black coating on AMD panels. Leave on or remove? #2692062
08/27/19 08:21 PM
08/27/19 08:21 PM
New Brunswick Canada
copperSwinger Offline OP
Do you people recommend removing the black coating on AMD replacement panels? will be spraying epoxy primer soon and wondering if the primer will bite bare metal better than the black coating from AMD.
car is a fastback barracuda with new full quarters and rear valence from AMD
thanks
Re: black coating on AMD panels. Leave on or remove? [Re: copperSwinger] #2692064
08/27/19 08:23 PM
08/27/19 08:23 PM
Kirkland, Washington
Pacnorthcuda Offline
I removed it.
Re: black coating on AMD panels. Leave on or remove? [Re: Pacnorthcuda] #2692081
08/27/19 09:15 PM
08/27/19 09:15 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
We always remove it on exterior surfaces-it’s not worth the risk trusting it to do the job a good epoxy can do.
Re: black coating on AMD panels. Leave on or remove? [Re: Paul Jacobs] #2692110
08/27/19 10:44 PM
08/27/19 10:44 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
At Carlisle, there was a restorers panel session and they all said always remove it down to bare metal. Plus they said to always wear a mask because the black coating is a lung health hazard!! I had not heard that before.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: black coating on AMD panels. Leave on or remove? [Re: copperSwinger] #2692121
08/27/19 11:31 PM
08/27/19 11:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks
Remove it and treat it to either an etch-primer or epoxy coat
