Page 3 of 5 1 2 3 4 5
Re: TF270 accessories [Re: Cab_Burge] #2706584
10/14/19 02:42 AM
10/14/19 02:42 AM
Canada
MestocX Offline
MestocX  Offline
Canada
My apologies it was installed -2 ill make the correction in the post
The short block was originally installed in a 3300 pound Ebody with 2.19 valve E heads that made 688 with the same camshaft.
Used a 727 with a brake with a 5000 10 inch vert ran consistent 10.10s with a 4150 1050 with the same cam. With the lighter car engine builder decided to retard the cam for the glide and the looser converter im guessing. Power range was 5000-6500 but when through at 7100. Standard port head was tapped out after 6500 with that particular combination.
I will attach the cam card
Re: TF270 accessories [Re: MestocX] #2706671
10/14/19 11:51 AM
10/14/19 11:51 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thanks for that combo and your experience's with it. I'll surprised with the 5* timing differences with the changes, but with same 4.25 stroke and heads. I just called Comp Cams to get a better understanding of the cam I have in it. Dwayne says it has a mild lobe, Comp says its a 32.7 on a scale of 25-50 for intensity. They also tell me it has 4* ground in and should be dot to dot to have the proper advance set. I degree'd it to 105.5, but i'm pretty sure it was not dot to dot at the 105.5* setting. Maybe I have the cam 4* too far advanced? Don't know, but I will pull the cover and check it and get some springs off for checking as well. I thought it was odd i have .160 pv clearance on int. and .230 on ex. Not sure,but that could be an indication too far advanced.
Still playing with the carb. Dom told me to drill the pvcr's a little bigger .080" to help get up on the power quicker. I did this and it worked. Hits the vert hard and quicker blowing the tires off thru 1st and 2nd til I lift or shift. This is with the new M/T R radials that really stick. Tach goes right to 68-6900rpm and lays there til lift or shift. That was a good tweak. Still fat on top and expected with the bigger pvcr's, so will try a .029HS bleed and also square jetting today. No real data, just street tuning for now. Timing at 37* total now and engine does not skip a beat and never has.
Re: TF270 accessories [Re: mopar dave] #2706705
10/14/19 01:21 PM
10/14/19 01:21 PM
Canada
MestocX Offline
MestocX  Offline
Canada
From what i've seen most mopars like 38* timing the trickflow heads seem to like 34-36 degrees maybe because of the better combustion chamber. Also the pistons in our combo are domed with a 70. Head gasket so im guessing it wants more timing from the dome i also found it odd that it liked so much timing.
Our 1150 ultra we run 98 squared with 30hispeed. In good air under 2000 we go 28 and 99. Also run c114 vp. Runs good for what we need it for.
The cam spec i have posted worked really well at 11.1 maybe see what they think about that particular cam. It'a also from cammotion
Re: TF270 accessories [Re: MestocX] #2706714
10/14/19 01:47 PM
10/14/19 01:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
They also tell me it has 4* ground in and should be dot to dot to have the proper advance set. I degree'd it to 105.5.
So you’re within 1/2 a degree of 4deg advanced.
Do you not trust that you degreed it in properly?
Frankly, you’re calling everyone under the sun and getting tons of info, much of which is just erroneous.
Like the cam advance for example.
It makes absolutely zero difference whether there was 0, or 4*, or 50* advance ground into it.
You do what’s required to install it where you want it.
If it’s in at 105.5....... I doubt you’ll find any magic by moving it......... but, there is only one way to know.
And that’s to move it and see what happens.
If you bought a cam that had a 108lsa, and had 4* advance ground in it, and stick it in the motor, degreed it in and found it was in at 112.
You call the cam grinder and they tell you it should have come right in at 104.
So, do you leave it at 112 because the cam grinder(who is not working along side of you while you’re installing the cam) said it really should have come in at 104........or do you move it because it’s not at 104?
Do you think there is somehow a difference between the cam being in at 105.5 with the gears dot-to-dot vs the gears being advanced to the +4(or -6, or off a tooth, or any other way imaginable)and the cam being at 105.5?
105.5 is 105.5........ doesn’t make any difference how you got it there.
