Re: Type II power steering box [Re: ProSport] #2702445
09/30/19 10:19 PM
09/30/19 10:19 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you need a pressure hose and a return for the pump. this setup looks like it would work with a motor plate.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Type II power steering box [Re: ProSport] #2702451
09/30/19 11:15 PM
09/30/19 11:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
there will be two hoses at the pump. generally one is a pressure hose from the pump to the rack, then a return hose from the rack to the reservoir and a feed line from the reservoir to the pump.
That's with a remote reservoir, if you have a pump mounted reservoir then the line between the pump and reservoir isn't there.
Re: Type II power steering box [Re: AndyF] #2702820
10/02/19 07:09 AM
10/02/19 07:09 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Andy I think this setup will work for me, let us know when you have some ready to sell.
I will probably have to ditch my serpentine setup though so I can run a 2-groove crank pulley.
I'll start looking for a part number for a March pulley kit. Does this TYPEII pump require a bolt-on or press on pulley?
Re: Type II power steering box [Re: ProSport] #2702889
10/02/19 08:30 AM
10/02/19 08:30 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we sell a serpentine belt pulley for this pump. its also integrated into all of our serpentine belt kits.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Type II power steering box [Re: Jerry] #2702895
10/02/19 08:54 AM
10/02/19 08:54 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Awesome. Which brand are you, March?
Edit: I see you're SDC. 👍
Re: Type II power steering box [Re: 68rrunner] #2709913
10/25/19 12:32 AM
10/25/19 12:32 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted by 68rrunner
Originally Posted by AndyF
Not much information on that KRC bracket! That has to be one of the most ineffective ads for a part that I've seen. Basically zero info.
They work. EMax runs that setup. I don't have any pictures, but you can see it with a quick internet search. 9 years and going strong.
But IIRC, it wasn't 100% bolt on.
I thought it was for a magnum block. So one of the 3 bolt attachments needs some work. LIke an extension cause one bolt didn't line up or something. I have pics of it on the Emax up close.
Re: Type II power steering box [Re: autoxcuda] #2718990
11/24/19 08:08 PM
11/24/19 08:08 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I bought these brackets from Andy, he said they probably wouldn't work with a motor plate but I wanted to try it anyways.
I had to cut the ear off the rear bracket, I cut it on the dotted line in the photo. I drilled a 5/16 hole in the bracket to bolt it to my motor plate.
Everything was looking great until I realized my bulky Mezeire electric water pump was gonna interfere with the belt.
So I moved the pump over and down, and mounted it straight to the motor plate, and flipped the rear bracket around so it was aimed at the driver side of the car.
I slotted the that hole in the motor plate where the rear bracket bolts to the plate, so that it can move when the belt tension is being adjusted. I think it's gonna work great.
Re: Type II power steering box [Re: ProSport] #2722056
12/06/19 02:29 PM
12/06/19 02:29 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
What intake is on that RB?
Re: Type II power steering box [Re: mopardamo] #2723059
12/10/19 06:56 PM
12/10/19 06:56 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Andy, are these available yet? I haven't seen them on your site.
Re: Type II power steering box [Re: MarkZ] #2723483
12/12/19 03:46 PM
12/12/19 03:46 PM
AndyF Online content OP
AndyF  Online Content OP
They are available for my build! Not so sure I'm going to make a product out of it. Probably not a lot of folks who want to spend the money required to do this full conversion. The pump and pulley I bought from Detroit Speed were pretty expensive.
Re: Type II power steering box [Re: AndyF] #2723891
12/13/19 11:39 PM
12/13/19 11:39 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My pump is made by PSC, I got it at Summit for around $220 and it came with the pulley installed. Not real expensive at all.
Re: Type II power steering box [Re: AndyF] #2724167
12/15/19 12:22 PM
12/15/19 12:22 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Andy, these pumps seem to be a popular add on for Gen3 guys. There may be a market for a conversion bracket, especially because it's a singular plate.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Type II power steering box [Re: A39Coronet] #2724191
12/15/19 02:01 PM
12/15/19 02:01 PM
I've seen them on G3 Hemi engines. I think it is a simple conversion since there is a flat area on the engine where the pump mounts. I don't have any G3 stuff in my shop so I don't know exactly how it works.
Re: Type II power steering box [Re: AndyF] #2724264
12/15/19 06:30 PM
12/15/19 06:30 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm looking to do a Hydroboost conversion and need to replace the pump anyways. The Type II stuff seems to have more aftermarket support. If you do decide to make a run of those I'm game. Could probably use one of your throttle brackets for the Sniper EFI too.
Re: Type II power steering box [Re: MarkZ] #2725166
12/18/19 05:06 PM
12/18/19 05:06 PM
A local guy stopped by the other day to get some parts from me and he loved the Type II bracket. He wanted to ditch his old ham can PS pump but didn't know there were any alternatives. So I sold him a set of brackets and told him good luck. He took some pictures of my setup and said he would give it a try. Who knows, he might have his setup running before I get mine done. I'm probably at least 6 months away from getting this project back on the ground.
Re: Type II power steering box [Re: AndyF] #2726263
12/22/19 09:39 PM
12/22/19 09:39 PM
Davis, California, USA
MrBelvedere2 Offline
wow I really like that set up....I would love a set of brackets if you make some. It doesn't really seem too expensive to convert over to that pump.
1965 Plymouth Belvedere II hardtop
Re: Type II power steering box [Re: A39Coronet] #2726334
12/23/19 09:27 AM
12/23/19 09:27 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Where's what I did on my G3, it also doubles as my torque strap mount [I am not selling them/trying to hi-jack Andy's thread]. The third bracket-to-head bolt is behind the pump and countersunk. The spacing and pulley is just right so that it uses a factory 6.1L serpentine belt. The lower mounting is also a little better on the eyes, the pump is in a pretty prominent location when stock. The bottom right bolt on the bracket is 3/8-24 threaded and serves as a mounting point for a torque strap, which ties to the factory sway bar bracket on the k-frame.
Screen Shot 2019-03-11 at 9.48.18 PM.png18813261_1559033294140723_8800620614020919199_n.jpg
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Type II power steering box [Re: GoodysGotaCuda] #2738990
02/02/20 12:26 PM
02/02/20 12:26 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Goody which pump did you use?
Re: Type II power steering box [Re: JAMESDART] #2739174
02/02/20 08:56 PM
02/02/20 08:56 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I bought a race [ball bearing] pump from PSC motorsports. They do a lot of Jeep/off-road stuff that uses these type of pumps. I may end up going back to figuring out a stock style pump since I'd like to add a torquestorm centrifugal supercharger at some point.
2020 RAM 1500
Re: Type II power steering box [Re: AndyF] #2750776
03/10/20 03:30 PM
03/10/20 03:30 PM
Georgia
72440CUDA Offline
72440CUDA  Offline
Georgia
I've been looking into running a KRC pump (GM type II) for my 440 and I was just about to ask if you've looked into the Unisteer bracket... until I read further down the thread, lol!
I started off buying the bracket kit from Unisteer but after I bolted it on I decided it was too crappy of a design to use on my car.
That was the only bracket I could find that was on the market.
I'm interested as well if you have a set laying around. I'll be in Oregon next week.
My plan is to swap over to a 1 wire alt, low mount Sanden A/C compressor, 440 Source 6 rib pulleys. I plan on running hydroboost as well.
