Re: Sec. Plate Info for S/S 426 Hemi Holley Carbs 4235 & 4236
[Re: Cab_Burge]
#2703948
10/04/19 08:30 PM
10/04/19 08:30 PM
Posts: 1,102 Melbourne, Florida
Florida_70Bee
Melbourne, Florida
Go to Holleys tech section to see what rear metering plates where stock on those carbs from day one Thanks Cab I went to Holley's technical support pages and got a listing specs table of both carbs but unfortunately under the Secondary Main Jet or Plate column it states N/S instead of a part number for both 4235 & 4236 (With no explanation of what N/S means).
[Re: Jimi_Vignogna]
#2704238
10/06/19 08:21 AM
10/06/19 08:21 AM
Posts: 2,636 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have a new set (repop) of 4235/4236's here. I was going to see what numbers are on them for you. But I don't see a number. Except 5792 stamped upside down in the center. Do I need to take the metering plate out?
2011 Drag Pak Challenger
[Re: rickseeman]
#2704246
10/06/19 08:58 AM
10/06/19 08:58 AM
rickseeman
Stuttgart, Arkansas
Ok, I did find those numbers in one of my Holley books so they are legit numbers. But that doesn't tell us that those numbers are correct or a 68.
[Re: rickseeman]
#2704286
10/06/19 11:01 AM
10/06/19 11:01 AM
rickseeman
Stuttgart, Arkansas
I'm beginning to think those numbers might be correct. They are staggered jets and different from carb to carb hence having 2 carb numbers on 68's as opposed to 3116's for either side of a 64/65.
[Re: Jimi_Vignogna]
#2704472
10/06/19 11:31 PM
10/06/19 11:31 PM
Florida_70Bee
Melbourne, Florida
I’m not sure what the original part numbers were, unless your engine is a stroker or has ported heads and a large roller cam those plates are probably very close in jetting for what you need. On my stocker engine I use .030 idle and .073 main jet. On the older super stock engines my father used to run we had .032 -.080 plates. Thanks for the Info Jimi.. I'm beginning to think they are close as well as I wanted a baseline to start with..
[Re: rickseeman]
#2704473
10/06/19 11:32 PM
10/06/19 11:32 PM
Florida_70Bee
Melbourne, Florida
I'm beginning to think those numbers might be correct. They are staggered jets and different from carb to carb hence having 2 carb numbers on 68's as opposed to 3116's for either side of a 64/65. Thanks for checking those out for me..So do you know what the idle and main sizes are on those plates?
[Re: Florida_70Bee]
#2708224
10/18/19 11:07 PM
10/18/19 11:07 PM
Florida_70Bee
Melbourne, Florida
Thanks for all the tips and suggestions everyone
I finally called the Holley tech line this afternoon and found out the plates they use were the 5792 and 5790's .
They had them in stock and I ordered one of each.. I also bought 2 new correct primary metering blocks as the ones on the carbs were not original to the carbs (as they were anodized black).