Re: TF270 accessories [Re: fast68plymouth] #2706744
10/14/19 03:38 PM
10/14/19 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, 105.5 is what I degree'd the cam to and that is where I would want it. I'm just saying the dots where not lined up with the cam being degree'd at 105.5 from what I remember and it wouldn't hurt to check. Maybe my math was off, who knows. Also, I want to install a factory cover with the timing scale mounted on it for more accurate timing settings. I don't like the one I have. So it's a win win.
Re: TF270 accessories [Re: mopar dave] #2706764
10/14/19 04:56 PM
10/14/19 04:56 PM
AndyF Offline
AndyF  Offline
Just do what you need to do to get confidence in your tune. Keeping careful notes and taking pictures as you go is the best method I know. When I degree a cam in on one of my engines I take a picture of the timing wheel when I'm finished. Then I can look back thru my pictures and see what it was. I don't trust my memory or my notes.
Re: TF270 accessories [Re: AndyF] #2706789
10/14/19 06:46 PM
10/14/19 06:46 PM
Mt Morris Michigan
Mt Morris Michigan
Good advise Andy . Wish I would have done that, but the chain cover is coming off regardless. If I don't bump the compression up to where I think it needs to be, then a smaller more aggressive cam change may be just the ticket for now. I'm thinking something like a 266/270@50 on 108 and same lift, but more aggressive lobe. something like a 27 or 28. First need to get the springs checked and go from there. It may take me a bit, but I will get this sorted out, I always do.
The square jet test went ok. Can't cruise it on the street, but it runs great at WOT. Cruises 11.5-12.5 fat. Wide open was 13.0-13.2 with the bigger .029" HS air bleed in the mix. I think that air bleed will work good in warmer summer weather. Thanks for the help guys.
Re: TF270 accessories [Re: mopar dave] #2706791
10/14/19 06:51 PM
10/14/19 06:51 PM
Are you checking the cam timing off of the lifters or valve retainers with light checking springs like the motor will be ran with the rocker arms on it with the lash set cold for the aluminum heads? work grin scope thumbs
I do the initial cam timing check on the lifters and do the final cam timing off of the intake lobe centers at the retainers with light checking springs and I always verify the exhaust lobe centers once I have the intake lobe set where I want it to make sure the cam is ground on the LSA the cam card says it is scope I've found more than one cam, from two different makers, that where not ground on the LSA the cam card called for shock One was ground on a 101 ILC when the card called for 104 ILC and the other was ground with 8 degree retard ground in it, that rascal wouldn't fall out of tree installed like that rant puke
Re: TF270 accessories [Re: Cab_Burge] #2706799
10/14/19 07:08 PM
10/14/19 07:08 PM
Mt Morris Michigan
Mt Morris Michigan
Cab, I degree'd the cam with the heads off and used a tool that fits in the intake lifter bore and rides directly on the cam. I didn't double check the accuracy of the cam, but sounds like I should have. Now that the engine is fully assembled, I don't think the tool will fit in there, so this time I will have to measure off the lifters edge.
Re: TF270 accessories [Re: mopar dave] #2706994
10/15/19 12:48 PM
10/15/19 12:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Unless your time & budget is unlimited, you need to approach it like you're in a class that requires the parts you have already to be legal, and the goal is to get it dialed in as best you can given those specific constraints.
The problem when I try this is that I keep changing classes on myself. no & laugh2
Re: TF270 accessories [Re: mopar dave] #2706995
10/15/19 12:52 PM
10/15/19 12:52 PM
BradH Offline
BradH  Offline
Or, mock it up to read off the pushrod end. That might be an easier way to get an accurate reading w/ the heads still on (but the rockers off, obviously).
Re: TF270 accessories [Re: BradH] #2707018
10/15/19 02:00 PM
10/15/19 02:00 PM
Mt Morris Michigan
Mt Morris Michigan
I'm with you. My class is constantly changing as well. I thought I was done with this go fast stuff, but its in my blood and has been since I was 14,well, maybe 7 is more like it. I know I told Dwayne I wanted a street/strip cam easy on parts when he spec'd this cam and that's what he gave me. I understand and my own fault. I thought I was all grown up now and didn't need to go real fast anymore. I was wrong. I now need to turn this program up a couple notches. I want to run 10 o's or near it, so what ever it takes within reason, more compression, a more aggressive cam lobe that will live on the street and a bunch more tuning.
