Spool to a limited slip diff #2698316
09/17/19 08:50 AM
09/17/19 08:50 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all,
I am looking to buy a car with a Dana 60. It currently is running a mini spool with 3:45 gears, I am not to keen to running that on the street. What do I all need to convert it to a limited slip Sure Grip set up?
Thanks!
1969 Dodge Dart Swinger
Re: Spool to a limited slip diff [Re: MikeyT] #2698429
09/17/19 12:32 PM
09/17/19 12:32 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Something like this. Probably some other smaller bits but I can't help with that. Dr. Diff is one of several other sources if you can't find one locally.
https://milwaukee.craigslist.org/pts/d/milwaukee-dana-60-power-lok/6967934897.html
Re: Spool to a limited slip diff [Re: MikeyT] #2700626
09/24/19 10:55 PM
09/24/19 10:55 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Definitely check the backlash BEFORE you disassenble it to remove the mini spool and return it to that lash. It may be looser than the original range when first set up due to wear....
Re: Spool to a limited slip diff [Re: MikeyT] #2700862
09/25/19 05:06 PM
09/25/19 05:06 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Originally Posted by MikeyT
Hi all,
Thanks!
Did you mean 3.54 gears? What ratio will you want?
You will need to know what gear ratio you are going to use and what spline your axles have before you look for a suregrip.
