Best way to press out leaf spring bushing?
#2705804
10/11/19 09:15 AM
10/11/19 09:15 AM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
Any recommendations on what to use to press out the 1.5" bushing in the rear leaf springs? The shop has a press, but they are struggling to find a press detail to press the bushing out.
Re: Best way to press out leaf spring bushing?
[Re: second 70]
#2705851
10/11/19 11:28 AM
10/11/19 11:28 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Years ago when I did my AAR springs, I just used a piece of exhaust tubing. Piece of cake.
[Re: second 70]
#2706147
10/12/19 10:47 AM
10/12/19 10:47 AM
Posts: 16,516 On the run…
BloFish
On the run…
I just used a press and large socket on mine came right out. This how I did mine as well.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: MO_PA]
#2706423
10/13/19 03:19 PM
10/13/19 03:19 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Use your welder to weld inside of the bushing, go round and round 2 or three times and the bushing will shrink and fall out. This works great, also works on lower control arm bushings if you like to get your stuff apart without beating the parts up.
