Which mini starter do I ask for? #2691017
08/24/19 08:08 PM
08/24/19 08:08 PM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
We are putting a 1969 style BB motor in a car. It has a manual transmission, so it's the 11" clutch. I believe its a 143 tooth flywheel. The TTI header instructions say to use a mini starter. It gives several Mopar part numbers. But we were going to get one at Auto Zone or wherever. Which one would be best? What model/year/engine car do I tell them it's for? Thanks.
2011 Drag Pak Challenger
Re: Which mini starter do I ask for? [Re: rickseeman] #2691022
08/24/19 08:11 PM
08/24/19 08:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1998 Ram with a 360 should work.
NAPA has a lifetime warranty now also.
Re: Which mini starter do I ask for? [Re: Alaskan_TA] #2691024
08/24/19 08:28 PM
08/24/19 08:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Any decent parts store should be able to cross an OEM part number to something they sell.
Re: Which mini starter do I ask for? [Re: rickseeman] #2691026
08/24/19 08:33 PM
08/24/19 08:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I suggest the genuine Denso unit that Mancini carries. I'm running a factory 318 Dakota starter on my 143 tooth flywheel with Doug's headers and it fits fine.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Which mini starter do I ask for? [Re: fourgearsavoy] #2691040
08/24/19 09:01 PM
08/24/19 09:01 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Gus beer
That's what I used on my 65. (It's an automatic.) I didn't know if it would work on a car that had a direct drive starter originally.
Re: Which mini starter do I ask for? [Re: rickseeman] #2691145
08/25/19 10:17 AM
08/25/19 10:17 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
I wish we still had a NAPA around here. Ours had some knowledgeable people in there. I'll get one and give it a try. Thanks.
Re: Which mini starter do I ask for? [Re: rickseeman] #2691161
08/25/19 10:40 AM
08/25/19 10:40 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Your NAPA may have had some good people, but I question their starter rebuilder:
I'm on the 3rd replacement NAPA Premium starter in my Pathfinder.
Factory one lasted over 190,000 miles.
Their best rebuilts get maybe 5,000 before stranding you somewhere.
This latest one sounds like it's laboring...
Re: Which mini starter do I ask for? [Re: topside] #2691185
08/25/19 11:22 AM
08/25/19 11:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a reman Advance in my 65 440.12.5 compression and 2 inch TTIs with 4 speed.Been in for 20 years.Still works like new.My son ran 440 source in his 62 300 413.It was in like 5 years and no problems.Rocky
Chrysler Firepower
Re: Which mini starter do I ask for? [Re: rickseeman] #2691313
08/25/19 06:26 PM
08/25/19 06:26 PM
Rittman Ohio
Rittman Ohio
Gus beer
I'm pretty sure only the early production 426 HEMI used the direct drive starter with a special bellhousing that wont use the late model gear reduction starter.
Double check your bell and flywheel before you bolt it all together twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Which mini starter do I ask for? [Re: fourgearsavoy] #2691321
08/25/19 06:57 PM
08/25/19 06:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
My 64 300's 413 used a direct drive starter and the mini starter didn't fit. It was a 3 speed manual trans, not an auto or an A833.
