Original 69 hemi carbs #2704918
10/08/19 05:38 PM
10/08/19 05:38 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Just went to rebuild my carter 4619 & 4620 original hemi carbs and when I took the FRONT carb cover off there was NO lower thick accelerator pump spring under the plunger.
The rear carter carb has the bigger spring under the plunger.
Was there supposed to be a bigger spring under the plunger on the front Carter carb?
Re: Original 69 hemi carbs [Re: Sammy] #2704962
10/08/19 08:13 PM
10/08/19 08:13 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Scott Smith Harms at Harms Automotive, IMHO, best person to ask about carbs.
Mike.
Re: Original 69 hemi carbs [Re: Sammy] #2705014
10/08/19 10:52 PM
10/08/19 10:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Only one spring,16-171 listed,first item at top of sheet,for all applications,means front and rear both.
Re: Original 69 hemi carbs [Re: 62maxwgn] #2705039
10/09/19 05:59 AM
10/09/19 05:59 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by 62maxwgn
Only one spring,16-171 listed,first item at top of sheet.
I'm asking if both carbs front and rear have that spring or is the front carb spring not used?
My set of restored Carter carbs are missing the front carb spring.
Re: Original 69 hemi carbs [Re: Sammy] #2705096
10/09/19 10:04 AM
10/09/19 10:04 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Both have springs,the sheet covers "all" 1968/69 Hemi carbs so that would indicate all had springs,It's real easy to forget to one on re assembly.Here is the balance of the spec sheet,you may want to save for future reference..
Re: Original 69 hemi carbs [Re: Sammy] #2706268
10/12/19 08:44 PM
10/12/19 08:44 PM
I've had hands on experiences with a lot of OEM Street Hemi motors,1966 up through a 1971, all of them had the pump return springs in both carbs. up
Re: Original 69 hemi carbs [Re: Cab_Burge] #2706276
10/12/19 09:11 PM
10/12/19 09:11 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Finally someone answers the man
Re: Original 69 hemi carbs [Re: cudaman1969] #2706294
10/12/19 11:27 PM
10/12/19 11:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I answered him in the beginning ! rolleyes
Re: Original 69 hemi carbs [Re: 62maxwgn] #2706348
10/13/19 09:41 AM
10/13/19 09:41 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks.
For all the replys.
I'm going to install a spring today.
I put in a new oe correct leather accelerator pump on both carbs.
Seems the front carb still wont squirt. Think the check valve is stuck?
Can it be freed up without taking off the carb?
Re: Original 69 hemi carbs [Re: moparmike1] #2706349
10/13/19 09:43 AM
10/13/19 09:43 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Mike.
I'm shocked Scott Smith didnt reply on here.
Thankyou to 62maxwagn and Cab and the others who replied and help me. Greatly appreciated.
Re: Original 69 hemi carbs [Re: Sammy] #2706351
10/13/19 09:44 AM
10/13/19 09:44 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Moparmike1 thankyou also.
Re: Original 69 hemi carbs [Re: Sammy] #2706389
10/13/19 12:46 PM
10/13/19 12:46 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Had no choice but to take both off.
Had to flip them upside down and keep tapping till they fell out.
They were stuck.
Guess the bad gas doesnt help them.
Now I'm betting there was nothing wrong with my old accelerator pumps after all.
Lesson learned.
