Re: CHEAP SPEED PART SECRETS??
[Re: 69B3GT]
#270106
03/29/09 07:55 PM
03/29/09 07:55 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
well when i was 17 just few years ago i put a sniper kit on my very mild/stock 360. with the 150 shot it went from 13.9's to 12.35. A wise man once said "it makes the cripple get up and walk"
On another note...probably gears with sticky street tires. there are tons of things that come in to play. whats the combo???
jm
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
Post deleted by Defbob
[Re: emarine01]
#270107
03/29/09 07:56 PM
03/29/09 07:56 PM
[Re: 69B3GT]
#270110
03/29/09 08:19 PM
03/29/09 08:19 PM
Posts: 160 Florida
hemisurfer
N2O with a set of headers, fuel system, and some carb and timing tweaks will yield tons of HP per dollar spent. Chemical supercharging. I agree not my choice either but you said "cheap" Expensive? How about alcohol injected, supercharged, tube chassis, four link, fabricated rear housing, glass doors trunk and hood, plexi windows and a lenco.
Chris
[Re: hemisurfer]
#270112
03/29/09 08:51 PM
03/29/09 08:51 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
When I was 18 I found a 1" spacer for an Autolite 2-bbl carb (same flange as Holley) and bolted it to a stock iron intake by drilling 4 holes and using socket head cap screws. It didn't line up real well, so I took a grinder to the intake and laid waste to it. I got a 500 CFM Holley 2-bbl from a roundy-round racer, that hilljack setup was worth about .3 in ET over the stock 2-bbl.
Also a cheapo recurve kit for your distributor, use the lightest pair of springs and ditch the vacuum advance.
Take those J heads that you have and have them milled about .040, spend a weekend with some burrs and sandpaper rolls and clean up all the ports.
Get the cheapest set of $150 1-5/8 headers you can find, buy new and pull them off and repaint with VHT every spring.
Discard every unneccessary piece of street equipment, heater box, radio, horn, back seat, carpet, everything in the trunk. Then get underneath your car with a can of stripper, scrapers, screwdrivers, and steel wool. We took 30 lbs. of undercoating and dirt off of a guy's car once.
That should keep you busy for a few weeks, I'll try to think of a few more.
[Re: cgall]
#270113
03/29/09 08:59 PM
03/29/09 08:59 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Many years ago, some guy named McCandless told me the best way to go faster was take weight out of the car. His words were something like "It don't break, it don't wear out and you don't have to work on it" Has been good advice for me.
[Re: 69B3GT]
#270114
03/29/09 09:53 PM
03/29/09 09:53 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
Cmon now almost 600 views and barely anyone has suggestions....im open to anything, and yes ive thought about throwing a big block in it but i just think it would bee too nose heavy
Here are a couple of proven go quicker things you can do for next to zero $$$, if you have some basic fab skills. I've posted these before with the results, but I'll do it again for you. First is a fresh air set up. You can do it diff ways, I first made a ram air set up where I attached some round, flexable dryer ducting to an empty air cleaner and ran it down to attach to the bottom of the bumper. This was worth about a tenth and a half over a paper element in a 14" air cleaner assy. I ditched that in favor of a sealed air pan (pic). This was about 28 hun better than the paper filter deal. When made the pan I wanted to test it against the filter AND then against the ram air on the same day in back to back tests. This was the results. This was with my old 360 motor. First pass with paper filter set up was 11.55. Took that stuff off and put the ram air set up on it for pass 2. It went 11.41. took that off and put on the air pan, sealed to hood scoop and it went 11.27. In all of this I spent less than $15. The next "trick" is in next reply.
[Re: StrokerPost]
#270116
03/29/09 10:02 PM
03/29/09 10:02 PM
Posts: 5,618 long island NY
Ari440
long island NY
a stop sign as an airbox to seal to the sixpack hood no money needed to do this 11.00s to 10.85 when I had the 440
1.39 9.85 - 137 mph
[Re: 69B3GT]
#270117
03/29/09 10:07 PM
03/29/09 10:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well not using N20 is a personal choice, nobody in my family has used it and there have been some fast cars and still are some fast ones. Ive toyed with the thought of it but ill just build some fire breathing monster and try to tear up my buddies aluminum headed small block chevy on a 150 shot....ill just set up the suspension and everything since he is on stock suspension and a stock convertor....ill just have to beat him at the line and not look back
There's 2 ways to build a car.... lots of HP or make it light.... I've always believed in the latter because you can go quick and be easier on parts
[Re: 70AARcuda]
#270118
03/29/09 10:26 PM
03/29/09 10:26 PM
Posts: 15,491 the boonies
aarcuda
the boonies
the .028 SB head gaskets are available again..
P4120094 or MR Gasket 1121
same gasket..
thanks. i just ordered a set. i'll change out those fel pro 1008's (.039-.042" thick) sometime and give these a shot
[Re: ccdave]
#270120
03/29/09 11:27 PM
03/29/09 11:27 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The mr gaskets have a lot bigger bore than the mopar performance ones did or the fel pro 1008 so no significant compression gain from the mr gasket. If however you went from the 1008 to the mopar you could gain around 1/2 point depending on the rest of the combo.
My problem with nitrous has always been that I can't refill it for $2 gal at the gas pump.
[Re: 69B3GT]
#270125
03/30/09 04:23 AM
03/30/09 04:23 AM
StrokerPost
Missouri
See the air cleaner set ups and the air dam under the car are things im talking about, those are cool and they dont take more then a few bucks and some genius designs, ive thought about those but i cant find a cheap hemi scoop so itll have to wait. So on the air cleaner set ups do you just measure out the bottom of your hood where the scoop is then make a pan and use foam to seal it?
Basically yeah. here is a pic of the pan on the motor and the whole in the hood just above. I use a bolt on Harwood areo scoop, the smallest they had.
