Best way to press out leaf spring bushing? #2705804
10/11/19 09:15 AM
10/11/19 09:15 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Any recommendations on what to use to press out the 1.5" bushing in the rear leaf springs? The shop has a press, but they are struggling to find a press detail to press the bushing out.
Re: Best way to press out leaf spring bushing? [Re: vinnyd76] #2705805
10/11/19 09:18 AM
10/11/19 09:18 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If it is an original bushing in an old spring you may have to cut the center out with a torch and then split the sleeve out with a chisel... twocents
...FAFO...
Re: Best way to press out leaf spring bushing? [Re: skicker] #2705808
10/11/19 09:26 AM
10/11/19 09:26 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Yes, the Rear Leaf Springs are original. They are a set of A-Body 383/440 leaf springs.
The shop removed the bushing from a set of 70 B-Body 440 springs not that long ago, but they are struggling to remember what they used.
Re: Best way to press out leaf spring bushing? [Re: vinnyd76] #2705835
10/11/19 11:01 AM
10/11/19 11:01 AM
central il.
second 70 Offline
second 70  Offline
central il.
I just used a press and large socket on mine came right out.
Re: Best way to press out leaf spring bushing? [Re: second 70] #2705851
10/11/19 11:28 AM
10/11/19 11:28 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Years ago when I did my AAR springs, I just used a piece of exhaust tubing. Piece of cake.
Re: Best way to press out leaf spring bushing? [Re: second 70] #2706147
10/12/19 10:47 AM
10/12/19 10:47 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
This how I did mine as well.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to press out leaf spring bushing? [Re: BloFish] #2706209
10/12/19 02:07 PM
10/12/19 02:07 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Use your welder to weld inside of the bushing, go round and round 2 or three times and the bushing will shrink and fall out.
Re: Best way to press out leaf spring bushing? [Re: MO_PA] #2706248
10/12/19 06:48 PM
10/12/19 06:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
eek up Cool idea smile
Re: Best way to press out leaf spring bushing? [Re: MO_PA] #2706423
10/13/19 03:19 PM
10/13/19 03:19 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
This works great, also works on lower control arm bushings if you like to get your stuff apart without beating the parts up.
Re: Best way to press out leaf spring bushing? [Re: vinnyd76] #2706606
10/14/19 07:39 AM
10/14/19 07:39 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
If a shop has an issue removing a simple bushing... what are they doing the rest of the day?
