Re: New Best with 514
[Re: 10secGTX]
#2705569
10/10/19 03:13 PM
10/10/19 03:13 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Nice!!
That’s Andy’s old motor right?
What’s the current configuration?
[Re: fast68plymouth]
#2705606
10/10/19 04:23 PM
10/10/19 04:23 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
that's great . including the car
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2705630
10/10/19 05:35 PM
10/10/19 05:35 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
Nice!!
What’s the current configuration? It’s basically his long block ... I used a MW Victor intake w 1.7 rockers ... I have a 1150 Dominator in my heavy POS ...it’s got a 904 with a 8 “ ATI and a 3.90 gear ... I’m just using 904 till I can buy something over the off season... if I can 60’ it will be a helluva ride
[Re: 10secGTX]
#2705633
10/10/19 05:39 PM
10/10/19 05:39 PM
fast68plymouth
So. Burlington, Vt.
Did that have the EZ’s on it for it’s final iteration?
High CR?
The 60’s do like they could use some improvement.
[Re: 10secGTX]
#2705823
10/11/19 10:17 AM
10/11/19 10:17 AM
fast68plymouth
So. Burlington, Vt.
VERY nice!! Is that pump gas?? Haaa ... I wish ... it has your EZ’s Dwayne... it’s 15-1 ..so I’m using C14 Actually, credit where credit is due.......the CNC porting on those was done by Jeff at MCH. I just freshened the valve job after they’d been run for a bunch of testing.
#2705865
10/11/19 11:44 AM
10/11/19 11:44 AM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Congrats on the new best...Its running well, start working on those short times now.
#2705866
10/11/19 11:52 AM
10/11/19 11:52 AM
Posts: 31,050 Oregon
AndyF
VERY nice!! Is that pump gas?? Haaa ... I wish ... it has your EZ’s Dwayne... it’s 15-1 ..so I’m using C14 Actually, credit where credit is due.......the CNC porting on those was done by Jeff at MCH. I just freshened the valve job after they’d been run for a bunch of testing. Yeah those heads have some frequent flyer miles on them. I ran then initially out of the box and they didn't make any power. Sent them to Jeff at MCH for his CNC porting and they picked up a bunch. Had to send them to Dwayne though since MCH missed some things such as the pushrod tubes. They also got sent to Fastlane in Utah for some work at one point. Not to mention all the CNC machine work I did on the rocker stands to fit the Jesel setup. Nobody makes a Jesel setup for EZ heads so it required some custom machine work. Glad to see you have the car out making laps. I know it took a bunch of work to get that together and into the car. You probably have another 1/2 second you can pick up from chassis, converter and tuning so you'll have fun next year getting it all sorted out. I helped out some local guys with a Belvedere this year with a similar engine. First pass off the trailer was an 11.70 and after a few sessions (and a bunch of work) they are now in the high nines. Always a lot of details to sort out on new combos.
[Re: AndyF]
#2705979
10/11/19 05:16 PM
10/11/19 05:16 PM
10secGTX
Cleveland Ohio
Were you running full exhaust at the track? I think you said you have 3.5 inch exhaust with mufflers? I have exhaust with mufflers, that dumps out at axle. I had a issue with the tires and need to glue them to the rim .. we marked the tire and rim and it moved about half the way around the rim. so I will see how the 60' will improve once I can get that together
[Re: Clanton]
#2706007
10/11/19 06:29 PM
10/11/19 06:29 PM
10secGTX
Cleveland Ohio
Nice job!Sorry I didn't stop by you or SunroofGTX. Mike I saw your car and then you were loaded up and rolling out< hope all is well
[Re: 10secGTX]
#2706009
10/11/19 06:35 PM
10/11/19 06:35 PM
AndyF
Were you running full exhaust at the track? I think you said you have 3.5 inch exhaust with mufflers? I have exhaust with mufflers, that dumps out at axle. I had a issue with the tires and need to glue them to the rim .. we marked the tire and rim and it moved about half the way around the rim. so I will see how the 60' will improve once I can get that together The cam that is in that engine might not be "perfect" for mufflers so that is one thing you could check by running without the exhaust system once you get the car hooking hard. If you still have the extra set of 1.85 rocker arms that is another variable you can play with once the car is hooking.
