I don't understand "Unsilenced Air Cleaner" #2702085
09/29/19 07:41 PM
09/29/19 07:41 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I like the look of the Mopar Unsilenced Air Cleaner from the 60's, but I've never understood the "unsilenced". To me, it appears the top comes all the over the sides and fits fully against the bottom plate, leaving nothing open to the element. I know I must be missing something, because there's not even a snorkel to allow air to come in, and certainly nothing unsilenced with my perception of the way it fits.
Am I just being dense? Wouldn't be the first time.
Facts are stubborn things.
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2702091
09/29/19 07:59 PM
09/29/19 07:59 PM
I dont have an answer for you but that is a good question
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2702095
09/29/19 08:20 PM
09/29/19 08:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You answered your own question. up
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2702096
09/29/19 08:22 PM
09/29/19 08:22 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Take a closer look at the base. The filter element sits in the flat area at the perimeter. The top is bigger leaving a gap around the bottom for air flow.
Re: I don't understand "Unsilenced Air Cleaner" [Re: GomangoCuda] #2702134
09/29/19 10:14 PM
09/29/19 10:14 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
This. ^^^
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: I don't understand "Unsilenced Air Cleaner" [Re: lilcuda] #2702211
09/30/19 09:40 AM
09/30/19 09:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
This. ^^^
This x2 ^^^^^
However, when compared to aftermarket open element filters, the Mopar unit pictured is considerably quieter.
Re: I don't understand "Unsilenced Air Cleaner" [Re: TC@HP2] #2702215
09/30/19 09:50 AM
09/30/19 09:50 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
To clarify, As stated above, their are two differences,
A "normal" air cleaner's lid is sealed to the base forcing the required air to enter through the snorkel which acts as a muffler.
Make sense now ? beer
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2702347
09/30/19 06:00 PM
09/30/19 06:00 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
bought that kit in the 90s,just paint the base black and no one will ever know it's not original to the car.
Re: I don't understand "Unsilenced Air Cleaner" [Re: 1970A13] #2702409
09/30/19 07:40 PM
09/30/19 07:40 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I’d be happy to buy one for 1990’s prices up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: I don't understand "Unsilenced Air Cleaner" [Re: BloFish] #2702662
10/01/19 03:03 PM
10/01/19 03:03 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, I guess if it (the base) seals against the element and not the lid sides, then some extra air comes in the bottom, versus just a snorkel.
Anyone running one of these, can you advise if it's as open sounding as a flipped lid? I kind of want one for my stroked 360 (408) but prefer a stock Mopar air cleaner, although this would not be stock to the car.
Thanks.
Re: I don't understand "Unsilenced Air Cleaner" [Re: BloFish] #2702679
10/01/19 03:46 PM
10/01/19 03:46 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
I might have one available!
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2702682
10/01/19 03:51 PM
10/01/19 03:51 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
It's definately louder, but not a full throated roar. Maybe if I tested it with a TQ? smile
Re: I don't understand "Unsilenced Air Cleaner" [Re: kowalski440] #2702689
10/01/19 04:08 PM
10/01/19 04:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks. If you decide you're selling one I'd PM me
Re: I don't understand "Unsilenced Air Cleaner" [Re: kowalski440] #2702790
10/01/19 09:56 PM
10/01/19 09:56 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Let me know...
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: I don't understand "Unsilenced Air Cleaner" [Re: BloFish] #2703013
10/02/19 11:36 AM
10/02/19 11:36 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Yes the only air gap is between the outer air cleaner lid and the bottom base. That gap is about 3/4” and my 410 CI small block exceeded that gaps ability to flow enough air. The later 340 air cleaners had a snorkle and a trap door that would pop open.
best of 11.17 at 120 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2703086
10/02/19 02:29 PM
10/02/19 02:29 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Here's your issue.
The filter must be tall enough to allow air to enter under the cover.
Thus you will "hear" air being pulled in.
You can get the same affect by using too tall of a filter in a regular housing and it will be unsilenced at the top.
We did this a lot way back when.
Will flow all the air you need, as the can and filter are much larger.
I dig where your going with this.
Super kool on da truck.
I have mechanical Aptitude.
I can screw up anything.
Re: I don't understand "Unsilenced Air Cleaner" [Re: bboogieart] #2703144
10/02/19 04:32 PM
10/02/19 04:32 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Yes, trying to be secretive about letting the extra air and and having the cool four barrel sound, and keep it Mopar. Also, lately I've been really liking the look of the unsilenced air cleaner more and more. Seeing them atop an old stock hp383 is a beautiful site.
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2703160
10/02/19 05:27 PM
10/02/19 05:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I had an air filter housing that had a series of holes (about one inch) around the circumference of the bottom, out side the filter. Cant remember what it came off of, Maybe an early 70's big block?
The idea is sound so maybe drill 1" holes around the bottom of your air cleaner housing.
Wont be sucking cold air from there though.
Or like we did back in the fun young days just get a taller filter or stack them.
Re: I don't understand "Unsilenced Air Cleaner" [Re: bboogieart] #2703227
10/02/19 08:25 PM
10/02/19 08:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I was cheap. I always just flipped the lid upside down. Then I started cutting off the extra part of the lid that was outside the filter, of course soon after that I started cutting off the bottom of the housing outside of the filter. I didn't need no chrome lid or base!
That sure made the car more difficult to drive when the weather got cold, I ended up getting a full housing for the winter months then swapped the cut version in late spring through early fall. Gene
Re: I don't understand "Unsilenced Air Cleaner" [Re: poorboy] #2703683
10/04/19 03:25 AM
10/04/19 03:25 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have experimented a bit with both styles and the road noise is dramatically louder at freeway speeds with an unsilenced unit vs. a dual snorkel.
