I was right, Motor filled with acorns!!! #2701802
09/28/19 06:39 PM
09/28/19 06:39 PM
New York
R/T1968R/T Offline OP
New York
Well I tackled the motor and it was confirmed, acorns in the motor.I said it was in my previous post. https://board.moparts.org/ubbthread...speed-dana-s-match-n96.html#Post2696527. I cleaned out the cylinders, sprayed PB blaster and the motor spins fine. Do you think its safe to fire up?
Re: I was right, Motor filled with acorns!!! [Re: R/T1968R/T] #2701807
09/28/19 07:00 PM
09/28/19 07:00 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Was it built by Squirrels?
Carl Kessel
Re: I was right, Motor filled with acorns!!! [Re: CKessel] #2701814
09/28/19 07:22 PM
09/28/19 07:22 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Gopher Motors
Unless something got hammered in between a seat and valve or got bent when cranking it over previously
If it was a brand new rebuild I would say pull the heads , but that’s not the case so
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: I was right, Motor filled with acorns!!! [Re: bee1971] #2701822
09/28/19 08:00 PM
09/28/19 08:00 PM
New York
New York
When I got the car I turned it by hand, nothing forced. Im going to oil everything up and give it a shot.
Re: I was right, Motor filled with acorns!!! [Re: R/T1968R/T] #2701829
09/28/19 08:32 PM
09/28/19 08:32 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think I'd tear that one down and go through it before I tried to run it. work
Re: I was right, Motor filled with acorns!!! [Re: bobby66] #2701839
09/28/19 08:55 PM
09/28/19 08:55 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
+1 iagree
Me too, a gasket kit is nothing and a clean up of any internal rust before it goes through the oiling system would make the engine last much longer if it is still good now, the rings would probably appreciate the reduction of acorn dust too grin
Re: I was right, Motor filled with acorns!!! [Re: Alchemi] #2701903
09/29/19 07:22 AM
09/29/19 07:22 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Based on the rust in the intake ports I think it's likely the cylinder bores also have rust.
Re: I was right, Motor filled with acorns!!! [Re: bobby66] #2701972
09/29/19 01:06 PM
09/29/19 01:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree or x 3 or one my wind up with a pile of scrap iron. twocents
Re: I was right, Motor filled with acorns!!! [Re: TJP] #2701985
09/29/19 01:33 PM
09/29/19 01:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No way would I run it, that'll just create more damage. Tear it apart & rebuild it if you want it to be right.
Re: I was right, Motor filled with acorns!!! [Re: topside] #2702119
09/29/19 10:26 PM
09/29/19 10:26 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
That's nuts! smile
Seriously, though I would open it up and clean it out. If there is debris in the intake runners you know at least some of the pistons had an open intake valve and it got down in there, too.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: I was right, Motor filled with acorns!!! [Re: wingman] #2702128
09/29/19 10:45 PM
09/29/19 10:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Pull it apart and have a real look inside. How can you possibly believe the cam is going to be OK after seeing all that crap under the intake? What do you think your going to gain by hearing it run? I suspect you will cause a lot more harm then any good that can come from starting it.
Of course, its yours, start it if you feel lucky and feel the need. Next week you can post pictures of the cylinder wall and crank damage. Gene
Re: I was right, Motor filled with acorns!!! [Re: poorboy] #2702202
09/30/19 10:26 AM
09/30/19 10:26 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just pulled the 400 out of an old project truck. I removed one exhaust manifold and found an exhaust port filled with Decon. Those little critters ran all the way up the exhaust, through the muffler and into the head.
Re: I was right, Motor filled with acorns!!! [Re: burdar] #2702267
09/30/19 01:38 PM
09/30/19 01:38 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Years ago Chipmunks totally filled the aircleaner on my wife's car with dog food. Needless to say her car was running like a dog when she asked me to look at it. Arf arf.
