B body disc brake conversion kit #2704336
10/06/19 01:52 PM
10/06/19 01:52 PM
illinois
bigblk66_coronet Offline OP
illinois
i got a question for you guys. I have a 66 Coronet 550 with a 440. I had a CPP front disc brake 11 inch conversion kit put on last week. Im still running the drum master cylinder and he told me I need a proportioning valve which I completely over looked. My shop told me I may need a different master cylinder, I do not want a booster on this car. So do I just need to get a master cylinder for something with front discs? And ive thought about just switching to discs on the rear too. Anyone run 4 wheel discs and do I need a booster if I go that route? Just want to make sure its done right and safe. Thanks guys! Anyone?
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: B body disc brake conversion kit [Re: bigblk66_coronet] #2704350
10/06/19 03:12 PM
10/06/19 03:12 PM
AndyF Offline
AndyF  Offline
I don't know what a CPP kit so it is a little hard to know what you're working with. Some kits are okay but others are crap so hopefully you ended up with a good kit. The best bet for a car like yours is to just use factory parts. If you have 15 inch wheels you should be able to use the factory 11.75 rotors. If you have the 11.75 rotors then the system should work okay without a booster. If you have the big factory drums on the rear the setup will work even better. I wouldn't recommend rear disc brakes for your car.
Spend some time on the Doctor Diff website and you'll see what you need.
Re: B body disc brake conversion kit [Re: bigblk66_coronet] #2704379
10/06/19 05:47 PM
10/06/19 05:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, if for no other reason, to get rid of the residual pressure valve in the current MC. A manual disc brake MC from a later Mopar B-body would be a good choice. The need for a prop valve can be determined after the conversion is done. Install a prop valve only if you suffer from premature rear brake lockup.
Re: B body disc brake conversion kit [Re: John_Kunkel] #2704380
10/06/19 06:01 PM
10/06/19 06:01 PM
illinois
illinois
It does have a dual manual master cylinder on it right now. I did away with the suicide master cylinder about 8 years ago.
Re: B body disc brake conversion kit [Re: bigblk66_coronet] #2704404
10/06/19 07:05 PM
10/06/19 07:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, but it it's a drum brake MC it has a RPV in the front circuit which is incompatible with discs.
Re: B body disc brake conversion kit [Re: bigblk66_coronet] #2704406
10/06/19 07:12 PM
10/06/19 07:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I believe I used an early to mid 70s A-Body disc brake MC with a 15/16" bore.
Re: B body disc brake conversion kit [Re: BSB67] #2704424
10/06/19 08:03 PM
10/06/19 08:03 PM
AndyF Offline
AndyF  Offline
That MC might be okay. Drive the car and see what you think. You'll most likely need a prop valve since otherwise the rear drums will lock up during hard braking.
The problem with brake swaps is that people don't have a lot of "common knowledge" around what works and what doesn't. People kind of know which cam works with which engine and stuff like that but which master cylinder works with which rotor size and how much brake bias there should be and stuff like that isn't common knowledge. So when you start swapping parts around you have to either copy a factory setup, or be prepared to do some R&D.
Re: B body disc brake conversion kit [Re: AndyF] #2704493
10/07/19 07:36 AM
10/07/19 07:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use 70 C body disc masters.Mine on my 65 has been on for 20 years.Used the same on my kids 62 300 with power drums just used a drum master.Mine is non power disc frt.I run a later 5th ave PP valve.Rocky
Chrysler Firepower
Re: B body disc brake conversion kit [Re: BSB67] #2704581
10/07/19 01:27 PM
10/07/19 01:27 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Yup, a 1975 Duster with power disc brakes has a 15/16" bore. Use that with your manual setup.
Re: B body disc brake conversion kit [Re: Cuda340] #2704811
10/08/19 10:32 AM
10/08/19 10:32 AM
moparx Offline
moparx  Offline
just make sure the master you use has some kind of accuator rod retention so it doesn't pop out when you apply the brakes.
beer
Re: B body disc brake conversion kit [Re: Cuda340] #2704970
10/08/19 08:37 PM
10/08/19 08:37 PM
illinois
illinois
i have been looking but cant seem to find one anywhere
Re: B body disc brake conversion kit [Re: bigblk66_coronet] #2704974
10/08/19 08:42 PM
10/08/19 08:42 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Where are you looking?
Found it first try
Re: B body disc brake conversion kit [Re: Sniper] #2705098
10/09/19 10:07 AM
10/09/19 10:07 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Check with Dr. Diff . . . Cass will know or have exactly what you need . . .
