Page 1 of 3 1 2 3
Brett miller and the mw victor project #2708454
10/20/19 07:49 AM
10/20/19 07:49 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Digging for info on here with the search option, I found an old post where Brett chimed in and stated he was working on a pair of mw Victor's that would support 1000hp when done. He posted a couple pics as well, but that's all I found. Anyone here know if he ever finished them and the out come?
Re: Brett miller and the mw victor project [Re: mopar dave] #2708478
10/20/19 09:26 AM
10/20/19 09:26 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Not sure about that, but I know it can be done. We did a 540 a couple years ago that made a grand on the dyno. Broke everything in the car it went in but eventually ran the track numbers to back it up. I am sure Brett could get the same or better results.
Todd
Re: Brett miller and the mw victor project [Re: sasquatch] #2708508
10/20/19 10:44 AM
10/20/19 10:44 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Todd,
I think Brett's project was "small block" based. I could be way off but I think it was a Ritter block and was about 440 cubic inch and made high 900s in HP but had more left.
Both Brett and the engines owner are on here so hopefully they will be able to give facts rather than recollections.
Bill
Re: Brett miller and the mw victor project [Re: 340Cuda] #2708514
10/20/19 11:00 AM
10/20/19 11:00 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
is that the engine in shiloh davies's dart ?
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Brett miller and the mw victor project [Re: Ray408G3Hemi] #2708518
10/20/19 11:11 AM
10/20/19 11:11 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
No, Shiloh's is a early Ritter block with W8 heads
"Just a Bracket car dressed up like a streetcar"
Re: Brett miller and the mw victor project [Re: mopar dave] #2708527
10/20/19 11:34 AM
10/20/19 11:34 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Small block not big block
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: Brett miller and the mw victor project [Re: mopar dave] #2708529
10/20/19 11:41 AM
10/20/19 11:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yes, Brett took a crack at a BB MW Victor. As I recall, he did one port and decided it wasn't worth pursuing further. (EDIT: This is my a$$umption, but Brett could provide more details if he happens to see this thread). The numbers looked good, but weren't much different than what Chad Speier advertised for his CNC MW Victor program.
In general, the MW Victors CNC programs I've seen advertised (Speier, BES, Modern) all end up with big runner volumes for the sake of getting big flow #s at .700-.900" lift. Below that, I don't recall them being any better -- some not even as good -- as my PRH-ported standard Victors. IMO, those heads are ALL going to exhibit the same thing you're experiencing now with the Hughes heads, if you don't tailor the rest of the combination to work with them.
Somebody had an EMC (2017 or 2018?) entry with the BES heads that was IMO a big underperformer. When I read the details of the build and saw the heads that were used, it was a no-brainer to me why.
Dave - What happened to replicating what worked when YOUR heads ran 9s? You're getting so wrapped around the axle over this it's painful to read each new thread you start.
Re: Brett miller and the mw victor project [Re: BradH] #2708547
10/20/19 01:10 PM
10/20/19 01:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Apparently I don’t know the secret password for searching for any year Engine Masters final results/standings/order.
Got a link to the specifics on that Victor headed build?
Also, I may not be remembering it right, but....... I thought Brett started with a std port head....... and the port configuration he came up with was something that would have also required a heavily modified/custom intake manifold.
He did not end up with a traditional MW type of port opening.
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708548
10/20/19 01:12 PM
10/20/19 01:12 PM
The Great White North
RAMM Offline
RAMM  Offline
It was bright green and it did underperform. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708550
10/20/19 01:22 PM
10/20/19 01:22 PM
BradH Offline
BradH  Offline
Magazine
Re: Brett miller and the mw victor project [Re: BradH] #2708551
10/20/19 01:23 PM
10/20/19 01:23 PM
BradH Offline
BradH  Offline
Pooch #1
Re: Brett miller and the mw victor project [Re: RAMM] #2708552
10/20/19 01:24 PM
10/20/19 01:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
BES numbers.......
Not that it really means anything, but the picture they show for this head, which looks like it’s right out of the Ede catalog, is of a std port 1st gen head.
At 335cc....... it would likely be a MW Head.
Re: Brett miller and the mw victor project [Re: BradH] #2708554
10/20/19 01:24 PM
10/20/19 01:24 PM
BradH Offline
BradH  Offline
Pooch #2
Re: Brett miller and the mw victor project [Re: BradH] #2708555
10/20/19 01:28 PM
10/20/19 01:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
Huh...... were the rules weird for that class that year?
Re: Brett miller and the mw victor project [Re: BradH] #2708556
10/20/19 01:29 PM
10/20/19 01:29 PM
BradH Offline
BradH  Offline
Maybe since I have never entered one of those engine competitions I should just keep my mouth shut... but IMO the two RB 452 collaborations that Dwayne and I have worked together on over the years have done better with less.
EDIT: As I mentioned below, I don't know how these scores are calculated; maybe my junk wouldn't place well in an event like this. But the HP & torque for the builds above still look like underachievers to me.
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708558
10/20/19 01:30 PM
10/20/19 01:30 PM
BradH Offline
BradH  Offline
Let's ask Jesse, since he had entered a 354 Gen IIII Hemi in the same class. shruggy
Re: Brett miller and the mw victor project [Re: BradH] #2708562
10/20/19 01:35 PM
10/20/19 01:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
I see the one entry is listed as using a roller cam....... so it’s not flat tappet only.
Maybe a low-ish CR rule?
4150 carb only?
Small header collectors?
Low-ish operating range?
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708563
10/20/19 01:35 PM
10/20/19 01:35 PM
BradH Offline
BradH  Offline
I don't remember what he started with, but the end result was, as you stated, not a "traditional MW type of port opening."
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708566
10/20/19 01:40 PM
10/20/19 01:40 PM
BradH Offline
BradH  Offline
4150 carb only?
Top 3 in the class:
EDIT: Notes for 1st place say 11.3 CR and 4th place say 11.7 CR...
And I have NO idea how they score these things.
Re: Brett miller and the mw victor project [Re: BradH] #2708575
10/20/19 02:05 PM
10/20/19 02:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
https://board.moparts.org/ubbthread...-bb-victor-heads-update.html#Post2281884
I wonder if he ever CC’d that port?
SRH used to have the flow data for his CNC job on the website, but I couldn’t find it today.
Page 1 of 3 1 2 3