Re: TF270 accessories [Re: mopar dave] #2707043
10/15/19 03:57 PM
10/15/19 03:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Shouldnt be hard. I had a smallblock i drove everywhere with a roller did that had mild lobes Dwayne did cam on ran 9’s easily at almost identical weight.
Just gotta get the combo right. I know you will.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: TF270 accessories [Re: B3422W5] #2707075
10/15/19 06:27 PM
10/15/19 06:27 PM
Mt Morris Michigan
Mt Morris Michigan
If I were to do compression and a roller I have no doubt it would go low 10's and maybe better with some work. Looks like a more aggressive flat tappet isn't worth much and a roller maybe 15hp and same for compression, but together it's a good boost.
Re: TF270 accessories [Re: mopar dave] #2707086
10/15/19 07:21 PM
10/15/19 07:21 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I'm not sure where it wants to be shifted. I
It went thru traps at 6900 RPM
The rpm is high ? Converter/trans issue ?
You are mid 125-127MPH? I am 130mph @ 6700 with 30"radial Flat tappet 272@050/600 nett lift . @ 3780lbs . 6000 converter shift @ 6500 (faster than 6300)
Last time out :
1.439
4.205
6.553 @ 104.17
Best sixty is in the 1.42s
Your numbers :
"1.45, 4.272, 6.626 . The vert may be a tad on the tight side, but if the engine made more power it would make up the difference and stall higher."
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: TF270 accessories [Re: tex013] #2707091
10/15/19 07:43 PM
10/15/19 07:43 PM
Mt Morris Michigan
Mt Morris Michigan
That's been my thought too. Leave the vert in for now. My best 1/4 was 10.40@129.75. What's your cubic inch. My gear is a 4.10 with a 28" tire. Gonna switch to a 3.73 late next year.
Re: TF270 accessories [Re: mopar dave] #2707115
10/15/19 09:46 PM
10/15/19 09:46 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
505ci@11.0:1 pump gas . 4.1 gear . If you are running a 28"radial rpm is about right , I went 10.25@129.65 right around 7000 with a 28x10.5 Pro bracket radial . That was turning off the line for a 1.45-46 sixty . Now have the 29.5x10.5 Pro BR , 28s didn't like the T brake at least not at that time .
Slower et = chassis setup or other ? . NOT HP . You are mph ok for 10.20s . What MPH do you gain in 2nd half of the 1/4 ? If you run 1/4 ?
The vert comment was yours I copied .
But when I foot braked the 505 with standard port heads , 4150 carb ,it went 10.50 , changed to smaller size vert , went from 5000 to 5800 , same et's . Fitted 4500 same et's more consistent , though didn't have much tuning till I split intake ports and the block .
I would be getting the car better before I spent more money .
Tex
New best MPH 130.32
Re: TF270 accessories [Re: tex013] #2707197
10/16/19 08:50 AM
10/16/19 08:50 AM
Mt Morris Michigan
Mt Morris Michigan
I ran 105.2 in the 1/8 mile and 129.75 in the 1/4. I'm sure the car needs some tuning of its own as well. Double adjustable Vikings are on my list for the front. I have Calverts on the rear that were set on 5 and left at that setting. I will try tightening those up next time out.
Re: TF270 accessories [Re: mopar dave] #2707237
10/16/19 11:07 AM
10/16/19 11:07 AM
AndyF Offline
AndyF  Offline
Why not pull the engine over the winter and get it on a dyno? Then you'll know how much power it is making and what the torque curve looks like. If you are super ambitious you can even line up some parts for testing on the dyno. Intake manifolds and carbs are easy to swap. Ignition timing is easy to adjust, etc. A cam change on the dyno is a major thrash so you might not want to attempt that but you should still be able to learn a lot.
Re: TF270 accessories [Re: mopar dave] #2707245
10/16/19 11:31 AM
10/16/19 11:31 AM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
The mph you posted suggest that the times are 6.4xx in the 1/8 and 10.2-10.3 in the quarter .. work on chassis before spending money on new parts
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
