Where to find info on an 833 #2692923
08/30/19 02:17 PM
08/30/19 02:17 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Hi, we have an 833 we bought for use on a 71 RR we're building.
Have decided to go auto.
Friend we bought it from has no idea on it's origin.
Is their a resource on line or here to determine what it is from, year, etc.?
Stenciled #s are: 4F 245825, PP8334852
Cast case #s : C99129H
Tail case #s: C99539E
23 Spline
We want to sell it and the flywheel, new clutch and bell housing to offset some of the cost of a rebuilt 727.
Thanks in advance, Joe
Re: Where to find info on an 833 [Re: jlatessa] #2692926
08/30/19 02:39 PM
08/30/19 02:39 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
74 model year b/e body. Casting number on front bearing retainer?
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Where to find info on an 833 [Re: jlatessa] #2692961
08/30/19 04:39 PM
08/30/19 04:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
are the stamped numbers clear? got a pic? confused
4F 245825 would've been a Newark, DE assembled '74 Dart or Valiant
4852 is Saturday, November 9, 1974 (too LATE for 1974 model year)
Re: Where to find info on an 833 [Re: 6bblgt] #2693015
08/30/19 09:18 PM
08/30/19 09:18 PM
I have cast iron case NP833 23 spline I'm wondering what it came it came out of originally, it has a stamp of PP8333020 and them stamped OE125609 on the same line with 0225 stamped directly under it on the same pad. The case casting number C99129 help
Sorry for hijacking this blush
Re: Where to find info on an 833 [Re: Cab_Burge] #2693106
08/31/19 10:19 AM
08/31/19 10:19 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab like you I have 2.One is early with flange for drive shaft.The other is supposedly from 69 RR.Sat in friends building for probally 30 years.Been in my other garage for years also.Rocky
Chrysler Firepower
Re: Where to find info on an 833 [Re: Cab_Burge] #2693129
08/31/19 11:43 AM
08/31/19 11:43 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally Posted by Cab_Burge
stamped 0E125609
It is from a 1970 Challenger from the LA plant.
New number to me, but if the owner ever registers the car I can let you know.
Re: Where to find info on an 833 [Re: Alaskan_TA] #2693320
09/01/19 12:22 AM
09/01/19 12:22 AM
Thanks, I would really appreciate the help bow up
I was going to put a A body main shaft (out put shaft) with all the gears on it, and A body tail shaft housing on this case, not now realcrazy
I don't have a 1970 and later B&E body tail shaft housing so it is time to look for one wrench
I do have a good SO CA desert 1966 to 1969 B body tail shaft housing to trade if anyone is interested in trading work help
Re: Where to find info on an 833 [Re: Cab_Burge] #2693974
09/03/19 01:46 PM
09/03/19 01:46 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Getting back to Dan Brewer on the casting # of the front bearing retainer.
Dan the # is: 69866 and a backward "C"
Thanks, Joe
Re: Where to find info on an 833 [Re: jlatessa] #2694228
09/04/19 08:15 AM
09/04/19 08:15 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Thanks, Joe
Should be C99369? They can be hard to read sometimes. With that retainer, it's 4.805" diameter. Would have come out of a 74 B body with a 400 BB.
Re: Where to find info on an 833 [Re: Dan Brewer] #2694255
09/04/19 09:37 AM
09/04/19 09:37 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Ha! that's funny, reading it upside-down, the numbers worked, though...LOL
Thanks, Dan
