Help---Mystery problem !!
#2698844
09/19/19 12:57 AM
09/19/19 12:57 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Long story here...........I hope someone can throw me some ideas ?
Right now -----My dart----fresh motor . I have no spark from the coil . Months ago i fired up the car with this motor , and the timing was WAY off . It sounded crisp but wouldnt idle. This is just firing it up --so I had a buddy help fire it back up and the timing light said 60 deg btc ! So i backed it down to 30 and it wouldnt even start at normal timing...just sputter. Seemed normal when the timing light said 60btc....?
I recently looked at everything--looked at cam lobes , rockers , lash , cleaned the carb , timing chain+ gears .....Full on Leak down test----.even tried a new UNILITE that burned up in a couple minutes....a new coil , and a new MP ecu .
Now... Lets back up .......before i fired up the fresh motor last winter , i had a mishap. My buddy handed me the battery to put in the trunk , and i didnt have the light in the trunk.........i said ---Are you sure the Positive is to the rear? he said Yes................nope..... my dumass hooked it up.....backwards... we turned car on and had nice smoke by the engine....it burned a fusible link. Im still kicking myself for that.
SO----my buddy bought me a new chrome MP ecu.....I had the battery tested at Oreilly--tests perfect.. Nothing else looks hurt / burnt .
so tonight..i went and tried again--no spark and the ECU transistor gets REAL hot !! I had another ecu i plugged in---same thing--transistor gets super hot . I have 11.8v at both sides of the ballast...and both sides of the coil with ign ON . This is a MP distributor .
Nothing as far as wiring has changed on the car during this fiasco....
Im lost here............do i have 2 bad ECU boxes ? ive swapped coils..........the car ran weirdly with the new Unilite too...like the ignition is wayy screwed up . But it did RUN...........now..no spark ..
Yes i would love to scrap it all and put a switch panel in and a Msd setup---but no $$$$ to do that. Id like to find whats wrong with this setup because its worked great since 2008 !!
Re: Help---Mystery problem !!
[Re: 493_DART]
#2698943
09/19/19 11:32 AM
09/19/19 11:32 AM
RapidRobert
I would set the damperner at 15 BTDC on #1 compression (or your known/preferred initial #) then set the dist so the magnet is dead even with the tooth & the #1 plug wire is above or near above the rotor. But first pull the yellow (ign) wire off of the starter relay to disable the starter & pull the #1 plug wire out of the dist cap & hold it 1/4 from a ground & seperate the dist zigzag pickup connector & drag the male terminal on the body half of the connector across the intake surface to make/break ground & see if the coil wire sparks to ground with the key "on" & with a helper holding it to "crank". this takes the dist out of the picture. Holler back EDIT what Squirrel said, confirm you have the right stuff in there
[Re: RapidRobert]
#2698954
09/19/19 12:00 PM
09/19/19 12:00 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Screw a top dead center stop in cylinder number one and carefully check top dead center to make sure your damper didn't spin to double-check your timing issue. Lots of out of Country dampers are spinning.
[Re: pittsburghracer]
#2698955
09/19/19 12:07 PM
09/19/19 12:07 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Screw a top dead center stop in cylinder number one and carefully check top dead center to make sure your damper didn't spin to double-check your timing issue. Lots of out of Country dampers are spinning. Yep .
