ATI Damper Pulley Alignment? #2690652
08/23/19 02:32 PM
08/23/19 02:32 PM
North Dakota
Azzkikrcuda Online content OP
Azzkikrcuda  Online Content OP
North Dakota
Looking at getting ATI Damper part number 917470E, Which lists as working with stock cover and pulley alignment. Can anyone confirm stock pulleys will line up with this Damper. Thanks.
The only Carbs I care about are under the hood!
Re: ATI Damper Pulley Alignment? [Re: Azzkikrcuda] #2690659
08/23/19 02:52 PM
08/23/19 02:52 PM
Is that the part number for a BB?
If so what year are you working on?
Re: ATI Damper Pulley Alignment? [Re: Cab_Burge] #2690687
08/23/19 05:09 PM
08/23/19 05:09 PM
North Dakota
North Dakota
Internal balance, Big Block mopar
Re: ATI Damper Pulley Alignment? [Re: Azzkikrcuda] #2690719
08/23/19 06:57 PM
08/23/19 06:57 PM
MN
W
Willie68coronet Offline
W
MN
Yeah I have that damper on my 440 with stock timing cover and pulleys. Lined up straight for me
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: ATI Damper Pulley Alignment? [Re: Azzkikrcuda] #2690740
08/23/19 08:47 PM
08/23/19 08:47 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
ATI 917470E
I believe that I need to use a 0.060" spacer behind the WP pulley.
Re: ATI Damper Pulley Alignment? [Re: BSB67] #2690862
08/24/19 09:26 AM
08/24/19 09:26 AM
North Dakota
North Dakota
50/50 so far.
Re: ATI Damper Pulley Alignment? [Re: Azzkikrcuda] #2690895
08/24/19 11:29 AM
08/24/19 11:29 AM
MN
W
W
MN
I bought the water pump spacer he mentioned but didn't need it when I mocked everything up.
I used Superformance gaskets everywhere, which are thicker than fel pro. That could be a difference or some other variable.
Re: ATI Damper Pulley Alignment? [Re: Willie68coronet] #2690901
08/24/19 12:06 PM
08/24/19 12:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
.060 is less than 1/16" I bet the factory wasn't that precise.
Re: ATI Damper Pulley Alignment? [Re: second 70] #2690903
08/24/19 12:16 PM
08/24/19 12:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
And it's with an aftermarket WP housing and pump. WP to block and WP housing to WP gaskets are 0.030".
At the end of the day, I would say it lines up as best as one could expect considering the stack/variables.
Re: ATI Damper Pulley Alignment? [Re: Azzkikrcuda] #2690939
08/24/19 02:43 PM
08/24/19 02:43 PM
North Dakota
North Dakota
Thanks everyone for the info. Sounds like it should work.
Re: ATI Damper Pulley Alignment? [Re: BSB67] #2691149
08/25/19 10:18 AM
08/25/19 10:18 AM
central il.
second 70 Offline
second 70  Offline
central il.
Heck better than that yours look perfect.
Re: ATI Damper Pulley Alignment? [Re: Willie68coronet] #2691328
08/25/19 07:12 PM
08/25/19 07:12 PM
AndyF Online content
AndyF  Online Content
Also depends if you use the oil slinger or not. The oil slinger pushes the damper forward a small amount. Gasket thickness will also change pulley alignment and so will the type of pulley that you use. Reproduction and aluminum pulleys might not be correct.
Re: ATI Damper Pulley Alignment? [Re: second 70] #2692749
08/29/19 10:18 PM
08/29/19 10:18 PM
North Dakota
North Dakota
Got the ATI Damper today and measured pulley location against a stock damper. Was only 0.03 inch difference. Using Stock pulley setups with this Damper should not be a problem.
