Re: Original 69 hemi carbs
[Re: 62maxwgn]
#2705039
10/09/19 05:59 AM
10/09/19 05:59 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Only one spring,16-171 listed,first item at top of sheet. I'm asking if both carbs front and rear have that spring or is the front carb spring not used? My set of restored Carter carbs are missing the front carb spring.
[Re: Sammy]
#2705096
10/09/19 10:04 AM
10/09/19 10:04 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Only one spring,16-171 listed,first item at top of sheet. I'm asking if both carbs front and rear have that spring or is the front carb spring not used? My set of restored Carter carbs are missing the front carb spring. Both have springs,the sheet covers "all" 1968/69 Hemi carbs so that would indicate all had springs,It's real easy to forget to one on re assembly.Here is the balance of the spec sheet,you may want to save for future reference..
[Re: Sammy]
#2706268
10/12/19 08:44 PM
10/12/19 08:44 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
I've had hands on experiences with a lot of OEM Street Hemi motors,1966 up through a 1971, all of them had the pump return springs in both carbs.
[Re: moparmike1]
#2706349
10/13/19 09:43 AM
10/13/19 09:43 AM
Sammy
Wind Gap,Pa.
Scott Smith Harms at Harms Automotive, IMHO, best person to ask about carbs.
Mike. I'm shocked Scott Smith didnt reply on here. Thankyou to 62maxwagn and Cab and the others who replied and help me. Greatly appreciated.
