69 RR Convertible panel question #2262010
03/02/17 02:15 AM
03/02/17 02:15 AM
cbusters Offline OP
cbusters  Offline OP
There is a filler panel that mounts behind the back seat with screws to the cross brace above the convertible top pump. It attaches to the large interior plastic panels and also anchors the boot front edge. What is this called in the parts manual and where is it located? Perhaps the code? Mine is missing and I am trying to locate all the little parts and want to know what to ask for. TIA
Re: 69 RR Convertible panel question [Re: cbusters] #2262079
03/02/17 10:07 AM
03/02/17 10:07 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
PM me and i will send you some photos of the part. Larry
Re: 69 RR Convertible panel question [Re: cbusters] #2262674
03/03/17 02:55 PM
03/03/17 02:55 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Is '66-70 b body the same? I have a nice one if you need it.
Re: 69 RR Convertible panel question [Re: cbusters] #2262814
03/03/17 07:57 PM
03/03/17 07:57 PM
Chicago
PurpleBeeper Offline
Chicago
Dang, I don't know the name, but I'm sure 68-70 is the same...not so sure about 66-67, but you never know.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 69 RR Convertible panel question [Re: cbusters] #2697413
09/14/19 10:47 AM
09/14/19 10:47 AM
Washington
Dan C Offline
Dan C  Offline
Washington
Hi, I Have the same question. I realize this is an old post, but, I have spent hours looking through the assembly manual as well as searched threads with no luck. I have the panel, at least I think most of it, just trying to figure out how it all gets mounted back there. I bought the car as a basket case in boxes, so I never took it apart. Any help would be greatly appreciated. Thanks, Dan
Re: 69 RR Convertible panel question [Re: Dan C] #2697573
09/14/19 07:22 PM
09/14/19 07:22 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Re: 69 RR Convertible panel question [Re: 70runner] #2697659
09/15/19 03:51 AM
09/15/19 03:51 AM
Washington
Dan C Offline
Dan C  Offline
Washington
OK, thanks. Looks like the top piece is missing on mine. Is that spot welded on?
Re: 69 RR Convertible panel question [Re: Dan C] #2697660
09/15/19 04:04 AM
09/15/19 04:04 AM
Washington
Dan C Offline
Dan C  Offline
Washington
Also, any idea where these go?
Re: 69 RR Convertible panel question [Re: Dan C] #2697676
09/15/19 07:53 AM
09/15/19 07:53 AM
cbusters Offline OP
cbusters  Offline OP
I did not have those parts on my RR Conv and it is completed.
Re: 69 RR Convertible panel question [Re: cbusters] #2697694
09/15/19 09:46 AM
09/15/19 09:46 AM
California
biggE Offline
biggE  Offline
California
It's a molding strip that covers the cross brace between the wheel wells. On the back side of the brace the strip that holds the well liner is screwed to it. The molding piece sits on top of the brace and at each end is a screw that holds the ends to the ears that are part of the rear interior panels.
Re: 69 RR Convertible panel question [Re: Dan C] #2697788
09/15/19 03:31 PM
09/15/19 03:31 PM
70runner Offline
70runner  Offline
Don't recognize the top (black) piece. Looks like it may be some sort of header panel with cutouts for convertible latches, but not b body.
Next group looks like window channel fuzzies, window sweeps.
Don't recognize the final group, though they bare slight resemblance to the alum piece that attaches to rear of cross brace, to hold well cover.
Here's another pic of the cross brace, I believe it's a single piece, not welded. The holes are reliefs for attaching the alum piece.
Re: 69 RR Convertible panel question [Re: 70runner] #2697951
09/16/19 07:04 AM
09/16/19 07:04 AM
Washington
Dan C Offline
Dan C  Offline
Washington
Awesome, thank you very much!
