Correct ballast resistor with Mopar Perf Ignition? #2701451
09/27/19 04:05 PM
09/27/19 04:05 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
I installed a Mopar performance electronic distributor with Chrome box ECU in my 1970 440.
I have the following Accel 8140M ignition coil:
Super Stock Universal Performance Coil
SPECIFICATIONS:
Color: Yellow
Maximum Voltage: 42000
Package Quantity: 1
Primary Resistance: 1.400 ohms
Secondary Resistance: 9.2K ohms
Turns Ratio: 94:1
From the info above coil specs I assume I should be running a ballast with approximately 1.4 ohms. I currently have the original points style 0.6 ohm resistor installed. I am thinking I may be asking for trouble with the coil overheating. Should I upgrade to the 1.4 ohm resistor? If so, what brand do you like?
I see these models are available at approx. 1.4 ohms:
NAPA* Echlin* ICR11 (1.35 Ohms)
NAPA Echlin ICR34 (1.4 Ohms)
Lucas* 3BR (1.3 - 1.4 Ohms)
Mopar* DCC-4529795 (1.4 Ohms)
Accel* ACC-150250 (1.35 Ohms)
Standard* RU-4 (1.35 Ohms)
Standard RU-23 (1.2 ohms)
Standard RU-37 (1.4 Ohms)
Thanks in advance for your advice! Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: 70gtx440dana] #2701463
09/27/19 04:28 PM
09/27/19 04:28 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I recall the old school Mopar Performance ignition system upgrade kit came with a 0.5-0.8 resistor
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: 70gtx440dana] #2701468
09/27/19 04:45 PM
09/27/19 04:45 PM
Quote
You're fine as is
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: 70gtx440dana] #2701511
09/27/19 06:45 PM
09/27/19 06:45 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My Mopar catalog says to use a 1 Ohm ballast resistor (Mopar part # P5206436) with the Mopar (# P4120889) yellow Accel coil..
Just my $0.02... wink
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: Sinitro] #2701584
09/27/19 10:53 PM
09/27/19 10:53 PM
Yes Ma wants 1 ohm of ballast with it & Accel wants .7 Do you have .6 measured, as the last (OE) point ballast I ohm'd was 1.6
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: RapidRobert] #2701701
09/28/19 11:56 AM
09/28/19 11:56 AM
Lansing, MI
Lansing, MI
I will check the resistance and make sure I am between 0.6 and 1 ohm. Thanks! Joe
Re: Correct ballast resistor with Mopar Perf Ignition? [Re: 70gtx440dana] #2701759
09/28/19 03:17 PM
09/28/19 03:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have had good results with the Mallory 700 Ballast resistor. It is about 1-ohm. They claim 0.75 Ohm cold, and 1.5 Ohm hot. As far as i can tell they are no longer made or out of stock?
https://www.speedwaymotors.com/Mallory-Ignition-700-Ballast-Resistor-75-1-50-Ohm,27571.html
