premium or cheap drill bit needed #2695308
09/07/19 09:14 PM
09/07/19 09:14 PM
RapidRobert Offline OP
I am going to drill my oil passages from crank to oil gallery. I will be very careful as to not break off a drill bit & trash the block & I am wondering if I bought a premium drill bit that I assume would be harder or a cheaper one that might flex a bit before snapping if that would increase my odds. thank you for your time.
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695311
09/07/19 09:19 PM
09/07/19 09:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My vote is for the best bit you can find. It will stay sharp longer and it will be designed better and make a cleaner hole twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: premium or cheap drill bit needed [Re: fourgearsavoy] #2695336
09/07/19 10:55 PM
09/07/19 10:55 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I like good drill bits, but in that application, you really aren't doing that much, I would probably buy the cheapest one I could find. You aren't drilling a hole you are enlarging it. And cast iron cuts like butter.
2011 Drag Pak Challenger
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695355
09/08/19 02:02 AM
09/08/19 02:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Use a reamer. They are not that expensive in the smaller sizes and they do a better job, leaving a smoother surface inside the hole.
I have used this one: https://www.amazon.com/gp/product/B00DMAUAPA/ref=ppx_yo_dt_b_asin_title_o07_s02?ie=UTF8&psc=1
But it is a bit on the short side, and I held it in a drill extension, but worked good for $12
If you can get a longer one it would make the job really easy.
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695360
09/08/19 07:07 AM
09/08/19 07:07 AM
Sticky South
Rodenteliminator Offline
Sticky South
Use the reamer at low speed and not a lot of pressure and pull it out often to let it clean, don't get in a hurry !
Sorry honey I spent the rent
Re: premium or cheap drill bit needed [Re: Rodenteliminator] #2695368
09/08/19 08:46 AM
09/08/19 08:46 AM
pennsylvania
poboyengineering Offline
pennsylvania
I was able to get aircraft bits (partial flute, long reach) at my local hardware store. They only carried 1/4 and 5/16" They required a lot of "pecking" to keep the chips from clogging the flutes.
Cleveland twist drill carries the 9/32' that McCandless suggested in the MP engine book and they have fully fluted bits.Even with the full flute don't try to get it all in one stroke.
https://www.cutting-tool-supply.com/ClevelandTwistDrill/
Be sure to use the correct speed, it's a pretty splindly bit. The calculations work out at approx 1000 rpm.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: premium or cheap drill bit needed [Re: poboyengineering] #2695391
09/08/19 10:01 AM
09/08/19 10:01 AM
this pristine fresh block which looks like gold was machined ten ways from sunday & with a $1700 machine shop bill I cannot afford a fatal mistake at this stage of the game. Thanks guys.
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695409
09/08/19 11:06 AM
09/08/19 11:06 AM
moparx Offline
moparx  Offline
use a reamer only ! it won't grab and snap like a drill will.
i don't know what size hole you have to start with, but a reamer is designed to only enlarge around .010 [ten thousandths] above the drilled hole size. you will more than likely, have to buy a couple of them to arrive at your desired hole size. use plenty of lube, relieve the hole often to clear the chips, and take your time.
reamers come in extended reach in virtually all sizes, so you don't need to settle for a shorty.
try mcmaster-carr for your needs, or possibly the bag.
the only thing to watch for before you start, use something like a coat hanger or welding rod, and run through the hole to make sure there is nothing obstructing the hole. i have see all kinds of "stuff" [especially in cast holes] hiding in long holes that still allowed the hole to function as designed, although not at 100%, such as chunks of broken tooling and casting boogers. both of which can shatter quality tooling upon contact. you shouldn't find anything, but you never know.
beer
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695416
09/08/19 11:20 AM
09/08/19 11:20 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Use a reamer as mentioned. A 6” chucking reamer will barely break thru, but it will work fine. Just chuck it at the end of the chuck mostly. Also, use an air drill. It gives you better control, and is less torquey than electric or even a cordless. You’ll also appreciate the smaller drill, when you team #5.You can also help by just chamfering the edge of the hole, either with a file or bit to help reamer engagement. Ream with steady pressure. Don’t horse it, but keep it steady, and keep pulling the reamer back to clean the flutes. You don’t need lube, the cast iron doesn’t need it. When done, put a 1/2” cartridge roll on an extended shank, and go in and touch all the inside of the galleys. Reaming WILL leave little shards of metal, and you must clean them off.
RIP Monte Smith
Re: premium or cheap drill bit needed [Re: Rodenteliminator] #2695423
09/08/19 11:33 AM
09/08/19 11:33 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
This!
When you clean the reamer , DO NOT use a rag in your bare hand, the reamer will slice through it like it is not even there. Ask me how I know, DOH!
use a stiff bristle brush to clear the chips. Paul
Re: premium or cheap drill bit needed [Re: iapco103] #2695466
09/08/19 01:55 PM
09/08/19 01:55 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Sometimes I think guys overthink some of these jobs. I will be grabbing my long drill bit out of my engine building box and doing two blocks this week. Like I’ve done many times before. Spray drill, spray drill, repeat. Job done.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: premium or cheap drill bit needed [Re: pittsburghracer] #2695605
09/08/19 10:14 PM
09/08/19 10:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When it comes to buying an extra long bit like the one required to do the job, you're not going to have much choice between "cheap" or "premium". FWIW, the one I bought back in 1974 has served me well and is still in fine shape to do many more blocks. But I should note that I have never used that bit for anything else.
Re: premium or cheap drill bit needed [Re: CompWedgeEngines] #2695612
09/08/19 10:41 PM
09/08/19 10:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 6" reamer works fine on the #1 through #4 mains, but the drill chuck gets in the way of the block at the rear seal retainer area, so that is where a drill bit extension comes in handy to clear the block wall at the #5 main.
If you are a decent welder, you can also weld a rod to the reamer to make it longer and not have to spend $50+ on an extended length reamer.
Drilling works too, done it several times and only broke one drill bit, but after using the reamer, it just seems to do the job easier and quicker, with a cleaner finish, less burrs and such where it breaks through, and smoother walls inside the reamed hole.
Re: premium or cheap drill bit needed [Re: RapidRobert] #2695630
09/08/19 11:33 PM
09/08/19 11:33 PM
AndyF Offline
AndyF  Offline
By an extra long reamer and keep it in the original case in your tool box and it should last a long time. You can get them for around $30 from a tool supply house or order one on line.
Re: premium or cheap drill bit needed [Re: AndyF] #2695735
09/09/19 11:12 AM
09/09/19 11:12 AM
Alright, it sounds like reaming is the way to go, I just hope I dont have to buy several depending on how much material is needed to get to 9/32 but I will if need be. I just dont feel lucky on this operation so I am leery of a drill bit tho I have done it that way in the past. thanks guys for the excellent feedback.