#2698993
09/19/19 02:45 PM
09/19/19 02:45 PM
493_DART
Worst Weather USA
Screw a top dead center stop in cylinder number one and carefully check top dead center to make sure your damper didn't spin to double-check your timing issue. Lots of out of Country dampers are spinning. the damper isnt going to make my coil Not spark...im thinking its the coil and/ or the ecu............I can double check the dist pickup but i think i did and it was giving a pulse ...........again ive swapped both BUT , i dont know if the replacements were any good to begin with ! yes i had the Unilite wired correct I think the clue here is nothing changed with wiring....it ran great until the battery incident .....i have no spark out of the coil , and the ecu Transistor is getting super hot . I have a Kill/ Run switch--its working ..and i have a starter button...its working . 11.8vdc to coil pos/ neg and same at ballast terminals if my timing is off....im sure would still have spark out of the coil ...weather its 40 deg btc or 0 btdc
[Re: 493_DART]
#2698998
09/19/19 03:18 PM
09/19/19 03:18 PM
Posts: 4,457 Washington
madscientist
Washington
Screw a top dead center stop in cylinder number one and carefully check top dead center to make sure your damper didn't spin to double-check your timing issue. Lots of out of Country dampers are spinning. the damper isnt going to make my coil Not spark...im thinking its the coil and/ or the ecu............I can double check the dist pickup but i think i did and it was giving a pulse ...........again ive swapped both BUT , i dont know if the replacements were any good to begin with ! yes i had the Unilite wired correct I think the clue here is nothing changed with wiring....it ran great until the battery incident .....i have no spark out of the coil , and the ecu Transistor is getting super hot . I have a Kill/ Run switch--its working ..and i have a starter button...its working . 11.8vdc to coil pos/ neg and same at ballast terminals if my timing is off....im sure would still have spark out of the coil ...weather its 40 deg btc or 0 btdc If you killed the Unilite, that's a sign there's an issue somewhere.
[Re: madscientist]
#2699003
09/19/19 03:35 PM
09/19/19 03:35 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Verify that the distributor is turning when the engine cranks. The distributor gear pin could be sheared. It can still turn some on friction.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: firefighter3931]
#2699649
09/21/19 09:52 PM
09/21/19 09:52 PM
Posts: 62 montreal, quebec,canada
7e5dartsport
if you have a 4pin ballast resistor, test its resistance. one side should be 5 ohms, the other 0.5 ohms. if you have a 2pin resistor, it should be from 0.25 to 0.5 ohms. all these tests with the connectors at the resistor disconnected for testing.
fully legal sounds the same as full illegal...
[Re: 493_DART]
#2707833
10/17/19 08:21 PM
10/17/19 08:21 PM
493_DART
Worst Weather USA
Update---- still have 12v everywhere it should swapped in a new ECU ..........no spark ....grounded ecu case to battery neg direct ........no spark brand new coil ........no spark , checked and swapped coil output cable . pulled dist out to check pickup ---works fine . swapped ballasts--both test good I give up ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) going with new ignition..maybe a ready to run setup .
[Re: Hemi_Joel]
#2707834
10/17/19 08:25 PM
10/17/19 08:25 PM
493_DART
Worst Weather USA
Verify that the distributor is turning when the engine cranks. The distributor gear pin could be sheared. It can still turn some on friction. verified .
#2707835
10/17/19 08:26 PM
10/17/19 08:26 PM
493_DART
Worst Weather USA
Try reversing the pickup wires. I had a similar problem in the past nd the car wouldn't even fire until I reversed the pickup wires.
Ron the plug and dist. wiring havent changed at all since it ran .
[Re: 493_DART]
#2707843
10/17/19 08:52 PM
10/17/19 08:52 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
Ron the plug and dist. wiring havent changed at all since it ran . Something has changed or it would still run, correct ![work work](/ubbthreads/images/graemlins/custom/work.gif) I would be checking the grounds with a ohm meter between the ECU, coil resistor and the distributor housing and block ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Cab_Burge]
#2707873
10/17/19 09:59 PM
10/17/19 09:59 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
Just a shot in the dark...about 100yrs ago I had a 67 Barracuda w/440... anyway one nite I went to a friends house and when I tried to leave no start /spark... every thing looked good just no spark. then I found one of the wires from the MSD-6C had gotten trapped under the Valve cover. Once I found and resolved the issue (plus learned another lesson about MSD's) it started right up...just a thought ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Cab_Burge]
#2708108
10/18/19 02:25 PM
10/18/19 02:25 PM
493_DART
Worst Weather USA
Ron the plug and dist. wiring havent changed at all since it ran . Something has changed or it would still run, correct ![work work](/ubbthreads/images/graemlins/custom/work.gif) I would be checking the grounds with a ohm meter between the ECU, coil resistor and the distributor housing and block ill go over grounds with the meter 1 more time...i know the block was good--and i had a direct ground from Batt to Ecu... ill check wiring again but i had 12v everywhere it should be-----
