B body disc brake conversion kit
#2704336
10/06/19 01:52 PM
10/06/19 01:52 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
i got a question for you guys. I have a 66 Coronet 550 with a 440. I had a CPP front disc brake 11 inch conversion kit put on last week. Im still running the drum master cylinder and he told me I need a proportioning valve which I completely over looked. My shop told me I may need a different master cylinder, I do not want a booster on this car. So do I just need to get a master cylinder for something with front discs? And ive thought about just switching to discs on the rear too. Anyone run 4 wheel discs and do I need a booster if I go that route? Just want to make sure its done right and safe. Thanks guys! Anyone?
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: B body disc brake conversion kit
[Re: bigblk66_coronet]
#2704379
10/06/19 05:47 PM
10/06/19 05:47 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My shop told me I may need a different master cylinder, I do not want a booster on this car. So do I just need to get a master cylinder for something with front discs? Yes, if for no other reason, to get rid of the residual pressure valve in the current MC. A manual disc brake MC from a later Mopar B-body would be a good choice. The need for a prop valve can be determined after the conversion is done. Install a prop valve only if you suffer from premature rear brake lockup.
[Re: John_Kunkel]
#2704380
10/06/19 06:01 PM
10/06/19 06:01 PM
bigblk66_coronet
illinois
It does have a dual manual master cylinder on it right now. I did away with the suicide master cylinder about 8 years ago.
440w/727
#2704404
10/06/19 07:05 PM
10/06/19 07:05 PM
John_Kunkel
Rio Linda, CA
Yes, but it it's a drum brake MC it has a RPV in the front circuit which is incompatible with discs.
[Re: AndyF]
#2704493
10/07/19 07:36 AM
10/07/19 07:36 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
We use 70 C body disc masters.Mine on my 65 has been on for 20 years.Used the same on my kids 62 300 with power drums just used a drum master.Mine is non power disc frt.I run a later 5th ave PP valve.Rocky
Chrysler Firepower
[Re: BSB67]
#2704581
10/07/19 01:27 PM
10/07/19 01:27 PM
Posts: 2,366 Wheatfield, NY
Cuda340
Wheatfield, NY
I believe I used an early to mid 70s A-Body disc brake MC with a 15/16" bore. Yup, a 1975 Duster with power disc brakes has a 15/16" bore. Use that with your manual setup.
[Re: Cuda340]
#2704970
10/08/19 08:37 PM
10/08/19 08:37 PM
bigblk66_coronet
illinois
i have been looking but cant seem to find one anywhere
440w/727
