Removing 8 3/4 pinion carrier #2705700
10/10/19 09:23 PM
10/10/19 09:23 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hi All,
I am trying to pull the pinion carrier off of my 8 3/4 rear end. I got all of the bolt loose with no problems, and got the carrier slid forward to the end of the bolts (so there is a quarter inch gap between it and the back of the axle housing), but it will not come off. I can wiggle it up and down some, but there is absolutely no side to side movement and it will not pull or pry off. I am out of ideas after struggling with it for an hour or so.
Am I missing something? Can somebody give me some advice on this?
Thanks.
Greg
Re: Removing 8 3/4 pinion carrier [Re: GregY] #2705701
10/10/19 09:25 PM
10/10/19 09:25 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Did you remove the axles?
Re: Removing 8 3/4 pinion carrier [Re: DoctorDiff] #2705705
10/10/19 09:35 PM
10/10/19 09:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
whistle
Re: Removing 8 3/4 pinion carrier [Re: Sniper] #2705706
10/10/19 09:36 PM
10/10/19 09:36 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Not much else in there to keep it from coming out other than the axle shafts..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Removing 8 3/4 pinion carrier [Re: GoodysGotaCuda] #2705710
10/10/19 09:40 PM
10/10/19 09:40 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Boy I am dumb sometimes.
Somehow I skipped right to Step 2.
Thank you.
Re: Removing 8 3/4 pinion carrier [Re: GregY] #2705754
10/11/19 01:25 AM
10/11/19 01:25 AM
that is one lesson you will never forget, huh work up
Re: Removing 8 3/4 pinion carrier [Re: Cab_Burge] #2706653
10/14/19 10:44 AM
10/14/19 10:44 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Yep, I confirmed first hand that the carrier does in fact come out much easier with the axles out. I only wish they had made it a little heavier.
Everything looked good with the internals, and it's back in again, I just need to get the axles back in and some fresh gear oil and I should be good to go (pray for no leaks!).
Thanks for all of the help. Sometimes I tend to jump into stuff without doing the necessary up front research.
Greg
Re: Removing 8 3/4 pinion carrier [Re: GregY] #2706735
10/14/19 03:21 PM
10/14/19 03:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's a clutch-type Sure-Grip, make sure the thrust buttons are intact before installing the third member...they're known to fall out when the axles are removed and disappear in the oil.
