AVS fuel line wrestling #2693752
09/02/19 08:24 PM
09/02/19 08:24 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Needed a fuel line from pump to AVS for this '68 Road Runner 383.
Got one from Classic (# MF574A) that's supposedly for this application.
Uh, no way. Even tried 2 tubing benders to tune it, no luck.
Quite different at the lower area, as far as bends & angles, hits block, alternator, & distributor.
I have an original to compare it to but the carb end was screwed up by someone, hence the aftermarket Russian Roulette.
The Classic catalog also lists an MF571A and MF572A.
The 571 says for AFB but looks the same as the OEM piece. Also looks like Inline Tube # PRE6801.
The 572 says for AVS but looks more like the 574.
Anyone here know the secret part # or if the AFB uses the same thread as AVS?
Re: AVS fuel line wrestling [Re: topside] #2693772
09/02/19 09:14 PM
09/02/19 09:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Steve,thread is the same and I may ( or may not ) have a good fuel line,I'll look tomorrow and let you know.
Re: AVS fuel line wrestling [Re: 62maxwgn] #2693779
09/02/19 09:34 PM
09/02/19 09:34 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Appreciate that, Bill - this is a pretty shiny piece, for what it's worth.
Re: AVS fuel line wrestling [Re: topside] #2694770
09/05/19 07:13 PM
09/05/19 07:13 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Well the update on what's turning into a bit of a cluster****...and additional info if it helps:
Tried repairing the existing line, still a leaker @ carb end just spinning the motor unlit.
Bill's line was already claimed, but big thanks for trying thumbs
Called Classic & spoke with a tech guy there, who unfortunately isn't familiar with Mopars.
He did have the 571 & 572 pulled and gave me measurements & descriptions as best he could.
Classic gets their lines from Fine Lines.
The 572 sounded "no way".
Gonna try the 571, which cost $24.99 + $8.95 UPS, but they're sending me an RMA for the 574 at least.
Inline Tube has a # PRE6801 that looks right, but I'll try the 571 and report back in case it helps someone.
Classic's & Inline Tubes' photos show the lines upside down and/or backwards, printed a page of each and viewed each from opposite side of the paper.
Looked all over the FSM & Interweb for a clear photo of correct routing - 2nd-guessing myself - nuthin'.
I guess nobody here has run into this?
Oh, and FWIW, the "KV" stamped hose is rock hard. But at least it's short. (insert wisecrack here).
Maybe my OCD can turn this into a 2-week saga, complete with Waa-mbulance laugh2 !
Re: AVS fuel line wrestling [Re: topside] #2694920
09/06/19 10:40 AM
09/06/19 10:40 AM
moparx Offline
moparx  Offline
my best friend has stated many times : "there is no such thing as a [insert YOUR time here] 15 minute job."
beer
Re: AVS fuel line wrestling [Re: topside] #2714750
11/11/19 11:04 AM
11/11/19 11:04 AM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I'm going to have to replace the fuel lines from the pump to the carb on my 67 Belvedere II 383, which has an AVS as well. Did you ever get this sorted out?
Lee
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: AVS fuel line wrestling [Re: lilcuda] #2714758
11/11/19 11:52 AM
11/11/19 11:52 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Oops, forgot the update on this, sorry.
Yes, the 571 worked after a minor tweak to get the angle right at the carb end.
Re: AVS fuel line wrestling [Re: topside] #2714824
11/11/19 02:56 PM
11/11/19 02:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
For whats its worth,
Ive used both Fine lines and inline tube BOTH required some tweaking on one end or the other to make them fit.
Got so pissed off on one ( dont remember which ) I just made my own lower one time.
Re: AVS fuel line wrestling [Re: gtx6970] #2714975
11/11/19 09:47 PM
11/11/19 09:47 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I just replaced the fuel lines from the front rail to the pump and up to the carb on mine and got them from Fine Lines and probably needed very minor tweaking but were better than any others I've had with my other cars.
inherited a 69 roadrunner from my grand pop.
Re: AVS fuel line wrestling [Re: topside] #2716138
11/15/19 04:02 PM
11/15/19 04:02 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Thanks for the info! I ordered the Inline Tube # PRE6801. Hopefully, it's a good part.
