Re: Spot Weld Cutter
[Re: 2abodymcodes]
#2696188
09/10/19 03:36 PM
09/10/19 03:36 PM
Posts: 209 Carlisle, AR.
mdwyer
Carlisle, AR.
i use Blair spot weld cutters. seem to last longer than the cheaper ones
1970 Challenger T/A 1970 Roadrunner RM21 Vcode 1971 Gtx 1971 Satellite 1971 Charger 500 GB5 383 A54 car 1972 Satellite 1997 Dodge 1500 hunting rig 2014 Ram 2500 Mega Cab
[Re: mdwyer]
#2696224
09/10/19 05:04 PM
09/10/19 05:04 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
i use Blair spot weld cutters. seem to last longer than the cheaper ones I use a small drill bit to start a pilot hole and then the Blair spot weld cutter.
[Re: 2abodymcodes]
#2696286
09/10/19 07:17 PM
09/10/19 07:17 PM
Posts: 12,017 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Personally, I have had better service with the drill bit style of spot weld cutter than I have with the toothed ones. I keep breaking the teeth on the toothed ones. The drill bit type are available in 8mm and 10mm. I keep both since they are cheap. And they like to be turned slooooooooowwwwww so as to not build up heat. I can use a drill bit style one for a long, long time because it doesn't have teeth to break off.
https://www.ebay.com/itm/10-mm-COBALT-SPOT-WELD-CUTTER-WELDER-DRILL-BIT/230756723524?epid=1258453770&hash=item35ba2c2b44:g:FlYAAOSwd4tT82yr
Master, again and still
[Re: DaveRS23]
#2696299
09/10/19 08:44 PM
09/10/19 08:44 PM
Posts: 643 southern conn
1969gtx
southern conn
split point drill bit 5/16 and 3/8 sold at ace hardware
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: Stanton]
#2696817
09/12/19 09:13 AM
09/12/19 09:13 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Stanton has a good suggestion. He's right that it is impossible to get all the spot welds completely cut, so a good amount of chiseling is necessary. I use a flat chisel blade in an air hammer that is turned down very low. Much faster (and easier) than hand hammering.
Another good reason to use the drill bit type of cutter is because they don't leave the center of the weld that has to be ground down. I can cut several panels out with just 2 bits, an 8mm and a 10mm. With the Blair toothed cutters, I would have went through quite a few of their bits. If you break even one tooth, it makes it very difficult to keep it in the cut. And it does help to pre-drill a pilot dimple for the pilot with the Blairs, but that is just more wasted time vs the drill bit style. With some odd shaped spot welds, it is still best to drill a pilot dimple even with the drill bit type. But it is only on the occasional odd spot, not every one.
When I first started pulling panels, I used the Blairs and a hand chisel. Now, with the drill bit style and the air hammer, I can pull a panel cleaner and much quicker and with less effort.
I haven't tried the split bits mentioned above. Are they hard to start and hold in the exact spot they need to be to get the most spot weld cut?
[Re: 2abodymcodes]
#2697934
09/16/19 12:46 AM
09/16/19 12:46 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I use blair and keep the drill speed low. I never broke the teeth off one, but too much speed makes too much heat and they won't cut as well then.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 2abodymcodes]
#2699485
09/21/19 11:01 AM
09/21/19 11:01 AM
Posts: 752 AZ - The "dry heat" state
71autoxr
That Blair is the hot ticket. It is sold under a few names, including Matco. They should have the cutting tips available in 3/8" and 5/16" The blair tips are much beefier than the others that I have used. Center punch the hole, take it slow and low, keep the tip wet. .......(shhhhh. car talk is sooo dirty). As far as splitting the panels after cutting, trial and error. I had/have a homemade separator that I made from a piece of steel about 1" wide and 1/4" thick I sharpened. Eastwoods and others have a dedicated separator that mimics what I have. Take your time and don't be too aggressive with the chiseling, if you want to keep either panel in shape.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
