Same cap for 8 1/4 and 8 3/8 ring and pinion? #2691252
08/25/19 03:26 PM
08/25/19 03:26 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
My '79 W150 has an 8 3/8 rear R&P. It's seeping a bit of fluid from the diff, even though I recently serviced it. I'm going to pop the cap off again soon, and have a closer look to see if the cap is bent along the lip. I don't see any listings for new caps for 8 3/8, so I'm wondering if it uses same cap as the 8 1/4? Randy's Ring and Pinion website doesn't even show listing for one. Only shows 8.25 and 9.25 for '79 W150. I believe both are 10 bolt, so maybe same cap for both 8's? I want to be ready to purchase one if needed. Thanks.
Larry
Facts are stubborn things.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: larrymopar360] #2691259
08/25/19 03:42 PM
08/25/19 03:42 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Do you need the rubber fill plug? If yes it is the same part number as the 8 1/4 car plug. I have a couple nos plugs. I can mail you one for free if you can`t find it local. 3723687
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: mopars4ever] #2691271
08/25/19 04:20 PM
08/25/19 04:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I think he's talking about the sheet metal cover.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: mopars4ever] #2691286
08/25/19 05:01 PM
08/25/19 05:01 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I appreciate that but no, I'm talking about the actual cover. 10 bolt cover. Sorry for confusion and Thank you.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: larrymopar360] #2691288
08/25/19 05:04 PM
08/25/19 05:04 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
This is all that's listed for covers. Copy and paste didn't work frown
www.randysworldwide.com/diff-wizard/?diffyear=1979&make=Dodge&model=W150+1%2F2+Ton+4x4&drivetype=Rear+Diff+-+4WD
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: larrymopar360] #2691336
08/25/19 07:22 PM
08/25/19 07:22 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Someone can correct me if I’m wrong, but I was always under the impression that the 8 1/4 and 8 3/8 were one and the same. Just that the 8 3/8 was called that for truck use for some reason
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: 440newport] #2691367
08/25/19 09:22 PM
08/25/19 09:22 PM
md
md
Easy to find are the chrome ones. The plain metal ones not so much. 4049689. 8 1/4 and 8 3/8 are the same as far as i know.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: mopars4ever] #2691369
08/25/19 09:26 PM
08/25/19 09:26 PM
md
md
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: mopars4ever] #2691384
08/25/19 10:02 PM
08/25/19 10:02 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Dorman 697-709 black steel rubber plug under $30
Spectre Performance 6093 chrome, screw in plug under $25
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: Sniper] #2692046
08/27/19 07:41 PM
08/27/19 07:41 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I had no trouble finding 8.25 ones. I just need to be sure they are indeed the same (8 1/4 and 8 3/8) before ordering one. What an oddity that Chrysler would confuse things this way if they are the same. My FSM shows 8 3/8.
Thanks.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion? [Re: larrymopar360] #2692176
08/28/19 08:26 AM
08/28/19 08:26 AM
md
md
The mopar part number for the cover is the same for 8 1/4 and 8 3/8. The earlier 8 1/4 part number 2852921 from a 74 passenger car parts book for the cover interchanges with the 8 3/8 4049689 that is listed in the 78 truck book.
