to why they were built that way.
beer
Re: Running 2 Alternators simultanously? [Re: moparx] #2709817
10/24/19 03:55 PM
10/24/19 03:55 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
If the alternators have identical electrical characteristics then it would work well. But one will hog a little bit more load than the other depending on the characteristics of the alternators. Probably not an issue if you buy identical alternators.
I would need to think about it some, but I believe that running both alternators off of a single voltage regulator would be best although I don't know if the regulator is regulating field voltage or current .
Re: Running 2 Alternators simultanously? [Re: jcc] #2709851
10/24/19 07:04 PM
10/24/19 07:04 PM
mopar346 Offline
mopar346  Offline
Originally Posted by jcc
An engine mounted alternator only needs min output when at rest/idle, …..
Unless I'm missing something or thinking way wrong, you'd have to idle for a long time to drain the battery enough to matter. Even with the radio, AC and any other accessories a car can run a long time on a fully charged battery. I drove a car for several weeks as a teenager that couldn't afford and alternator by charging the battery every night, it was 25 miles one way to work, then I learned to build alternators. grin
Re: Running 2 Alternators simultanously? [Re: mopar346] #2709891
10/24/19 09:50 PM
10/24/19 09:50 PM
Pittsburgh
ratty Offline
ratty  Offline
Pittsburgh
why on earth? ....not trying to be rude, but... K.I.S.S
Hey buddy, is there a 440 in your Coronet 440? No, it's just a little 318.... (sound of crickets)...
Re: Running 2 Alternators simultanously? [Re: ratty] #2709901
10/24/19 10:19 PM
10/24/19 10:19 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Fair enough, but sometimes " better" trumps "simple", but only one way to find out. biggrin
Re: Running 2 Alternators simultanously? [Re: jcc] #2709911
10/24/19 11:56 PM
10/24/19 11:56 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Two alternators? How cute. How about twelve? Bass dyno dudes do it all the time, along with service vehicles. There are companies that make kits for all newer American trucks and vans, along with many cars. There are places that will make you custom brackets for dual 260amp alternators. How much power do you need?
Dual Alternator Kits
12 Alternators, 20 Batteries, 6 15"S... Marquis Self's BASS Cutlass FLEXING!!
Re: Running 2 Alternators simultanously? [Re: 375inStroke] #2709916
10/25/19 12:48 AM
10/25/19 12:48 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
haha
Why do they alway do this to crapboxes?
I think i agree with the KISS...
One or the other, the diff mount is a good idea if your car in the limits of weight distribution/reduction like FMJ's
Put the money towards one or two lipo batteries and call it done
Re: Running 2 Alternators simultanously? [Re: Alchemi] #2709924
10/25/19 06:37 AM
10/25/19 06:37 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Why not just one high output alternator?
Re: Running 2 Alternators simultanously? [Re: 70HemiGTX] #2709955
10/25/19 10:29 AM
10/25/19 10:29 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I have found some Marine regulators (Balmar) that appear to be a solution, ie two engines for one battery, which I think represents my situation, different speeds, etc. They appear to be robust for weather, small. and reasonably lightweight, but being marine slightly costly and hampering bang for buck on the idea.
Re: Running 2 Alternators simultanously? [Re: 375inStroke] #2710296
10/27/19 01:41 AM
10/27/19 01:41 AM
hooziewhatsit Offline
eek laugh2
And I was just going to mention an ancient video of a Ham radio guy that had ~8 alternators set up to drive the radio. When he keyed up, he'd have to hit the nitrous otherwise the load would stall the engine laugh2
Re: Running 2 Alternators simultanously? [Re: 70HemiGTX] #2710462
10/27/19 08:36 PM
10/27/19 08:36 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Best solution.
