Same cap for 8 1/4 and 8 3/8 ring and pinion?
#2691252
08/25/19 03:26 PM
08/25/19 03:26 PM
Posts: 15,877 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My '79 W150 has an 8 3/8 rear R&P. It's seeping a bit of fluid from the diff, even though I recently serviced it. I'm going to pop the cap off again soon, and have a closer look to see if the cap is bent along the lip. I don't see any listings for new caps for 8 3/8, so I'm wondering if it uses same cap as the 8 1/4? Randy's Ring and Pinion website doesn't even show listing for one. Only shows 8.25 and 9.25 for '79 W150. I believe both are 10 bolt, so maybe same cap for both 8's? I want to be ready to purchase one if needed. Thanks.
Larry
Facts are stubborn things.
Re: Same cap for 8 1/4 and 8 3/8 ring and pinion?
[Re: mopars4ever]
#2691286
08/25/19 05:01 PM
08/25/19 05:01 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Do you need the rubber fill plug? If yes it is the same part number as the 8 1/4 car plug. I have a couple nos plugs. I can mail you one for free if you can`t find it local. 3723687 I appreciate that but no, I'm talking about the actual cover. 10 bolt cover. Sorry for confusion and Thank you.
[Re: larrymopar360]
#2691288
08/25/19 05:04 PM
08/25/19 05:04 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
This is all that's listed for covers. Copy and paste didn't work www.randysworldwide.com/diff-wizard/?diffyear=1979&make=Dodge&model=W150+1%2F2+Ton+4x4&drivetype=Rear+Diff+-+4WD
[Re: mopars4ever]
#2691369
08/25/19 09:26 PM
08/25/19 09:26 PM
Posts: 13,593 md
mopars4ever
md
[Re: Sniper]
#2692046
08/27/19 07:41 PM
08/27/19 07:41 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I had no trouble finding 8.25 ones. I just need to be sure they are indeed the same (8 1/4 and 8 3/8) before ordering one. What an oddity that Chrysler would confuse things this way if they are the same. My FSM shows 8 3/8.
Thanks.
