Page 2 of 4 1 2 3 4
Re: bending cotter pins on tie rod ends and ball joints [Re: John_Kunkel] #2690074
08/21/19 04:45 PM
08/21/19 04:45 PM
WV
Little Detroit Offline
WV
I really can't believe I wasted my time reading this thread, but I'll say it's darn entraining to say the least ,that so many do not have anything more constructive to do than try to make a mountain out of a mole hill. but then again I read it.
Re: bending cotter pins on tie rod ends and ball joints [Re: Little Detroit] #2690187
08/21/19 11:03 PM
08/21/19 11:03 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yeah and it was your 426 HEMI numbered post too, something you can remember positively about a wasted post read. laugh2
Little Detroit
WV
Re: bending cotter pins on tie rod ends and ball joints [Re: Little Detroit] #2690208
08/22/19 01:04 AM
08/22/19 01:04 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
[quote=Little Detroit]
I really can't believe I wasted my time reading this thread, but I'll say it's darn entraining to say the least ,that so many do not have anything more constructive to do than try to make a mountain out of a mole hill. but then again I read it. [/quote
I'd say it was quick&sloppy. Same manner in which bumpers/doors/paint/etc were done back then. Geez: unless Chrysler actually had training on this or a written procedure. Sounds like it belongs in a Corvette forum.
Re: bending cotter pins on tie rod ends and ball joints [Re: PhillyRag] #2690235
08/22/19 08:29 AM
08/22/19 08:29 AM
WV
WV
thank you philly rag , pretty much the point I was sarcastically trying to point out. you would think common sense would come into play somewhere.
Re: bending cotter pins on tie rod ends and ball joints [Re: John_Kunkel] #2690413
08/22/19 05:45 PM
08/22/19 05:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally Posted by John_Kunkel
So, "correct" becomes "anal". Noted.
BTW, it's not impossible, I routinely do it on front suspension components that are the subject of this thread.
He asked about this part;
Quote
the way it came from the factory in the mid 70`s
So are you are running a 1970's era factory in 2019 or just misreading the question?
Re: bending cotter pins on tie rod ends and ball joints [Re: Alaskan_TA] #2690607
08/23/19 11:40 AM
08/23/19 11:40 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I understood the original question but merely commented on, what I consider, to be silliness. One strives to be "original" by installing cotter pins willy-nilly but has the chrome/paint redone to modern show standards.
Re: bending cotter pins on tie rod ends and ball joints [Re: John_Kunkel] #2690790
08/23/19 10:26 PM
08/23/19 10:26 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Where's "ROCK" these days? I want him to Sign my wheel well so that it's "factory line correct".
Maybe he still has the pencil he used back then.
Will that suffice?
I'm 99.99999% there.
Approaching the far outer reaches towards madness..
Re: bending cotter pins on tie rod ends and ball joints [Re: PhillyRag] #2690853
08/24/19 09:06 AM
08/24/19 09:06 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Will that suffice?
Don't forget your little black Dill valve stem caps or you're still not done !
Re: bending cotter pins on tie rod ends and ball joints [Re: 62maxwgn] #2690861
08/24/19 09:25 AM
08/24/19 09:25 AM
georgia
moparpro Offline
moparpro  Offline
georgia
anyone know the size of the factory cotter pins i need to buy some. thanks
Re: bending cotter pins on tie rod ends and ball joints [Re: moparpro] #2690866
08/24/19 09:46 AM
08/24/19 09:46 AM
moparx Online content
moparx  Online Content
all kidding aside, i once thought corvette dudes were fanatics when it came to restorations, but we have them beat by a country mile !
good or bad, our restorations are tons better. up
now where is my tank of NOS tire air ? i know it's here somewhere......... shruggy
beer
Re: bending cotter pins on tie rod ends and ball joints [Re: moparpro] #2690874
08/24/19 10:01 AM
08/24/19 10:01 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Better be careful,90 % of cotter pins are made in china ! eek
Re: bending cotter pins on tie rod ends and ball joints [Re: Alaskan_TA] #2690892
08/24/19 11:14 AM
08/24/19 11:14 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
My vote for thread of the year!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: bending cotter pins on tie rod ends and ball joints [Re: BloFish] #2690896
08/24/19 11:32 AM
08/24/19 11:32 AM
Guitar Jones Offline
laugh2 I just bend it back over the stud/bolt/spindle/whatever then cut the protruding meat ripper off flush with the nut. It ain't brain surgery.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: bending cotter pins on tie rod ends and ball joints [Re: Guitar Jones] #2690905
08/24/19 12:18 PM
08/24/19 12:18 PM
Akron, ohio
76orangewagon Offline
Akron, ohio
I'm going to assume that you (Mopars4ever) purchased or have the correct 3 prong castle nuts to use on your suspension components, its kind of pointless getting the cotter pin details correct if your using the wrong 6 prong castle nuts that come with all the aftermarket ball joints, tie rod ends, ect...
Re: bending cotter pins on tie rod ends and ball joints [Re: 76orangewagon] #2690931
08/24/19 02:14 PM
08/24/19 02:14 PM
md
mopars4ever Offline OP
md
76 Yes, i do. NOS upper and lower arms. NOS idler and pitman arms. NOS torsion bar end bushing. Just got a NOS upper ball joint boot 2269127 that was missing from a member here. So it`s not pointless to me but maybe to most. Honestly, I really don`t care if someone feels its trivial or not. Some people feel a need to express their way of thinking all the time around here. I feel it`s trivia when someone needs to express what they feel is trivial or not. Why do they waste their time? Dunno??? I`m getting some good info even with all the ones trying to ruin someones post. Some are proud of their work and some are proud of how their mouth works.
Re: bending cotter pins on tie rod ends and ball joints [Re: 62maxwgn] #2690932
08/24/19 02:16 PM
08/24/19 02:16 PM
md
md
I have a box of NOS mopar pins. I`m not sure of the size. I will have to check. Update: These are the ones I have. Are these correct? If you need some and they will work for you let me know.
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2690977
08/24/19 05:02 PM
08/24/19 05:02 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OMG The answer to the question is right there on the cotter pin box; HAMMERLOCK !!! hammer
Re: bending cotter pins on tie rod ends and ball joints [Re: A12] #2691027
08/24/19 08:33 PM
08/24/19 08:33 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The green box of pins are not NOS, those were sold at mopar parts stores and are relabeled pik-a-nut, originals are shorter, and do not have the bend at the end. The wrench rounding them off sure seems to make them look right. The little stuff matters on a restoration in my opinion, Johns way is better, but would stick out like a sore thumb on a restoration. When I pulled my superbird apart you could tell the idler arm was changed, correct mopar part, but wrong pin installed nicely, it stuck out. I would install the pins right and nice on everything except a restoration. Believe me, if you install the pins nicely on a car with all the proper colors, boots and plating, the mopar vin crowd would point out your "mistake". You can't win.
Re: bending cotter pins on tie rod ends and ball joints [Re: 4406bbl] #2691029
08/24/19 08:39 PM
08/24/19 08:39 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Made a mistake here, I should have said those pins are not assembly line correct, they could well be NOS.
Re: bending cotter pins on tie rod ends and ball joints [Re: mopars4ever] #2691050
08/24/19 09:48 PM
08/24/19 09:48 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Don’t ever let someone’s opinion stop you from getting the details right- I’m doing another OE restoration right now (#7) and am fanatical about the way it’s going- but in the end it’s my car and satisfies me and that’s all that matters...
Page 2 of 4 1 2 3 4
