Question for you carb restoration gurus. #2702042
09/29/19 05:58 PM
09/29/19 05:58 PM
Abilene, Texas
fastmark Online content OP
fastmark  Online Content OP
Abilene, Texas
I’ve got two 340 six pack carbs and i need some work on them. Theses carbs had the boosters melted in them from a carb fire I guess. Does anyone replace these properly to look and function like original? JB weld is not what I wanted to do. Thanks.
Re: Question for you carb restoration gurus. [Re: fastmark] #2702164
09/30/19 07:09 AM
09/30/19 07:09 AM
Abilene, Texas
Abilene, Texas
Well, I got a couple of PM’s about the booster replacement. Seems to be a common practice for Hp carb modification. The tool to replace them is a little pricy for a one time job but the boosters are cheap.
Re: Question for you carb restoration gurus. [Re: fastmark] #2702245
09/30/19 12:48 PM
09/30/19 12:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why not post the PM info for all to see?
Re: Question for you carb restoration gurus. [Re: John_Kunkel] #2702334
09/30/19 06:10 PM
09/30/19 06:10 PM
Abilene, Texas
Abilene, Texas
Not sure. I’m sure they have reasons. One said he did not post here much because of all the pop up adds. He repaired the boosters as part of his normal carb restoration for no additional charge but he did not do it as a stand-alone service. The other guy said he has had it done before by the carb anodizing guys and he would check if the new company still did that.
Re: Question for you carb restoration gurus. [Re: fastmark] #2702471
10/01/19 02:24 AM
10/01/19 02:24 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Brasswell carbs used to sell the boosters and tool. Now for tbe hacks... We made a tool out of scrap steel we machined and a flaring tool we cut up. Loose ones tighten nicely with a block of wood wedged in the barrel and a smack on the plate side with an old pushrod.
