Re: CHEAP SPEED PART SECRETS??
[Re: 69B3GT]
#270087
03/29/09 08:49 AM
03/29/09 08:49 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
If you've asked this before, you're probably sick of hearing this but.....$150 junkyard 360 I get the...."stroker crank/put a BB in it" cracks too. I'm sure there's something cheap you can do to a 273 but, can't think of money better spent than on a running 360.
[Re: S/ST 3040]
#270088
03/29/09 09:09 AM
03/29/09 09:09 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A 440 would be the cheapest way to get more power.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: 69B3GT]
#270091
03/29/09 01:16 PM
03/29/09 01:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The cheapest speed thing I've done was putting a good set of adjustable shocks on and dialing in the chassis.... I've picked up more than .5 just in the chassis
[Re: MR_P_BODY]
#270092
03/29/09 01:27 PM
03/29/09 01:27 PM
Posts: 903 Saskatchewan, Canada
cudabin
A set of 3.91 or 4.10 gears would wake thar car up!!!
Next thing would be a 10" torque convertor if it is an automatic.
Get a Thermoquad off a BB from the wreckers and rebuild it yourself.
After that it gets expensive,,,
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: S/ST 3040]
#270093
03/29/09 01:28 PM
03/29/09 01:28 PM
Quicktree
[Re: ahy]
#270095
03/29/09 02:52 PM
03/29/09 02:52 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Well i didnt mean just for the 273, i meant small things that have been done over the years to help a car out just a little. And my moms car has 340 manifolds on it and they are going to headers soon so ill probally toss those on the 273, as for carb and intake i had an LD340 layin around and my buddy is letting me borrow his 650 demon....yeah i know its too big but it runs better than the 2bbl ever could. The car is on a pretty decent tune. timing is 8*BTDC and it has new points, plug wires, superstock coil...all stuff we had in the garage. As for going the 360 route my dad donated a virgin 71 340 block,crank,J heads,pistons,rods,main caps, and some other stuff, but it needs to be completely rebuilt so itll have to wait.
[Re: 69B3GT]
#270096
03/29/09 04:18 PM
03/29/09 04:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
On a 300hp 360 crate motor the 340 manifolds only made about 5 more hp than the 273 manifolds so I think you will not notice the differance. You could sell the 340 manifolds and get almost enough money for TTIs that made like 25 hp more than the 340 manifolds.
One of my favorite cheap upgrades is a JY thermo-quad in place of a 2bbl, or even in place of a small 4bbl.
Thin head gaskets are a good one. MOost replacements are .040 - .060 thick and investing in steel shim gaskets for a BB or the now discontinued mpoar .028 gaskets for a SB can bump compression a nice bit.
For small blocks I love the change from putting magnums on in place of any other factory head.
High ratio rockers always work good for me on mild cam motors. You can get them for a couple hundred bucks and a pair of valve cover gaskets are all thats required to put them on.
A mopar, or similar electronic ign up grade or even a piece it together your self electronic, works great over points.
For the 904 guys the low gear sets from the mid 80s and later low gear ratios work great, especially on a milder motor.
[Re: HotRodDave]
#270098
03/29/09 04:28 PM
03/29/09 04:28 PM
Posts: 4,770 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Old days old ways- Better intake manifold, hotter cam/lifters and headers w/dual exhaust. Hyd cam and lifters are avail new for a great price. Intakes used are all over. Headers for an early A body may not be cheap. But use your 340 manifolds with a good dual exhaust.
Keep old mopars alive.
[Re: hemisurfer]
#270100
03/29/09 05:01 PM
03/29/09 05:01 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the .028 SB head gaskets are available again..
P4120094 or MR Gasket 1121
same gasket..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: hemisurfer]
#270101
03/29/09 05:28 PM
03/29/09 05:28 PM
69B3GT
Mira Loma, CA
N20 - Cheap, tunable, go fast, scatter parts . Now your racing.
haha ill stay away from N20, i was raised with the thought that thats for people who cant build motors, no offense i just dont believe in it. The 340 manifolds that we have are off a 73? i think ill look when we pull the car out later, Maybe ill talk to my dad about selling the 340 and getting a 360 magnum, how much more would parts be and how much power can those motors make?
Cmon now almost 600 views and barely anyone has suggestions....im open to anything, and yes ive thought about throwing a big block in it but i just think it would bee too nose heavy
[Re: gch]
#270103
03/29/09 06:38 PM
03/29/09 06:38 PM
Posts: 535 Ohio
racerAL
Ohio
haha ill stay away from N20, i was raised with the thought that thats for people who cant build motors, no offense i just dont believe in it....who ever raised u obviously hasn't seen any PRO MOD or 10.5 shootout racing..those guys run TONS on NOS and I'm sure they can build engines..nitrous when used properly can be an inexpensive way to make power.. ..with the options u have i say there is no replacement for displacement...use the biggest engine at your disposal...and get as much comp. as you can.(i.e. mill heads/deck block).u seem to have a good enough collection of parts to make yourself a nice little hot rod.. good luck...........Al
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
