Spot Weld Cutter #2696166
09/10/19 02:42 PM
09/10/19 02:42 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
What is the best spot weld bit or cutter that you've used ? I need to remove a bunch of sheet metal from a parts car without doing too much damage to the parts car.
Re: Spot Weld Cutter [Re: 2abodymcodes] #2696188
09/10/19 03:36 PM
09/10/19 03:36 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
i use Blair spot weld cutters. seem to last longer than the cheaper ones
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: Spot Weld Cutter [Re: mdwyer] #2696223
09/10/19 05:03 PM
09/10/19 05:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have Blair and whatever Eastwood sells, both seam to be fine. Never had an issue with either. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Spot Weld Cutter [Re: mdwyer] #2696224
09/10/19 05:04 PM
09/10/19 05:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I use a small drill bit to start a pilot hole and then the Blair spot weld cutter.
Re: Spot Weld Cutter [Re: Morty426] #2696250
09/10/19 06:09 PM
09/10/19 06:09 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
I use this Blair spotweld cutter.No need for pre drill.
Re: Spot Weld Cutter [Re: 2abodymcodes] #2696286
09/10/19 07:17 PM
09/10/19 07:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Personally, I have had better service with the drill bit style of spot weld cutter than I have with the toothed ones. I keep breaking the teeth on the toothed ones. The drill bit type are available in 8mm and 10mm. I keep both since they are cheap. And they like to be turned slooooooooowwwwww so as to not build up heat. I can use a drill bit style one for a long, long time because it doesn't have teeth to break off.
https://www.ebay.com/itm/10-mm-COBALT-SPOT-WELD-CUTTER-WELDER-DRILL-BIT/230756723524?epid=1258453770&hash=item35ba2c2b44:g:FlYAAOSwd4tT82yr
Master, again and still
Re: Spot Weld Cutter [Re: DaveRS23] #2696299
09/10/19 08:44 PM
09/10/19 08:44 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
split point drill bit 5/16 and 3/8 sold at ace hardware
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Spot Weld Cutter [Re: 1969gtx] #2696457
09/11/19 10:22 AM
09/11/19 10:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The Blair cutter is the hot ticket. I've used the cheapie cutters and had decent results but if you need to do more than a couple spots the things don't last so you're better off spending a bit more and saving yourself the frustration. Also get yourself a set of the panel splitters - these are hard flat blades you hammer between the panels after drilling out the spotweld to split the panels (you'll rarely drill out the weld perfectly!!)
I found the cutters break if they are able to wander. If you drill a dimple or even a hole right through the panels so the pilot stays put the cutter will work like a charm. Also keep the drill speed at a medium speed - slow enough not to heat up the cutter but fast enough that it doesn't jam in the material.
Re: Spot Weld Cutter [Re: 2abodymcodes] #2696671
09/11/19 07:34 PM
09/11/19 07:34 PM
cbusters Offline
cbusters  Offline
Cheap cutters will work if you keep them oiled. I fill a spray can lid with atf and dip it every two or three holes.
Re: Spot Weld Cutter [Re: Stanton] #2696817
09/12/19 09:13 AM
09/12/19 09:13 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Stanton has a good suggestion. He's right that it is impossible to get all the spot welds completely cut, so a good amount of chiseling is necessary. I use a flat chisel blade in an air hammer that is turned down very low. Much faster (and easier) than hand hammering.
Another good reason to use the drill bit type of cutter is because they don't leave the center of the weld that has to be ground down. I can cut several panels out with just 2 bits, an 8mm and a 10mm. With the Blair toothed cutters, I would have went through quite a few of their bits. If you break even one tooth, it makes it very difficult to keep it in the cut. And it does help to pre-drill a pilot dimple for the pilot with the Blairs, but that is just more wasted time vs the drill bit style. With some odd shaped spot welds, it is still best to drill a pilot dimple even with the drill bit type. But it is only on the occasional odd spot, not every one.
When I first started pulling panels, I used the Blairs and a hand chisel. Now, with the drill bit style and the air hammer, I can pull a panel cleaner and much quicker and with less effort.
I haven't tried the split bits mentioned above. Are they hard to start and hold in the exact spot they need to be to get the most spot weld cut?
Re: Spot Weld Cutter [Re: DaveRS23] #2697323
09/13/19 09:20 PM
09/13/19 09:20 PM
cbusters Offline
cbusters  Offline
I used a wood chisel. Flatter and a longer lead on the angle. I cut right through the little sheet metal tags.
Re: Spot Weld Cutter [Re: cbusters] #2697345
09/13/19 11:18 PM
09/13/19 11:18 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use a punch and hammer first to make a divit in the middle of spot weld then use the cutter... work
A-Body's RULE!
Re: Spot Weld Cutter [Re: 2abodymcodes] #2697934
09/16/19 12:46 AM
09/16/19 12:46 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use blair and keep the drill speed low. I never broke the teeth off one, but too much speed makes too much heat and they won't cut as well then.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Spot Weld Cutter [Re: Silver70] #2697997
09/16/19 10:12 AM
09/16/19 10:12 AM
moparx Offline
moparx  Offline
any round, toothed cutter works best with reduced RPM and moderate feed rate [pressure]. this greatly reduces, or eliminates tooth breakage.
lubrication helps as well for tool life.
beer
Re: Spot Weld Cutter [Re: 2abodymcodes] #2699485
09/21/19 11:01 AM
09/21/19 11:01 AM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
That Blair is the hot ticket. It is sold under a few names, including Matco. They should have the cutting tips available in 3/8" and 5/16" The blair tips are much beefier than the others that I have used. Center punch the hole, take it slow and low, keep the tip wet. .......(shhhhh. car talk is sooo dirty). As far as splitting the panels after cutting, trial and error. I had/have a homemade separator that I made from a piece of steel about 1" wide and 1/4" thick I sharpened. Eastwoods and others have a dedicated separator that mimics what I have. Take your time and don't be too aggressive with the chiseling, if you want to keep either panel in shape.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Spot Weld Cutter [Re: DaveRS23] #2699525
09/21/19 01:29 PM
09/21/19 01:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Mine are very similar to this one. Came in a 3 pack of sizes. After using the toothed ones and broke off a few teeth, bought these and never had an issue
Re: Spot Weld Cutter [Re: gtx6970] #2699527
09/21/19 01:31 PM
09/21/19 01:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The ones I own.
Ive used them several times and no complaints what so ever
https://www.ebay.com/itm/Spot-Weld-Cutter-Drill-Bit-set-HSS-1-4-5-16-3-8-USA/123130685627?
Re: Spot Weld Cutter [Re: gtx6970] #2700290
09/23/19 10:16 PM
09/23/19 10:16 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
I have the Blair kit and recently purchased the drill bit style made by Norseman. Made in the USA. I bought both 8mm and 10mm. Here is the link to the 8mm cutter.
https://autobodymetalcuttingsupplie...t-point-spot-weld-cutter-made-in-the-usa
David
Re: Spot Weld Cutter [Re: David1971] #2702279
09/30/19 02:22 PM
09/30/19 02:22 PM
Shelby, Ohio
2
Shelby, Ohio
Thanks for all the advise. I bought a Blair kit thru my Cornwell dealer.
Re: Spot Weld Cutter [Re: mdwyer] #2706692
10/14/19 12:55 PM
10/14/19 12:55 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Same here
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
