Running 2 Alternators simultanously?
#2709708
10/24/19 07:04 AM
10/24/19 07:04 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Is it possible? Are there problems when doing so? Would they both charge at full capacity if demand required? I'm thinking a smallish engine driven alternator, 40-50 amps, and a driveshaft driven larger alternator 60-80 amps that connects to trunk mounted battery. This configuration;on would be appealing to me if they would "get along".
Re: Running 2 Alternators simultanously?
[Re: jcc]
#2709709
10/24/19 07:17 AM
10/24/19 07:17 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Assuming completely separate systems, then yes, if the same system then I'm not sure your wiring would like it and I cant imagine how it would be beneficial. What is the purpose?
Careful, your character's showing!
[Re: GoodysGotaCuda]
#2709715
10/24/19 07:42 AM
10/24/19 07:42 AM
jcc
Bitopia
I'm going IRS, so a driveshaft rear mounted Alternator is relatively easy. Not sure about occasional road splash water I like my weight low, and rearward. An engine mounted alternator only needs min output when at rest/idle, when moving and the driveshaft alt is in play, demand is higher and some recharge is likely needed depending on idle time. Car would see minimum street use vs track car. Charging systems would be parallel.
[Re: jcc]
#2709720
10/24/19 08:08 AM
10/24/19 08:08 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
System would probably be similar to a boat with twin engines. There is a battery isolator/distributor that both alternators feed into. The battery or batteries are fed from that. Its basically a set of electrical check valves to keep current from going places you don't want it to.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: dvw]
#2709751
10/24/19 10:17 AM
10/24/19 10:17 AM
Posts: 19,355 north of coder
moparx
Some new 6.4 Ram trucks run 2 alternators. Doug i was just going to say the same thing. my one buddy has one of those trucks, but i never really looked at how those are wired up, or inquired as to why they were built that way.
[Re: moparx]
#2709817
10/24/19 03:55 PM
10/24/19 03:55 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
If the alternators have identical electrical characteristics then it would work well. But one will hog a little bit more load than the other depending on the characteristics of the alternators. Probably not an issue if you buy identical alternators.
I would need to think about it some, but I believe that running both alternators off of a single voltage regulator would be best although I don't know if the regulator is regulating field voltage or current .
[Re: jcc]
#2709851
10/24/19 07:04 PM
10/24/19 07:04 PM
mopar346
An engine mounted alternator only needs min output when at rest/idle, …..
Unless I'm missing something or thinking way wrong, you'd have to idle for a long time to drain the battery enough to matter. Even with the radio, AC and any other accessories a car can run a long time on a fully charged battery. I drove a car for several weeks as a teenager that couldn't afford and alternator by charging the battery every night, it was 25 miles one way to work, then I learned to build alternators.
[Re: mopar346]
#2709891
10/24/19 09:50 PM
10/24/19 09:50 PM
Posts: 6 Pittsburgh
ratty
Pittsburgh
why on earth? ....not trying to be rude, but... K.I.S.S
Hey buddy, is there a 440 in your Coronet 440? No, it's just a little 318.... (sound of crickets)...
[Re: 375inStroke]
#2709916
10/25/19 12:48 AM
10/25/19 12:48 AM
Posts: 234 Brisvegas, Australia
Alchemi
Why do they alway do this to crapboxes? I think i agree with the KISS... One or the other, the diff mount is a good idea if your car in the limits of weight distribution/reduction like FMJ's Put the money towards one or two lipo batteries and call it done
[Re: 70HemiGTX]
#2709955
10/25/19 10:29 AM
10/25/19 10:29 AM
jcc
Bitopia
I have found some Marine regulators (Balmar) that appear to be a solution, ie two engines for one battery, which I think represents my situation, different speeds, etc. They appear to be robust for weather, small. and reasonably lightweight, but being marine slightly costly and hampering bang for buck on the idea.
