Edelbrock STR 12 on the car! #2696540
09/11/19 12:51 PM
09/11/19 12:51 PM
Moncton, New Brunswick
hemidart1 Offline OP
Thanks to Gary and Mike (my restoration/mechanic guys) who can make anything work. It took a lot of fabrication to get the carbs, linkage and valve covers etc to work with this intake! The intake was NOS and I really wanted something on the car that would take you back to the old C/FX days of making a 273 run in that class....even though the engine in the car is now a 360.
1967 Hemi GTX
1969 Chrysler 300
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2696561
09/11/19 01:57 PM
09/11/19 01:57 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
cool
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Edelbrock STR 12 on the car! [Re: Jerry] #2696567
09/11/19 02:14 PM
09/11/19 02:14 PM
oregon
greendart408 Offline
oregon
Neat, worth it, that intake come from oregon by chance?
Re: Edelbrock STR 12 on the car! [Re: greendart408] #2696582
09/11/19 02:59 PM
09/11/19 02:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Very cool looking.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Edelbrock STR 12 on the car! [Re: greendart408] #2696594
09/11/19 03:52 PM
09/11/19 03:52 PM
Actually the intake was local out here in eastern Canada.
1967 Hemi GTX
1969 Chrysler 300
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2696637
09/11/19 05:49 PM
09/11/19 05:49 PM
Have you driven it yet?
I built a 383 hot street and strip motor for a customer who became a friend that had bought the Eddy STR and a pair of either Holley 600 or 650 D.P. carbs, I built it based on him using a good race converter, good ignition, fuel system and 4.56 gears in the back with short slick race tires to fit his 1963 Dart 270. He got in a rush to drive it and ended up with a stock converter, stock 2.43 gears in the 7 1/4 rear end with tiny rear tires and stock fuel system rant down
That combination was very lazy below 3000 RPM but once it got above that it would set you way back in the seat grin up
Good luck on your use with this set up up
Let us know your results please work
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2696666
09/11/19 07:16 PM
09/11/19 07:16 PM
oregon
oregon
Ok I had to ask, a buddy of mine had a str12 nib with a nib linkage kit. Said he sold it a yr or 2 ago.
Re: Edelbrock STR 12 on the car! [Re: greendart408] #2696667
09/11/19 07:25 PM
09/11/19 07:25 PM
It actually took two linkage kits to fabricate the one you see in the car.
It takes a lot of custom work to get these to work.
1967 Hemi GTX
1969 Chrysler 300
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2697017
09/12/19 09:27 PM
09/12/19 09:27 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If it runs like it looks , you have clearly done something right with you life.
Very cool.
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2697020
09/12/19 09:36 PM
09/12/19 09:36 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I can't imagine that linkage working correctly (as in the carbs opening the same amount) when one of the arms (where the links attach) is pointed forward and the other is pointed back. If you say it works, I'll have to take your word for it.
Re: Edelbrock STR 12 on the car! [Re: John Brown] #2697866
09/15/19 08:37 PM
09/15/19 08:37 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If the lengths of the arms are the same, then they should open the same
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Edelbrock STR 12 on the car! [Re: astjp2] #2697928
09/15/19 11:51 PM
09/15/19 11:51 PM
iagree scope
I've set up tunnel ram linkages for cross mounted dual Holley carbs with the arms on the shafts pointed towards the front of the carbs at around a 45 degree forward and the moved them so they where mounted around 45 degrees to the rear, forward works better up
I also experimented with the side linkages and bell cranks at 45, 90 and around 120 degrees from straight up shruggy
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2697936
09/16/19 01:49 AM
09/16/19 01:49 AM
AndyF Offline
AndyF  Offline
Looks cool. Be interested to know how it works. Those cross ram manifolds usually don't work very well on the street so good luck sorting that combo out. The vacuum secondaries might help. Hopefully you added a wide band in each head pipe so you can figure out what is going on with the fuel distribution. The factory guys didn't have wide bands back in the 60's which is probably why they eventually gave up on cross ram intakes.
Re: Edelbrock STR 12 on the car! [Re: AndyF] #2697940
09/16/19 02:22 AM
09/16/19 02:22 AM
Mopar engineers design the long cross rams in 1958. in 1961 they shorten the runners up and increased the intake and exhaust port sizes to make the Max Wedge package that had the shorter intake runners and a lot bigger plenum area under the carbs.
I'm not sure when and who came out with the tunnel ram intakes which ended upmaking the cross rams intakes obsolete work shruggy
I wasn't overly impress with the Eddy STR intake on that 383 motor at the time we used it and now after owning and driving several different cars with stock M.W motor and then later owning and driving a hemi cross ram motor in a drag car I can say there are far better parts than the Eddy STR intakes blush
Re: Edelbrock STR 12 on the car! [Re: hemidart1] #2768896
04/27/20 10:24 PM
04/27/20 10:24 PM
Runs great. Just put the first 100 miles on it.
1967 Hemi GTX
1969 Chrysler 300
Re: Edelbrock STR 12 on the car! [Re: astjp2] #2768991
04/28/20 08:28 AM
04/28/20 08:28 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The lengths match, but the throttle movement per degree of shaft rotation will not.
A lever @ 12 o'clock will move more from a horizontal lever pulling backward than a lever @ 1 o'clock.
A lever @ 3 o'clock won't move at all.
A lever @ 6 o'clock will move the other way.
Boffin Emeritus
Re: Edelbrock STR 12 on the car! [Re: polyspheric] #2769068
04/28/20 12:04 PM
04/28/20 12:04 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
if cross rams was junk from 58 to 61 why did they put them on 1968 race hemi cudas and darts ??
Re: Edelbrock STR 12 on the car! [Re: HEMI472] #2769121
04/28/20 02:03 PM
04/28/20 02:03 PM
The long B and RB long ram intake where never used on any Hemi motors, ever scope They where introduced on the 1959 Chrysler 300 with the standard intake port size heads with bigger valves and some where put on some B motors in 1958 as a race package that was not promoted back then is what I have heard but not verified by anyone at Chrysler confused
The 1964 race hemi came with the aluminum cross ram intake like the Max wedge cars came out with in 1962, some of the very early ones had AFB carbs like the 1964 Max wedge motors had. The A990 race hemi drag cars had Mag cross rams intake that year with the SS Holley carbs only. Mopar went back to the aluminum hemi cross rams in 1968 for the Hurst Darts and Baracuda scope
Re: Edelbrock STR 12 on the car! [Re: HEMI472] #2769149
04/28/20 03:00 PM
04/28/20 03:00 PM
AndyF Offline
AndyF  Offline
1. Because it was all they had
2. Because they didn't know any better
3. Because it looked cool
4. Because other people were doing it
Re: Edelbrock STR 12 on the car! [Re: AndyF] #2769176
04/28/20 04:04 PM
04/28/20 04:04 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
sorry i did not mean 58 to 61 i was talking about cross rams in general if you read the post they say cross rams are not that good
