Any duster running 275 DR tires #2704242
10/06/19 08:45 AM
10/06/19 08:45 AM
east coast
Otherlane Offline OP
east coast
i just bought a set of jegs 15x8 wheels with a 5.50 back space with 275/60 drag radial. The tires hits the springs, I’m going to replace with cal trac. I’m thinking of getting the 4.50 back space. That 1 in back space should help..what did you guys do to make this wheel/tire fits?
Re: Any duster running 275 DR tires [Re: Otherlane] #2704261
10/06/19 09:48 AM
10/06/19 09:48 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Offset spring hangers will make your life easier. 275/60/15 M/T drag radials on my '71 Duster fit no problem with the offset hangers and Caltracs. 15 x 8 wheel, 4 1/2" backspace.
'71 Duster
'17 Ram 1500
Re: Any duster running 275 DR tires [Re: RMCHRGR] #2704306
10/06/19 11:51 AM
10/06/19 11:51 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Had a similar deal on a Duster BB street car.
It already had the 3/4" relocation but was still too tight with 5.50" BS & 275s.
5.00" BS would have worked perfectly but that's not commonly found.
I eventually ran a 4.50" BS 15x8. Tires were just inside the outer wheel opening.
Often a 28" tire gets pretty close at the front of the opening, too.
If it was a lower-powered street car with studs, a 1/2" spacer would work with the 5.50 BS.
But that thing made 600 ft lbs...
By the same token, the racecar has always had .250" spacers and they've never been a problem (low 10s).
Re: Any duster running 275 DR tires [Re: RMCHRGR] #2704318
10/06/19 12:24 PM
10/06/19 12:24 PM
east coast
east coast
If i can get it like that I'm happy
Re: Any duster running 275 DR tires [Re: Otherlane] #2704430
10/06/19 08:15 PM
10/06/19 08:15 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Is it a stock small bolt 8 3/4 currently in the car?
This may not work for you but I have a 65 B Body housing under Dads 72 Duster...Backspace on the 9.5" wheels is 5.5"...
Tires are 275/60 M/T ET Streets...
5.5" is too much for a stock width small bolt 8 3/4 without a spring relocation...
...FAFO...
Re: Any duster running 275 DR tires [Re: skicker] #2704911
10/08/19 05:15 PM
10/08/19 05:15 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
15x8 with a 4.5 backspace with a 1/4 spacer plate works on my car.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
