New Best with 514 #2705541
10/10/19 02:06 PM
10/10/19 02:06 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I was having some issues with tire moving and will have to Glue them to the rims
Re: New Best with 514 [Re: 10secGTX] #2705548
10/10/19 02:25 PM
10/10/19 02:25 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow!
'63 Dodge 330
11.19 @ 121 mph
Re: New Best with 514 [Re: 10secGTX] #2705569
10/10/19 03:13 PM
10/10/19 03:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice!!
That’s Andy’s old motor right?
What’s the current configuration?
Re: New Best with 514 [Re: fast68plymouth] #2705606
10/10/19 04:23 PM
10/10/19 04:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
that's great . including the car
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: New Best with 514 [Re: fast68plymouth] #2705630
10/10/19 05:35 PM
10/10/19 05:35 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
Originally Posted by fast68plymouth
Nice!!
It’s basically his long block ... I used a MW Victor intake w 1.7 rockers ... I have a 1150 Dominator in my heavy POS ...it’s got a 904 with a 8 “ ATI and a 3.90 gear ... I’m just using 904 till I can buy something over the off season... if I can 60’ it will be a helluva ride
Re: New Best with 514 [Re: 10secGTX] #2705633
10/10/19 05:39 PM
10/10/19 05:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did that have the EZ’s on it for it’s final iteration?
High CR?
The 60’s do like they could use some improvement.
Re: New Best with 514 [Re: fast68plymouth] #2705640
10/10/19 05:48 PM
10/10/19 05:48 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i think it has the TF 270 heads on it.
Re: New Best with 514 [Re: krautrock] #2705643
10/10/19 06:06 PM
10/10/19 06:06 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
VERY nice!! Is that pump gas?? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New Best with 514 [Re: hemi-itis] #2705644
10/10/19 06:09 PM
10/10/19 06:09 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
Haaa ... I wish ... it has your EZ’s Dwayne... it’s 15-1 ..so I’m using C14
Re: New Best with 514 [Re: 10secGTX] #2705800
10/11/19 08:58 AM
10/11/19 08:58 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Get that thing to come out of the hole better and you will be in the 9's easy - your MPH indicates you got the HP to dip into the nines
Re: New Best with 514 [Re: 10secGTX] #2705823
10/11/19 10:17 AM
10/11/19 10:17 AM
So. Burlington, Vt.
So. Burlington, Vt.
Actually, credit where credit is due.......the CNC porting on those was done by Jeff at MCH.
I just freshened the valve job after they’d been run for a bunch of testing.
Re: New Best with 514 [Re: fast68plymouth] #2705865
10/11/19 11:44 AM
10/11/19 11:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Congrats on the new best...Its running well, start working on those short times now.
Re: New Best with 514 [Re: fast68plymouth] #2705866
10/11/19 11:52 AM
10/11/19 11:52 AM
AndyF Offline
AndyF  Offline
Yeah those heads have some frequent flyer miles on them. I ran then initially out of the box and they didn't make any power. Sent them to Jeff at MCH for his CNC porting and they picked up a bunch. Had to send them to Dwayne though since MCH missed some things such as the pushrod tubes. They also got sent to Fastlane in Utah for some work at one point. Not to mention all the CNC machine work I did on the rocker stands to fit the Jesel setup. Nobody makes a Jesel setup for EZ heads so it required some custom machine work.
Glad to see you have the car out making laps. I know it took a bunch of work to get that together and into the car. You probably have another 1/2 second you can pick up from chassis, converter and tuning so you'll have fun next year getting it all sorted out. I helped out some local guys with a Belvedere this year with a similar engine. First pass off the trailer was an 11.70 and after a few sessions (and a bunch of work) they are now in the high nines. Always a lot of details to sort out on new combos.
Re: New Best with 514 [Re: AndyF] #2705870
10/11/19 11:59 AM
10/11/19 11:59 AM
AndyF Offline
AndyF  Offline
Were you running full exhaust at the track? I think you said you have 3.5 inch exhaust with mufflers?
Re: New Best with 514 [Re: AndyF] #2705891
10/11/19 12:43 PM
10/11/19 12:43 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
NICE!!!...looks like a stocker too.
Re: New Best with 514 [Re: AndyF] #2705979
10/11/19 05:16 PM
10/11/19 05:16 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I have exhaust with mufflers, that dumps out at axle. I had a issue with the tires and need to glue them to the rim .. we marked the tire and rim and it moved about half the way around the rim. so I will see how the 60' will improve once I can get that together
Re: New Best with 514 [Re: 10secGTX] #2705992
10/11/19 05:51 PM
10/11/19 05:51 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice job!Sorry I didn't stop by you or SunroofGTX.
Re: New Best with 514 [Re: Clanton] #2706007
10/11/19 06:29 PM
10/11/19 06:29 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
Mike I saw your car and then you were loaded up and rolling out< hope all is well
Re: New Best with 514 [Re: 10secGTX] #2706009
10/11/19 06:35 PM
10/11/19 06:35 PM
AndyF Offline
AndyF  Offline
The cam that is in that engine might not be "perfect" for mufflers so that is one thing you could check by running without the exhaust system once you get the car hooking hard. If you still have the extra set of 1.85 rocker arms that is another variable you can play with once the car is hooking.
Re: New Best with 514 [Re: 10secGTX] #2706020
10/11/19 07:22 PM
10/11/19 07:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thank you I am good,I need a new vert to finish up going n/a and just needed 1 more pass to jet an 850 before I put on the 1050 yesterday to get ready for next year.There was a ton of cars there,Must have been close to 400.