Re: Which mini starter do I ask for? [Re: Sniper] #2691368
08/25/19 09:22 PM
08/25/19 09:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The 143 is a bolt in on the starter.The DD Hemi was iirc 178 teeth.My buddy has one in his Runner.I run a 143 with Lakewood.Did run the stock bell years ago.No problems with a mini.My stock bell was from like a 69 or so Runner.Just remember if it has the plastic cap it usually has to be tossed.Some blocks need the studs cut down a bit also.Rocky
Chrysler Firepower
Re: Which mini starter do I ask for? [Re: therocks] #2691408
08/25/19 11:22 PM
08/25/19 11:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I replaced my Power Master mini starter about 3 years ago for my 440/493 in my 63 . Went to Salvo's and got one for a 98 pickup truck for a 318. Cost me about $70 dollars and has a lifetime warranty. Still working great with no problems and cranks my bigblock over very good. Ron
Re: Which mini starter do I ask for? [Re: fourgearsavoy] #2699583
09/21/19 06:37 PM
09/21/19 06:37 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Gus beer
Gus beer
Gus is right. After the early '60's, the only direct drive starter was in the '66-'69 Hemi cars and only those with a manual trans and 172 tooth ring gear. For those rare applications, the only aftermarket gear reduced replacement starter is the RobbMc: http://www.robbmcperformance.com/products/hemi_starter.html
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Which mini starter do I ask for? [Re: Sniper] #2699678
09/21/19 11:04 PM
09/21/19 11:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If you have a Mopar number, they should be smart enough to do a cross reference. Or you could go to their website and do it yourself. I always know the numbers I need when I go to a part store. Saves the aggravation.
Re: Which mini starter do I ask for? [Re: CMcAllister] #2699779
09/22/19 10:46 AM
09/22/19 10:46 AM
moparx Offline
moparx  Offline
aggravation ? at a parts store ? laugh2 laugh2 laugh2
surely not ? laugh2 laugh2 laugh2
you mean your vehicle is "not in the computer" ? laugh2 laugh2 laugh2
whistling stirthepot
beer
Re: Which mini starter do I ask for? [Re: CMcAllister] #2699827
09/22/19 12:06 PM
09/22/19 12:06 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Even when I have a part number and know exactly what I want they still want to know what year and model it is going on. I tell them it doesn't matter because it never came on this car but they disagree. The only way they know how to find it in their computer is to drill down starting with year, make, and model. Seriously, they can't look up it up by a part number? Crap software or too lazy to learn how to use all of its features?
You should have seen the chaos when I wanted to buy a Honda battery for my Simplicity lawn tractor. Haha. The Simplicity battery is like 1/8" different in size, costs more, has less amps and is no longer made.
Re: Which mini starter do I ask for? [Re: GomangoCuda] #2699857
09/22/19 12:50 PM
09/22/19 12:50 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Dart has a reman from a 93 5.2 Dakota, it's been flawless for almost 15 years. It's been on the 340, 408 and now the 434.
Re: Which mini starter do I ask for? [Re: moparx] #2699865
09/22/19 01:46 PM
09/22/19 01:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
beer
Been awhile, but back when I didn't have a computer in my pocket or in the shop, I pulled a part (some electronic thing IIRC) from one of my vehicles, carried it to an AZ, showed it to the guy and said - this is a xxx and I need this for my xxx, He looked at it and said - they never made one. After that, I knew part numbers - just go get one off the shelf please.
Re: Which mini starter do I ask for? [Re: CMcAllister] #2699947
09/22/19 08:28 PM
09/22/19 08:28 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
as per Slantsixdan:
"There is even a smaller starter that works... Ask for one from a 2005-2008 Dodge Ram with a 5.7 and a MANUAL transmission, the automatic starter for this application is totally different and will not fit.
It is a coaxial (planetary) gear reduction design, not offset like the Chrysler and Nippondenso gear reduction starter designs. That's why the motor housing is directly in line with the starter drive axis, thus making the whole starter more "laterally compact".
Be sure and get a genuine starter with a Chrysler, Denso, or Nippondenso nameplate on it. The Chinese copycats flooding the market (advertised at parts stores as "100% new!") are junk. A used genuine starter from a wrecking yard is preferable to a new fake/Chinese or "remanufactured" starter."
EDIT: You will have to drill out the one threaded hole this starter has. I forgot to mention that.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Which mini starter do I ask for? [Re: mopardude318] #2700016
09/23/19 12:50 AM
09/23/19 12:50 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Originally Posted by mopardude318
as per Slantsixdan:
[img]https://i.ibb.co/ySkxp2q/IMG-0424-zpsa920a78b.jpg[/
I’ll check into that tomorrow.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
