OE Correct 1/4" Return Fuel Hose Clamps #2707280
10/16/19 01:46 PM
10/16/19 01:46 PM
White Plains, NY
VCODE Online boogie OP
VCODE  Online Boogie OP
White Plains, NY
I am looking for original pictures or documentation on the OE correct 1/4" return fuel hose clamps that are used on a 70 440 Challenger. Does the vapor separator end 1/4" hose use the red spring type clamp or the keystone type clamp. Does the other end that connects the rubber hose to the steel return line get the red spring type clamp or keystone type clamp.
I have see them both ways on restored cars.
Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707289
10/16/19 02:47 PM
10/16/19 02:47 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Frank Badalson sells a kit with the correct hoses and clamps. They are Keystone clamps. I have confidence that Frank should know what is correct.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: MOPARMIKE69] #2707292
10/16/19 03:03 PM
10/16/19 03:03 PM
White Plains, NY
White Plains, NY
I talk with Frank, have not asked him about this yet. One of the engines he did had a red spring clamp on it. Why I ask first is I saw on Dave Walden's Challenger which had a Keystone.
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: MOPARMIKE69] #2707293
10/16/19 03:07 PM
10/16/19 03:07 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have the correct OE style Oetiker clamps for both 5/16 & 3/8 fuel line if you need them. $1 each. Let me know if I can help.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: 70gtx440dana] #2707298
10/16/19 03:26 PM
10/16/19 03:26 PM
White Plains, NY
White Plains, NY
Thanks, I have the correct clamps for all sizes, just trying to find out 100% on which one to use on 1/4" return hose.
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707299
10/16/19 03:28 PM
10/16/19 03:28 PM
Lansing, MI
Lansing, MI
#123 is the correct for 1/4"
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: 70gtx440dana] #2707304
10/16/19 03:48 PM
10/16/19 03:48 PM
White Plains, NY
White Plains, NY
My 1/4" keystone clamps are stamped 505
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707319
10/16/19 04:46 PM
10/16/19 04:46 PM
Lansing, MI
Lansing, MI
#123 is the Oetiker brand part number. #505 must be another manufacturer.
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707370
10/16/19 07:59 PM
10/16/19 07:59 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Bob,
Im 99% sure even the return line takes the keystone clamps. Should be yellow zinc dichromate finish. Sorry ,,dont remember the number stamped on them
Clear zinc on the 5/16" and black zinc on the clamps for the 3/8" hose
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: gtx6970] #2707505
10/17/19 07:49 AM
10/17/19 07:49 AM
White Plains, NY
White Plains, NY
Thanks Bill, I have all or the correct keystone clamps with correct plating.
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707523
10/17/19 09:16 AM
10/17/19 09:16 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I remember the article by Frank and always followed that practice with the red spring clamp. Has his view on this changed???
Ron
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: RJS] #2707550
10/17/19 10:07 AM
10/17/19 10:07 AM
White Plains, NY
White Plains, NY
Ron
Ron, Are you saying that Frank said red spring clamp on vapor separator end.
Thanks Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707754
10/17/19 05:41 PM
10/17/19 05:41 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ron
Thanks Bob
Yes exactly what I am saying. There was an article in one of the major Mopar mags. with an interview including pictures. If may have also been in one of the Mr. Norms pamphlets that were around years back. So after seeing/reading Frank's direction I always followed it. Is it now considered just one of the ways it's done or a mistake????
Ron
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: RJS] #2707757
10/17/19 05:51 PM
10/17/19 05:51 PM
White Plains, NY
White Plains, NY
Ron
Thanks Bob
Ron
Thanks Ron,I confirmed with Frank. Red clamp is correct
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2707837
10/17/19 08:31 PM
10/17/19 08:31 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
OK cool so at least my memory is still intact. I always felt that Frank is one of the best people to take advise from over the years.
Ron
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2708014
10/18/19 11:07 AM
10/18/19 11:07 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I apologize for straying a little off the subject here. But is there a better set of crimping pliers than what I have? And can anyone provide some tips on how to make a nice triangular shaped crimp like the factory (see image below of KV hose)? I am inconsistent on my crimping. Some come out triangular and some are shaped like tear drops. I have been using Oetiker branded clamps.
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: David1971] #2708261
10/19/19 08:02 AM
10/19/19 08:02 AM
White Plains, NY
White Plains, NY
These work good on the keystone clamps. You can see the tool keep the tops flat.
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: David1971] #2708266
10/19/19 08:13 AM
10/19/19 08:13 AM
White Plains, NY
White Plains, NY
While at it. Has anyone see this. Original keystone clamp from the factory. Look at the crimp. We are all trying to keep the top flat, and look what I found on my 70 Challenger
Bob
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2708295
10/19/19 10:57 AM
10/19/19 10:57 AM
It's a dry heat
It's a dry heat
Bob
same ones Ive always used. basically called CV boot clamp pliers
Re: OE Correct 1/4" Return Fuel Hose Clamps [Re: VCODE] #2708307
10/19/19 11:38 AM
10/19/19 11:38 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
Bob
Thanks Bob. I bought this one off of Ebay. It looks like an older version of the Model 424
