Trick flow heads on a 5.9 Magnum #2692146
08/28/19 05:56 AM
08/28/19 05:56 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Well, after a few months of getting the car ready I'm about ready to pull the trigger on heads for my 5.9 Magnum and I really want to run the new trick flows
,anybody got any real world experience with them yet? Where did you get them? Did they have to be tweaked? My short block is assembled, it's just a bracket build, ARP bolts on stock rods and crank with zero deck KB's, no cam or heads bought yet, 4:10 gear, 727 trans in the below 67 Dart, glass hood and front bumper, one seat interior, trying to see if I can get it in the mid 6's. First small block bracket car I've ever built.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2692361
08/28/19 05:12 PM
08/28/19 05:12 PM
Weatherford, Texas
Weatherford, Texas
Nobody has put trick flows on a Magnum yet....?
1968 Plymouth GTX
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2692384
08/28/19 07:29 PM
08/28/19 07:29 PM
there just was a thread on trick flows (I didn't pay much attention to the jist of it cuz they are above my pay grade) but you might be able to glean some info from it.
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2692560
08/29/19 10:27 AM
08/29/19 10:27 AM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
This may be helpful reading. If may be worth contacting B3RE to discuss.
https://www.forabodiesonly.com/mopar/threads/tf-190-heads.439418/
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2692664
08/29/19 04:43 PM
08/29/19 04:43 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I think it's been done and they used Harland Sharp shaft mounted rockers that oil through the push rod. The story is on FABO.
Re: Trick flow heads on a 5.9 Magnum [Re: 65Dodge440] #2692790
08/30/19 04:50 AM
08/30/19 04:50 AM
Weatherford, Texas
Weatherford, Texas
Thanks, I'll go check it out.
1968 Plymouth GTX
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2693189
08/31/19 04:01 PM
08/31/19 04:01 PM
SoCal
Brian Hafliger Offline
SoCal
What info are you looking for? Only thing you have to do is run a rocker arm setup that allows oil up thru the adjuster like the new HS rockers designed for this head, or PRW stainless rockers like we use, or TD rockers (best if using a solid roller cam).
Brian Hafliger
Re: Trick flow heads on a 5.9 Magnum [Re: Brian Hafliger] #2694574
09/05/19 05:41 AM
09/05/19 05:41 AM
Weatherford, Texas
Weatherford, Texas
Thanks for the reply Brian, just saw it this morning, I will try and give you a call today, thanks.
1968 Plymouth GTX
Re: Trick flow heads on a 5.9 Magnum [Re: RapidusMaximus] #2694611
09/05/19 09:15 AM
09/05/19 09:15 AM
NY usa
540challenger Offline
NY usa
If I am not mistaken, the early magnum blocks still had the oil holes drilled in the deck. So u could still but the LA style head on.
