Re: Front end rebuild
[Re: 68SportSatvert]
#2698334
09/17/19 09:13 AM
09/17/19 09:13 AM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Proforged is a better choice today. Available from Rockauto, Amazon, Ebag, etc.
Master, again and still
[Re: moparx]
#2698573
09/17/19 09:01 PM
09/17/19 09:01 PM
Posts: 1,758 KS
68SportSatvert
KS
#2698581
09/17/19 09:20 PM
09/17/19 09:20 PM
RapidRobert
Vert there are no stupid questions. Yes 11/16 on both ends & need the C body 11/16 tie rod ends. Is 11/16 needed I cannot say but many many cars are doing fine with the 9/16 ends
#2698666
09/18/19 09:02 AM
09/18/19 09:02 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I went to Rock Auto and looked at the ProForged parts. I have a question about the adjusting sleeves for the tie rods. I read somewhere that you should upgrade to the 11/16" adjusters. My car will have a rebuilt 383 with an Eddie Performer RPM, Holley 670 Street Avenger and a small cam. No high go here. Do I really need to upgrade the sleeves? If so, is the larger 11/16" on both ends? I'm new to this so please be kind of you think this is a stupid question. Thanks in advance. The autocross guys like the rigidity of the larger tie rods, but they are not at all necessary for most of us. I have never ran anything other than the stock smaller tie rods on any of my builds, whether they were going on the street or to the drag strip.
[Re: DaveRS23]
#2698695
09/18/19 11:10 AM
09/18/19 11:10 AM
Posts: 19,355 north of coder
moparx
at one time, the 11/16" C-body sleeves and ends were cheaper than the traditional 9/16" size. i don't know if it's like that now or not. last time i looked was 10 or more years ago.
[Re: moparx]
#2698706
09/18/19 11:56 AM
09/18/19 11:56 AM
RapidRobert
if the 11/16 are still cheaper then for sure go for it otherwise unless you are autocrossing/circle track or some other serious corner carving, 9/16 will suffice.
#2698790
09/18/19 08:40 PM
09/18/19 08:40 PM
RapidRobert
use the old ones if they are 11/16 (matches your 11/16 tie rod ends). If your old ones are 9/16 & you have ordered 11/16 tie rod ends then yes you will need new or used 11/16 sleeves
