Trick flow heads on a 5.9 Magnum
#2692146
08/28/19 05:56 AM
08/28/19 05:56 AM
Posts: 2,411 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Well, after a few months of getting the car ready I'm about ready to pull the trigger on heads for my 5.9 Magnum and I really want to run the new trick flows ,anybody got any real world experience with them yet? Where did you get them? Did they have to be tweaked? My short block is assembled, it's just a bracket build, ARP bolts on stock rods and crank with zero deck KB's, no cam or heads bought yet, 4:10 gear, 727 trans in the below 67 Dart, glass hood and front bumper, one seat interior, trying to see if I can get it in the mid 6's. First small block bracket car I've ever built.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Trick flow heads on a 5.9 Magnum
[Re: RapidusMaximus]
#2692384
08/28/19 07:29 PM
08/28/19 07:29 PM
RapidRobert
there just was a thread on trick flows (I didn't pay much attention to the jist of it cuz they are above my pay grade) but you might be able to glean some info from it.
#2692664
08/29/19 04:43 PM
08/29/19 04:43 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Nobody has put trick flows on a Magnum yet....? I think it's been done and they used Harland Sharp shaft mounted rockers that oil through the push rod. The story is on FABO.
#2693189
08/31/19 04:01 PM
08/31/19 04:01 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
What info are you looking for? Only thing you have to do is run a rocker arm setup that allows oil up thru the adjuster like the new HS rockers designed for this head, or PRW stainless rockers like we use, or TD rockers (best if using a solid roller cam).
Brian Hafliger
[Re: Brian Hafliger]
#2694574
09/05/19 05:41 AM
09/05/19 05:41 AM
RapidusMaximus
Weatherford, Texas
Thanks for the reply Brian, just saw it this morning, I will try and give you a call today, thanks.
