OE Correct 1/4" Return Fuel Hose Clamps
#2707280
10/16/19 01:46 PM
10/16/19 01:46 PM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
I am looking for original pictures or documentation on the OE correct 1/4" return fuel hose clamps that are used on a 70 440 Challenger. Does the vapor separator end 1/4" hose use the red spring type clamp or the keystone type clamp. Does the other end that connects the rubber hose to the steel return line get the red spring type clamp or keystone type clamp. I have see them both ways on restored cars. Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: OE Correct 1/4" Return Fuel Hose Clamps
[Re: VCODE]
#2707289
10/16/19 02:47 PM
10/16/19 02:47 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Frank Badalson sells a kit with the correct hoses and clamps. They are Keystone clamps. I have confidence that Frank should know what is correct.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#2707292
10/16/19 03:03 PM
10/16/19 03:03 PM
VCODE
White Plains, NY
I talk with Frank, have not asked him about this yet. One of the engines he did had a red spring clamp on it. Why I ask first is I saw on Dave Walden's Challenger which had a Keystone. Bob
[Re: MOPARMIKE69]
#2707293
10/16/19 03:07 PM
10/16/19 03:07 PM
Posts: 3,518 Lansing, MI
70gtx440dana
Lansing, MI
I have the correct OE style Oetiker clamps for both 5/16 & 3/8 fuel line if you need them. $1 each. Let me know if I can help.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2707298
10/16/19 03:26 PM
10/16/19 03:26 PM
VCODE
White Plains, NY
I have the correct OE style Oetiker clamps for both 5/16 & 3/8 fuel line if you need them. $1 each. Let me know if I can help. Thanks, I have the correct clamps for all sizes, just trying to find out 100% on which one to use on 1/4" return hose. Bob
[Re: VCODE]
#2707299
10/16/19 03:28 PM
10/16/19 03:28 PM
70gtx440dana
Lansing, MI
#123 is the correct for 1/4"
[Re: 70gtx440dana]
#2707304
10/16/19 03:48 PM
10/16/19 03:48 PM
VCODE
White Plains, NY
#123 is the correct for 1/4" My 1/4" keystone clamps are stamped 505
[Re: VCODE]
#2707319
10/16/19 04:46 PM
10/16/19 04:46 PM
70gtx440dana
Lansing, MI
#123 is the Oetiker brand part number. #505 must be another manufacturer.
[Re: gtx6970]
#2707505
10/17/19 07:49 AM
10/17/19 07:49 AM
VCODE
White Plains, NY
Thanks Bill, I have all or the correct keystone clamps with correct plating. Bob
[Re: RJS]
#2707550
10/17/19 10:07 AM
10/17/19 10:07 AM
VCODE
White Plains, NY
I remember the article by Frank and always followed that practice with the red spring clamp. Has his view on this changed??? Ron Ron, Are you saying that Frank said red spring clamp on vapor separator end. Thanks Bob
[Re: VCODE]
#2707754
10/17/19 05:41 PM
10/17/19 05:41 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I remember the article by Frank and always followed that practice with the red spring clamp. Has his view on this changed??? Ron Ron, Are you saying that Frank said red spring clamp on vapor separator end. Thanks Bob Yes exactly what I am saying. There was an article in one of the major Mopar mags. with an interview including pictures. If may have also been in one of the Mr. Norms pamphlets that were around years back. So after seeing/reading Frank's direction I always followed it. Is it now considered just one of the ways it's done or a mistake???? Ron
[Re: RJS]
#2707757
10/17/19 05:51 PM
10/17/19 05:51 PM
VCODE
White Plains, NY
I remember the article by Frank and always followed that practice with the red spring clamp. Has his view on this changed??? Ron Ron, Are you saying that Frank said red spring clamp on vapor separator end. Thanks Bob Yes exactly what I am saying. There was an article in one of the major Mopar mags. with an interview including pictures. If may have also been in one of the Mr. Norms pamphlets that were around years back. So after seeing/reading Frank's direction I always followed it. Is it now considered just one of the ways it's done or a mistake???? Ron Thanks Ron,I confirmed with Frank. Red clamp is correct Bob
[Re: David1971]
#2708261
10/19/19 08:02 AM
10/19/19 08:02 AM
VCODE
White Plains, NY
I apologize for straying a little off the subject here. But is there a better set of crimping pliers than what I have? And can anyone provide some tips on how to make a nice triangular shaped crimp like the factory (see image below of KV hose)? I am inconsistent on my crimping. Some come out triangular and some are shaped like tear drops. I have been using Oetiker branded clamps. These work good on the keystone clamps. You can see the tool keep the tops flat. Bob
[Re: David1971]
#2708266
10/19/19 08:13 AM
10/19/19 08:13 AM
VCODE
White Plains, NY
While at it. Has anyone see this. Original keystone clamp from the factory. Look at the crimp. We are all trying to keep the top flat, and look what I found on my 70 Challenger Bob
[Re: VCODE]
#2708295
10/19/19 10:57 AM
10/19/19 10:57 AM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
I apologize for straying a little off the subject here. But is there a better set of crimping pliers than what I have? And can anyone provide some tips on how to make a nice triangular shaped crimp like the factory (see image below of KV hose)? I am inconsistent on my crimping. Some come out triangular and some are shaped like tear drops. I have been using Oetiker branded clamps. These work good on the keystone clamps. You can see the tool keep the tops flat. Bob same ones Ive always used. basically called CV boot clamp pliers
[Re: VCODE]
#2708307
10/19/19 11:38 AM
10/19/19 11:38 AM
Posts: 203 Alabama
David1971
Alabama
I apologize for straying a little off the subject here. But is there a better set of crimping pliers than what I have? And can anyone provide some tips on how to make a nice triangular shaped crimp like the factory (see image below of KV hose)? I am inconsistent on my crimping. Some come out triangular and some are shaped like tear drops. I have been using Oetiker branded clamps. These work good on the keystone clamps. You can see the tool keep the tops flat. Bob Thanks Bob. I bought this one off of Ebay. It looks like an older version of the Model 424
