Re: Small block toothed flex plate?
[Re: crash520]
#2691909
08/27/19 12:18 PM
08/27/19 12:18 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Guys is there such thing as a 130 tooth small block flex plate? Need one for engine dyno, std 6 bolt pattern? If you keep your eyes open you should be able to pick up a used flex plate from someone running a powerglide. New ones are available from places like Summit or Jegs. I have both 6 and 8 bolt ones I use in my cars
[Re: crash520]
#2693566
09/02/19 03:24 AM
09/02/19 03:24 AM
Posts: 6,142 Melbourne , Australia
LA360
Guys is there such thing as a 130 tooth small block flex plate? Need one for engine dyno, std 6 bolt pattern? If it's for a Superflow Dyno, you'll need a flywheel. I've seen people use toothed flexplates in a pinch, but it's not ideal. The DTS tailshaft style from memory require an crankshaft adapter. Not sure what the tooth count is typically on a V8 flywheel, but there should be someone you might be able to borrow one or buy one from.
Alan Jones
[Re: crash520]
#2694554
09/05/19 01:27 AM
09/05/19 01:27 AM
LA360
Depending on their set up, you may just need the flexplate to start it. DTS had an option for a remote starter as well.
Alan Jones
