Throttle cable - need 19"-22" long, OEM style. Any sources? #2695597
09/08/19 10:00 PM
09/08/19 10:00 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Hey guys and gals,
I've got that issue of having changed carbs and now need a throttle cable (with OEM end fittings) that is about 2" longer than stock. My OEM stock is 17", and I need something like 19" but I'd take up to 22"..
Is there any source that lists 1960's style OEM Mopar Throttle cables by length, so I can choose the length I want?
I can find a good number of vendors who sell the OEM style cables online, but they list them by application; like '66 Charger 383', or '65 Belvedere Big Block', A-Body, etc..
..so far none of them have cared to just tell me what their lengths are, because they probably sell by drop-ship.
I see there is a "Long" OEM Mopar throttle cable, but it's 24-1/2".. a bit too long for my needs.
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: 67SATisfaction] #2695604
09/08/19 10:12 PM
09/08/19 10:12 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Mancini Racing has or will make what you need.
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: CSK] #2695615
09/08/19 10:48 PM
09/08/19 10:48 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
what year is car? there are 2 different styles that it can be. it is how it comes thru the firewall. andy f has a chart listing lenghts. i had a 65 coronet that was orig 225 and i left that in and was long enough to turn car sideways.
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: rbkt65] #2695706
09/09/19 10:06 AM
09/09/19 10:06 AM
moparx Offline
moparx  Offline
in the past, when i needed a longer cable and couldn't find it right away, i used a thin strip of approximately 1/8" steel to make up the needed distance. drilled the hole size needed in both ends, then used either a bolt with a ny-lok nut or a clevis pin and clip [sometimes hard to find that was short enough] in the cable end.
the carb end attached like usual, using the other hole in the strip.
rounding the ends and a spritz of paint from a rattle can made it look acceptable until the correct cable could be sourced.
this worked so good that sometimes, i just forgot about replacing the cable.
just something to consider if you run into a roadblock, or time constraint.
beer
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: moparx] #2695809
09/09/19 02:27 PM
09/09/19 02:27 PM
Albany, NY
Albany, NY
Thanks all - it's a '65 Satellite with the OEM firewall neck and clip / keeper..
I'll look at Mancini and AndyF's list, see what makes sense..
....just something to consider if you run into a roadblock, or time constraint.
beer
thumbs Thanks, brilliant minds think alike.. I fabricated about 1" of that, but need a little more.. and figured I could find something.
I want a fix in place by Friday, so yeah - I'm looking around now for some sheetmetal, and get the correct cable later.
Cheers,
- Art
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: 67SATisfaction] #2696134
09/10/19 12:49 PM
09/10/19 12:49 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I just called up Wildcat in Oregon and told them what length I needed and it had to fit my car. Apparently they have a bunch of them hanging on a rack and they grabbed one that was the length I wanted. Worked perfectly for me......
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: belv2vert66] #2697641
09/14/19 11:06 PM
09/14/19 11:06 PM
Albany, NY
Albany, NY
Thanks guys
- Here's an update and hopefully something useful for you all to take away..
So I found a longer 21-3/4" cable with OEM ends that would mount properly at the gas pedal and at the carburetor..
I looked at the product photos closely, it all looked good, and went ahead and ordered it.
I woke up the next morning and canceled the order.
Why?
Because what I realized as I was falling asleep (cuz, who doesn't think about their Mopars last thing before falling asleep, right?) was that the problem isn't the overall length of the cable. The problem was with the length of cable that sticks out of the metal-sleeved end. That end reaches from the manifold bracket to the mounting pin at the carburetor. That's what was too short. Not the overall length. What I'm saying is, you can have as long a cable as you want, but the amount of cable coming out of that metal-sleeved end has to be enough to reach the distance from the throttle cable bracket to the carburetor.
Instead of the longer cable, I fabricated a length of steel plate that extended by 1-1/2" the original length of cable that comes out of the metal-sleeved end to reach from the manifold bracket to the carburetor pin.
Cheers,
- Art
Re: Throttle cable - need 19"-22" long, OEM style. Any sources? [Re: 67SATisfaction] #2697706
09/15/19 10:30 AM
09/15/19 10:30 AM
moparx Offline
moparx  Offline
glad you got it going art !
i have done the same thing, extending the length of the cable end by fabbing a thin strip of steel to the length needed. a little rounding of the ends, paint, and few would know it was not stock, if they even noticed at all.
beer
