Update on my car and the 3 causes of problems
#2695804
09/09/19 02:14 PM
09/09/19 02:14 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
I tried to post this last night before my computer, ISP, locked up after typing on it for over 30 minutes and loosing it all, that went just like my weekend I left early Friday morning with a planned stop in Klamath Falls to buy some NP 833 parts from a tranny shop down there, I forgot to bring my driving instruction sheet with the shop phone number on it, I have a old flip phone so no help on getting driving directions from it. I tried to find it from my memory but missed it so Iended up having to call my wife for help and finally found the shop 1/2 hour later, loaded up the parts and headed out of the parking lot next door and ran over something big I didn't see that crunch the right front wheel and tire on the car trailer I had to drive about five miles before I could pull over to look at it and then drive another five miles to get to a place I could safely change it. Drove onto Sacramento with nothing bad happening until about 20 miles north of Sacramento to run into stop and go traffic jam north of the airport which went on for about 15 miles, lost around 40 minutes in that to have it happen again when I got into north Sacramento due to the Friday afternoon traffic rush Finally got off the freeways to end up getting lost due to missing a street sign I needed to turn east on, another 30 minutes lost stopping twice to get directions and finding the track $50.00 fee for a 4 hour test and tune It was almost dark so I ended up not unloading the car but I did leave the trailer with the car in it and ended up getting to the hotel around 9:30 PM and checked in, while I was doing that that a tour bus pull in with around 50 non English speaking tourist from Asia, not sure which country, maybe Japan which filled the lobby up bad enough to make it really hard to get from my truck with my luggage up to my room on the second floor Not a good start I went to the track Saturday morning well before the gates open to find out that I had park my trailer in a car show arena so strike two, moved it and got it in line for tech before they started time trails but I had to argue with the track owner wanting to charge anyone who was running time only(fun run, no class for electronic cars) another $50.00 above the pre entry fee of $40.00 I have had issues with this car this year having ignition issues that will make it kick back against the starter and back fire through the carb, now and then, not all the time. I had change the distributor thinking that was it and that seemed to fix it until I was ready to start it in the staging lanes, car ran over a second slow and 10 MPH slow, didn't leave worth a hoot and so on. Had trouble getting it started on the return road so I decided to check the timing again in the pits and ended up having the 12 V lead from the timing light ground out against the hot wire to the battery in the trunk after I got it started , it smoked that wire all the way back to the battery cut off switch ending my day, strike three I tried starting it after disconnecting that burnt up wire but no luck I did get to meet and talk to several members on here, Keith Richards, Shiloh and several others members on here that I'm not able to remember there names now I needed to turn my truck and trailer around so I could use the winch to load the car but some street racer had decided to park his new Challenger in my pit space blocking my car after I had walked up to talk to Shilow several pit space away from mine in the same row which ended adding some more frustrations to my great weekend of racing The only good thing that came out of the trials and tribulation is I remember that if I don't have some bad times now and then I forget to enjoy the good times, man am I ready for them I think my ignition problem may be related to me running the charging wire next to the magnetic pick up wires from the distributor in the cockpit, I will reroute the new charging wire far away from them this time One more race schedule locally next weekend of so I'm hoping to have it I fixed and run a new best in the 1/8 mile, 5.50 hopefully at or above 120 MPH RANT OFF I'll update off the last post on here
Re: Not so good weekend of trying to race at Sacramento
[Re: Cab_Burge]
#2695811
09/09/19 02:30 PM
09/09/19 02:30 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
got it in line for tech before they started time trails but I had to argue with the track owner wanting to charge anyone who was running time only (fun run, no class for electronic cars) another $50.00 above the pre entry fee of $40.00
And no kiss.
[Re: Cab_Burge]
#2696006
09/10/19 12:01 AM
09/10/19 12:01 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Cab it was excellent to finally meet you in person .. looks like we will be putting this race on our annual truck up north hopefully we will have more time to hang out next year..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: J_BODY]
#2696345
09/10/19 10:42 PM
09/10/19 10:42 PM
Posts: 608 TN
1DGEMAN
TN
Sacramento is FAMOUS for azzhats parking in pit spaces of racers...... that’s why I head out into the grass!
Been a few years since I’ve made the 9hr trek up there. Seems t me that used to have a lot of goatheads in the grass. That was years ago though.
Real Men shift for themselves
[Re: gregsdart]
#2696362
09/10/19 11:30 PM
09/10/19 11:30 PM
Cab_Burge
Probably not as all the MSD parts I have are old The distributor pickup harness is one of the older ones(15+Yrs) it is twisted inside a sheath but I'm almost sure their is no metallic shielding in that sheath I'll try to do a ohm test on the sheath and see if it conducts or not This car had a MSD 44 amp mag in it before I got it, I added the MSD7AL2, wiring and coil. I have a roll of 2 wire with a grounded sheath covering shielded wires some where around here , I'll check the one on the car and go from there Thanks for the heads up on that
[Re: Cab_Burge]
#2696366
09/10/19 11:42 PM
09/10/19 11:42 PM
Posts: 1,505 TN
SCATPACK 1
TN
What car did you take Cab Any pictures from your adventure.
Old Geezer Racing
[Re: SCATPACK 1]
#2696384
09/11/19 03:05 AM
09/11/19 03:05 AM
Cab_Burge
I don't know how to post pictures on here now, yet The car is a 1970 S/P Cuda chrome moly tube chassis car that weighs right at 2750Lbs with me in it ready to race, best ET so far is 8.862 at 150. MPH. I've been fighting this intermittent tuning issue for way to long, time to fix it and get on making the car faster I did a little testing on the car this afternoon and no spark from the coil, no voltage to the MSD 12V lead now I thought the last race of the year at the local track was the weekend after next, it is this weekend so it's time to get my rear in gear and fix this monster More tomorrow
[Re: HardcoreB]
#2696730
09/11/19 09:57 PM
09/11/19 09:57 PM
Cab_Burge
I melted two holes in the high pressure lines to the Shiftnoid throttle stop, which drained the CO2 bottle, and blew the 30 amp fuse for the ignition, the fuse did its job protecting the rest of the ignition wiring I'm waiting for a 25 Ft roll of 10 gauge wire and a new 100 amp Powermatser alternator do to be delivered tomorrow Hopefully back in the saddle this weekend
[Re: Cab_Burge]
#2696782
09/12/19 12:22 AM
09/12/19 12:22 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Cab, do you need some shielded aircraft wire? I also have some ground solder sleeves. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: mopar dave]
#2697359
09/14/19 01:03 AM
09/14/19 01:03 AM
Cab_Burge
UPDATE, I found 3 problems with my S/P car today while rewiring the alternator and rerouting MSD7AL2 coil and distributor pick up harnesses. First was when I installed the MSD7AL2 and coil I had ran the distributor mag pickup wires under the intake and the coil wires on the frame but I had tyrapped them together on the inside floor back to the MSD box for about 30 inches I did use a grounded sheath cable for the distributor pick up wires and had it grounded near the MSD box They are now separated by 18 inches or so all the way from the distributor to the box, same thing on the coil wire and alternator feed wire Second thing was that when I swapped the old and new motor last winter I evidently didn't tighten the mid plate to the frame bracket bolts where the #0 ground wire from the chassis to the engine is attached Third thing was it was still kicking back on the starter due to the timing being set over 45 degrees I had set it at 35 degrees before loading the car to go to Sacramento last Thursday Me thinks this car hates me and is messing with me all the time, I will work on it and beat on it until it does what I want I'll post on how it goes tomorrow evening when I get back from the track
