Clutch Pedal Return Spring #270049
03/28/09 11:46 PM
03/28/09 11:46 PM
Ont. Canada
10.90 Racer Offline OP
super street
super street
Ont. Canada
What is used for a clutch pedal return spring? I just converted my Dart back to a 4spd and the pedal does not return. It does have some return spring about 1/3 the way down but after that it goes over center and wants to stay towards the floor.
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270050
03/29/09 12:21 AM
03/29/09 12:21 AM
hemisurfer Offline
hemisurfer  Offline
Chris
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270051
03/29/09 12:26 AM
03/29/09 12:26 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Are you saying that there isn't one connected to the clutch peddle under the dash? It's not really needed if you have a return on the clutch fork down below.You need one or the other.
Re: Clutch Pedal Return Spring [Re: rowin4] #270052
03/29/09 12:36 AM
03/29/09 12:36 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Dont most performance clutch manufacturers suggest removal of the over-center spring anyway?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Clutch Pedal Return Spring [Re: 69L78Nova] #270053
03/29/09 12:43 AM
03/29/09 12:43 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
It depends on what style of pressure plate is used.
Re: Clutch Pedal Return Spring [Re: 69L78Nova] #270054
03/29/09 12:43 AM
03/29/09 12:43 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Depends upon type of pressure plate..
If a diaphram.. Yes
If B & B 3 finger.. No.
Re: Clutch Pedal Return Spring [Re: 69L78Nova] #270055
03/29/09 12:44 AM
03/29/09 12:44 AM
rowin4 Offline
rowin4  Offline
I don't know about the manufacture's but all that is needed is a good spring on the clutch fork to pull the throw out bearing off the pressure plate,the peddle doesn't have to return to full up position.
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270056
03/29/09 04:52 AM
03/29/09 04:52 AM
Netherlands
72Challenger Offline
Netherlands
I assume you have already completed the swap? As when you haven't completed the linkage from the pedal to the pressure plate the pedal want to stay down after it's overcentered. Otherwise it's what Rowin4 says...
Re: Clutch Pedal Return Spring [Re: 72Challenger] #270057
03/29/09 09:36 AM
03/29/09 09:36 AM
Ont. Canada
super street
super street
Ont. Canada
http://cgi.ebay.com/ebaymotors/1968-72-M...s#ht_1051wt_968
Is this the over center spring?
I already have an over center spring. Are there 2 springs under the dash?
I'm running a Soft Lok clutch, I'm now thinking I don't need an over center spring........
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270058
03/29/09 10:15 AM
03/29/09 10:15 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
One spring under dash.
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270059
03/29/09 10:18 AM
03/29/09 10:18 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
I was wondering if you had the swap done yet.
87 dakota 6.1 hemi
Re: Clutch Pedal Return Spring [Re: Michael] #270060
03/29/09 11:20 AM
03/29/09 11:20 AM
Ont. Canada
super street
super street
Ont. Canada
Well I think I'm going to remove the overcenter spring. This Clutch only has 1200 lbs at the moment.........and should go much lower.
Re: Clutch Pedal Return Spring [Re: Glen440] #270061
03/29/09 11:22 AM
03/29/09 11:22 AM
Ont. Canada
super street
super street
Ont. Canada
Getting there. I'm almost to the point of just playing with the small stuff. Time management has been a real issue.
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270062
03/29/09 01:29 PM
03/29/09 01:29 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
I had to remove the spring under the dash when I went to the light pressure pp otherwise it would stay on the floor.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Clutch Pedal Return Spring [Re: gearjammerdart] #270063
03/29/09 05:18 PM
03/29/09 05:18 PM
Ont. Canada
super street
super street
Ont. Canada
Donald
Cool!! Thanks
Re: Clutch Pedal Return Spring [Re: 10.90 Racer] #270064
03/29/09 05:38 PM
03/29/09 05:38 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Yup, lose it. The overcenter spring actually helps hold the pedal down once you reach a certain point.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
